PHEV mod under way, Bristol, UK.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by aminorjourney, Jun 7, 2008.
  1. aminorjourney
    aminorjourney Mum to two prius!
    335
    27
    Bristol, UK
    Drum roll....
    It's not 100% finished, but at least now I'm getting a proper plug in experience. I have to still build the battery box as the batteries are very temporarily secured in the trunk.
    I'm looking at finishing it some time in the next fortnight so it's ready for the exhibition. I'll also add the fan to the OEM packs to make sure they don't overheat.
    I just got back from a band-rehearsal I was coaching. I was able to head there and back in EV mode. Result!
    (And on a new tank I'm getting 150 mpg so far!)
  2. mrbigh
    3,686
    699
    Long Island, NY
    Congratulations Nikki, the UK EV Amazon!!! of today days.
    Keep the project going
  3. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Congratulations! I'm currently setting on 1110 miles 155MPG and rising tank. I have an estimated 300+ miles to go before I fill up. See if you can catch up. :D I cant wait to see your finished PHEV.
  4. aminorjourney
    335
    27
    Bristol, UK
    It may take me some time! I'm currently sitting at 80 miles or so, with fuel economy hovering at 79 mpg. Yesterday I had to do a huge number of miles so lost the good start I'd got with 11 miles at 130 mpg!
    I'm hoping today I may be able to improve on that as I'll be doing town driving and possibly have the chance to fill up with electrons half way through the day!
    Nikki.
  5. Flying White Dutchman
    4,376
    313
    have seen the video already
    subs. to your youtube channel haha
    i see you packs get to 30Celsius?
    is that after a charge
    whats your outside temp
    i have a round 5celcius uitside but my packs never get past 16celsius.
    i do use a lot bigger cable's
  6. aminorjourney
    335
    27
    Bristol, UK
    Hi!
    My packs got to 30 degrees C with just the OEM pack being charged.
    In the last four days the pack temperature hasn't gone above 19 degrees C - I filmed things just after I'd switched from one pack to three ;)
    My cables are 6AWG - so bigger than the EAA-PHEV wiki requires. What size are you using?
    Nikki.
  7. Flying White Dutchman
    4,376
    313
    i have to check again nikke
    not sure around 10 if i am not mistaken.
    dont understand one thing
    your packs ( so more then 1 ) go to 30C if you just charge your OEM pack???
    so when your not charging your add packs wy are these rizing to 30c???
    i just got my winter milage in...... disapointing 1 liter for 20,149 km or 47.42 MPG or 4,96L/100km
  8. aminorjourney
    335
    27
    Bristol, UK
    Hi Mr Flying ;)
    I'll start again - because I think my last post was rather confusing.
    I initially connected things up incorrectly, so if I had all three packs connected while driving my car's dash lit up like a Christmas tree! I stupidly put the extra batteries in parallel at a point in the circuit which meant that the hall effect sensor in the Prius couldn't measure the correct current drain.
    So, to cope, I was charging all three packs together- then disconnecting the two additional ones. I drove the Prius with the single battery and then dump-charged (equalised) the voltage when parked by connecting the two additional packs.
    On Tuesday, when I made the video, I'd been driving the car all day with only one pack - so the temperature was higher (30degrees C). I had then parked up and correctly connected the batteries so I could use all three at the same time.
    The OEM battery was still warm when I took the video, so it appeared that the pack was warmer than usual.
    In the past four days I've not seen the temperature climb above 19 degrees C (and that includes long drives!)
    My current fuel economy? 3.62L/100km (about 78mpg UK or 66 mpg (US)
  9. Flying White Dutchman
    4,376
    313
    a ok that clears thing up haha
    dump charging like that is not a smart thing to do.
    there are going to be high amps going from the charged 2 add packs into the depleted OEM pack at that moment..
    never dump charge and not go for a drive after that
    never dump charge and leave the packs for the evening.
    the high amps dump into the already hot OEM pack may cause termal runaway.
  10. aminorjourney
    335
    27
    Bristol, UK
    Flying,
    I think I may still be confusing you. I'm no longer dump charging (I was only doing it for a day). Now I've fixed up my setup I am charging and using packs in parallel. The hottest they've got so far is 21 degrees (just now after a long hilly trip). No big mountain passes though!
    So far I have 80.3 UK mpg and 158 miles post conversion. I'm actually sitting in my car waiting for my next school so this is a live figure!
  11. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    I have followed this thread with great interest. Congratulations on getting it running. One question, when you are charging from house power, are you charging all three batteries or just the two additional ones?
  12. Flying White Dutchman
    4,376
    313
    i did got it the first time haha
    just that even on 1 dump charge you can overheat the pack..
    but your save now so nothing to say here:D:p
  13. aminorjourney
    335
    27
    Bristol, UK
    I'm charging all three! Because they are essentially the same chemistry and similar enough to charge in parallel I can get away with it!
    Flying, glad I didn't cause any confusion! ;)
  14. aminorjourney
    335
    27
    Bristol, UK
    Here's a quick update:
    I was able to charge last night when we went out for Sushi. Our new local Mall (6 miles away) has SIX electric vehicle charging points. I was able to charge back to about 2/3 full while we were out eating.
    This morning we made a trip into town and back without much use of petrol and again just now. This gave rise to this:
    I'm hoping by the end of Tuesday I'll have the figure back up to the low 90s or even into the low 100s, since Mondays and Tuesdays are all about multiple short trips where I'll have chance to charge.
    If I keep this up I'll be able to do 800+ miles on a tank . :)
    I am very happy!
  15. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Are you sticking to the %40-%80 range for the battery charge or are you charging and depleting a wider range?
  16. aminorjourney
    335
    27
    Bristol, UK
    I'm pretty sure it's using 30% to 85% range, so it is extending it slightly. I hope to get a third additional battery, making four in total. I think it'll make a huge difference.
    Your pack is hymotion, isn't it?
    Nikki.
  17. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Yes my pack is the Hymotion. If I could not get a Hymotion pack I was going to do what you are doing now. I'm just curious if people are going to try to keep the 40-60 range to make the batteries last longer or if they are doing a more deeper discharge to get more range. Personally I would be doing exactly what your dong right now in the 30-85 range. You get a little more mileage without hurting the battery too much.
  18. aminorjourney
    335
    27
    Bristol, UK
    Exactly!
    In terms of energy, I think my pack is able to use about 14 ah (or about 3KWH if my math is correct). I was hoping for more, but I think my batteries may settle down as time passes so I may be able to squeeze more out when the weather is warmer.
    I am also now actively keeping my eyes out for pack number 4. We'll see if I can find one at a good price. Then I hope for a 15 mile EV range...
  19. mrbigh
    3,686
    699
    Long Island, NY
    Nikki, you will find that after your 12 or 15 full batteries recharge, these will get settle in the coordinated system and will provide you a better electrical range. Also, winter temperatures do NOT help a lot, the ICE will turn on as required by the car multiple Ecu's.
    Regarding achieved higher MPG, you are doing very well and U will do better, In my case, the vehicle is at my disposal and convenience and I do not like to suffer low temperatures nor freezing my but while driving early in the morning, so I do warm-up my Prius prior leaving to work; I do not do a full EV drive at all times in winter time but I do take the advantage of the PHEV as often as possible.
    My PHEV experimental stage ranged already 4 years, it is time for me to enjoy all the benefits of this Hybrid car conversion.
  20. jstack
    jstack New Member
    211
    40
    Chandler Arizona
    I
    I wonder if the A123 hymotion system would sell to you and make this easy. They are Canadian at the core so they connect well with the UK. They have a great system with top rated A123 safe lithium cells.
    Maybe contac them and see. You could be a UK green CHIP installer for them.
    cherio
    https://www.a123systems.com/hymotion/products/reserve_yours
