Physical key doesn't turn lock, SKS works
Discussion in 'Gen 2 Prius Main Forum' started by George W, Jun 30, 2019.
  1. George W
    George W Senior Member
    939
    520
    San Antonio
    Being the 3rd owner of an 08 Prius, I've never had to use the physical key to access the car. At the time of purchase (over a year ago) it only came with one fob.
    Out of curiosity, I finally attempted to use the hidden key, to learn it will not budge the Tumblers in either direction. I injected a bit of dry graphite Lube into the lock, to no avail. It's almost as if it's the wrong physical key.
    Electrically all of the Locking mechanisms respond inside the car. The fob works normally. All of the door handles appear to function correctly.
    Are there known issues on failed tumblers for Gen 2? Thanks
  2. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    I really, really had to work at mine on my '08 when I bought it 18 months ago. Took about 3 days of trying, but it works now. Word to the wise... use your physical key once in a while, a lock needs to be exercised.
    George W and ChrisFaehrtPrius like this.
  3. PriusCamper
    PriusCamper Senior Member
    13,467
    5,435
    Pacific Northwest, USA
    Maybe if you take the door panel off and work the mechanisms to loosen things up from both sides at the same time? I do know that in the first decade of Gen2 Prius, cars in areas with heavy rain used to show subtle signs of lock lubricant of some sort dripping down from key slot onto door. But now that Gen2 is older I never see that on cars anymore. As if it dried up after all these years? But keep working at it, it's an essential function you will need if you ever have your FOB fail.
    George W likes this.
    52,863
    maybe not the correct key? if you cannot get it to turn, you'll have to replace the cylinder
  5. George W
    939
    520
    San Antonio
    Did you use a dry lube or something like WD-40? Thank you.
  6. George W
    939
    520
    San Antonio
    That will be Plan C. Thank you.
  7. egg_salad
    545
    426
    Las Vegas, NV
    I used no lubricant, but I would certainly never use WD40 on a lock, it will just get gummy. Just wiggled the key while gently attempting to turn the lock.
    Graeme1949 likes this.
  8. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    I'm w/ Bisco.
  9. George W
    939
    520
    San Antonio
    Just trying to figure out how they paired the physical key's chip with this car, unless the driver side tumbler was changed at some point in the past. I've tried using a small amount of vibration to work the graphite powder into the tumbler but nothing has yet budged.
    #9 George W, Jul 2, 2019
  10. bisco
    52,863
    there is no relationship between the chip and the key. any key can be inserted into the fob
  11. George W
    939
    520
    San Antonio
    Thank you for that Insight.
  12. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Does the key from the other keyfob work?
  13. George W
    939
    520
    San Antonio
    Isn't one. Only got 1 from the Seller.
