Pick up power for reverse?
Discussion in 'Gen 2 Prius Main Forum' started by peecee, May 15, 2017.
  1. peecee
    peecee Member
    67
    39
    Annapolis, MD
    I am installing an aftermarket backup camera for my 2004 Prius. What wire could I tap into for power while the car is in reverse? I've also seen references to people powering the camera to come on with a turn signal activation to see behind you when changing lanes, but I'm not sure if I want to do that. Rather than dig around in the back to test which wire I should use, I'm hoping someone else has blazed that trail and can help me out.
  2. tvpierce
    tvpierce Senior Member
    949
    879
    Maine
    2013 Prius v wagon
    You tap into the wire that goes to your reverse lights. It should have stated that in the instructions.
    Is this a wired or wireless install?
  3. peecee
    peecee Member
    67
    39
    Annapolis, MD
    I doesn't say to get it from the reverse, just find a wire that provides power. Although now that you say that, it makes perfect sense. Thanks!
  4. peecee
    peecee Member
    67
    39
    Annapolis, MD
    It's a wired install. I could have gotten wireless, but I'd rather not take up a Bluetooth connection with that.
  5. tvpierce
    949
    879
    Maine
    2013 Prius v wagon
    Bluetooth is exactly why I asked. I installed a wireless one for a friend in his pickup that is Bluetooth equipped. Makes the camera darn near worthless.
  6. peecee
    peecee Member
    67
    39
    Annapolis, MD
    Sorry to hear that, although I'm glad my instincts were correct. With something permanent installed, I didn't see the point of relying on wireless connectivity for the camera, especially when bluetooth has a hard enough time maintaining a connection just for audio.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    All Prius have the main camera harness installed to support a camera even if no camera installed.
    So you have a switched 12 volt b+ line and also a video cable that terminates near the radio.
    You can find it by removing the plastic panel in the hatch right below the center rubber bellows.
  8. peecee
    peecee Member
    67
    39
    Annapolis, MD
    I pulled the rear trim panels and don't see any wires that don't have corresponding connectors back there. Are you sure the harness is already there for every Prius? I'd love to use the existing wiring rather than pulling everything apart to run the video cable to the front of the car. I'll take some pictures tonight when I get home, or would appreciate a photo showing what wire(s) to look for.
