Picked up a 2007 Prius with 270k miles any advise?
Discussion in 'Gen 2 Prius Main Forum' started by Mikesvagen, Feb 12, 2018.
  1. JC91006
    16,766
    8,563
    Bleeding the prius brakes are not as straight forward as other cars. It's a good thing you didn't go through with it, it would have been an expensive mistake.
    Toyota uses techstream software to do the brake fluid changes, the brakes are electronically controlled. I seemed to have remembered Toyota advising against the fluid changes because it contributes to the brake actuator failure
  2. JoeX
    JoeX Junior Member
    PA
    Check the 12 volt battery well to, both of my 06 had water there
    Mikesvagen likes this.
  3. William Redoubt
    William Redoubt Senior Member
    1,228
    1,172
    Coronado Island, California
    The best advice you can take it to check the oil and coolants every time you fuel up. That way you will see the oil consumption/coolant use and be able to top them off before they get damagingly low. Never fuel the car without this check!
  4. Mikesvagen
    Mikesvagen Member
    31
    31
    Kathleen, GA
    I
    Guys thanks for the advise on brake fluid... I dodged a bullet on that one!!
  5. padroo
    padroo Senior Member
    2,763
    2,252
    I replaced my front struts on my 2008 at 99,000 miles. I had never heard of one failing at such low mileage and the parts stores didn't even stock them. When I said it failed, it blew all the oil out and was everywhere under the car.
    Front wheel bearings seem to have an occasional failure. They get real noisy rather than fail. If it starts sounding like a four wheel drive truck with big tires you need to check your front wheel bearings.
    HID headlights were my number one problem though. They go off and then when you cycle the light switch off and back on they come back on for a while. Bulbs are expensive but are getting cheaper as time goes on. Only the higher lever Prii had them.
  6. Mikesvagen
    Mikesvagen Member
    31
    31
    Kathleen, GA
    I
    Thanks Padroo, so far so good on the wheel bearings. I have put close to 600 miles on her so far. The tires are noisy (Ecopias) about 1/2 worn but wheel bearing noise or slop yet. I have hids on two of our other cars so keep a couple sets on hand. Struts are on the short list for replacement parts.
    iPhone ?
  7. padroo
    2,763
    2,252
    My wheel bearing had no slop in it, it just got noisy.
    This is my YouTube video of a noisy right front wheel bearing.
    http://www.youtube.com/watch?v=8TTVE-x0888
    When I changed the front struts I bought the whole complete assembly with the springs ready to install. Everything is already assembled and everything is new when you are done. If any of the other parts are bad and you start buying them individually they start getting expensive. It makes it a simple job and saves a ton of time messing with spring compressors and such.
    Mikesvagen and Prodigyplace like this.
  8. JC91006
    16,766
    8,563
    What do you think about the quality of the struts? The ride is pretty good?
    SFO likes this.
  9. Mikesvagen
    Mikesvagen Member
    31
    31
    Kathleen, GA
    I
    I have not had good experiences with quick struts in the past and refuse to buy them. Broken hats, leaky struts after 25k. I know some people that swear by them.
    The plan is to go with Kyb for struts and a mild drop, leaning toward H&R springs. Plans may change as my daughter seems to have her eye on the car.
    iPhone
  10. JC91006
    16,766
    8,563
    OEM struts are high quality and they are cheaper than KYB. Most dealerships have online stores, where you can get the parts at very competitive prices
  11. padroo
    2,763
    2,252
    Everyone has their own ideas about quality. I don't remember the name of the company and they weren't on the car that many miles before I traded the car in but the car rode like stock and how good they are I will never know. If the car were newer I would have probably bought Toyota OEM and from what I read they are pretty much bullet proof and the fact that my local parts store didn't even stock aftermarket struts for a Prius says it all even though one of mine failed.
    William Redoubt and Mikesvagen like this.
  12. oil_burner
    oil_burner Active Member
    249
    126
    I got a great deal on rock auto for all 4 struts I think it was only around $300 at that price a no brainer. might as well order new springs and isolators (the dust boot is molded in). My car was sagging a bit in the rear turned out to be a broken spring, Moog springs fixed that and the car handles much better too.
  13. Mikesvagen
    Mikesvagen Member
    31
    31
    Kathleen, GA
    I
    Ill-advised it may have been, I went on a last minute camping trip and towed the teardrop camper with my Prius. Drove 300 miles round trip and everything went off without any problems. trailer weight 565lb 165lb of added gear, tongue weight 70lb. I kept speed at 65 mph or under, Headwind going out and calm coming home avg 34.1 mpg. No oil used, all temps stayed in spec according to Prius Assistant. Braking was not an issue and getting up to speed was not bad.
    Would I do it again? With a Prius with fewer miles yes. Would I try taking it up to the mountains? NO!! I did meet a couple at the campground that said they towed their teardrop cross country with a 2011 Prius a few years back when they first retired, with careful route planning they spent almost a month on the road with no problems... I am not that brave lol
  14. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    Not a lot of weight. That's not much different than having a few things in the trunk and 3 adult males (over 200lb each) in the back seat. Or no?
  15. Mikesvagen
    Mikesvagen Member
    31
    31
    Kathleen, GA
    I
    When you put that way it really is not a lot of weight... I was very pleased with the performance.
  16. William Redoubt
    1,228
    1,172
    It's nothing. These cars are rated for towing in other countries where the lawyers have less power. In the US, being risk averse is required. Damn lawyers. Where's my settlement?????
  17. Mikesvagen
    Mikesvagen Member
    31
    31
    Kathleen, GA
    I
    I will say it was a welcome change to get over 30 mpg towing the trailer, I only get 18-22 with the Volvo.
    Prodigyplace likes this.
  18. oil_burner
    249
    126
    I pulled a bit heavier last time, about a 800lb trailer and a 500lb motorcycle on top if it. The Prius handled it ok but it was definitely at the limit of what I wanted to ever pull.
  19. Mikesvagen
    Mikesvagen Member
    31
    31
    Kathleen, GA
    I
    I feel the car could take more, I just would not do it, especially after summertime comes to Georgia. The more i think about it i will be using the Prius with my current camp setup for shorter trips.
    iPhone
