Pickup Trucks and Oil Refinery Discussion - A Jay and Jimmie Production
Discussion in 'Fred's House of Pancakes' started by jayman, May 22, 2008.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Well, that is a good way of describing it. I would suggest the middle trays output of the CDU require the least processing
  2. jayman
    13,439
    641
    Winnipeg Manitoba
    Don't forget the use of very expensive rare-earth catalysts, which must be replaced on a regular basis. Still, it's better than just dumping or flaring off "undesirable" byproducts
    Too bad the same thing can't be done to shale processing. A lot of the wash water is a soupy muck that has high levels of heavy metals, currently they sit in giant settling ponds.
    That's something the shale proponents never tell you
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ya know, after all the environmental issues they have had with settling ponds for coal mines in Appalachia, i'm surprised that its still allowed... but most of that happened in the 40's to the 70's.... memories fade... its just some of the stories is just so horrifying, i cant believe it still goes on in any form...
  4. jayman
    13,439
    641
    Winnipeg Manitoba
    A lot of folks are unaware of the requirement for settling ponds to handle the contaminated water from shale processing. It's a simple fact that after "washing" the shale you have enormous amounts of arsenic and cadmium.
    The reason the shaleoil must be "washed" is to get that crap out. Otherwise you'd kill the catalysts used in the refinery
    So what you have left over is a concentrate toxic sludge with no real plan to deal with. I suppose they figure if they wait long enough, the earth will crash into the sun and take care of the problem
    Seriously, there are means to take care of the toxic sludge, but the treatment cost is so bloody high that if factored into a barrel of syncrude, tack on another $15
    Anyhoo, leaving tomorrow on another business trip, should be back Friday. Will try to have the diagrams numbered so the process is easier to follow
  5. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    gee... glad to know our environmental future hinges on $15 a barrel. funny, we almost did that much last friday
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    I've added a second general process diagram to my posts. The generic process diagram will have a red box superimposed on what part of the process I'm secribing
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    Crude Part IV: Catalytic Reforming
    I would like to describe what happens in the last stage after isomerization, which is Catalytic Reforming. In catalytic reforming, the aromatics from the isomerization process are converted to gasoline blends and hydrogen gas
    The actual catalytic process is typically a 3-step process using 3 reactors. The first step is the naphtha’s are heated to about 900 F and pressurized up to 45 atm, then sent into the first reactor. The gases react with the catalyst which causes the naphthenes to dehydrogenate, creating aromatics. As an example, methylcyclohexane to toluene and hydrogen gas. This is endothermic, so the gases must be preheated before the second reactor
    In the second reactor, the aromatic paraffin’s are isomerized to isoparaffins. For example, n-octane to 2,5 dimethylhexane. You can also expect the paraffin’s to dehydrogenate and to undergo aromatization, such as n-heptane to toluene and hydrogen gas.
    The resulting gases must again be heated up. In the third reactor, the remaining n-heptane is mixed with recycle and generated hydrogen to produce isopentane and ethane. The resulting mixture is sent through a chiller and a gas separator, which collects the excess hydrogen.
    The resulting liquid from the chiller and gas separator is sent through a fractionating tower, and I’m sure you’ve noticed there are quite a few fractionating towers in use within a typical refinery. In this fractionating tower, the liquid is heated up again.
    The lightest aromatics from this fractionating tower are typically methane, propane, ethane, butane, and trace hydrogen. These gases are collected at the gas processing plant within the refinery, the propane and butane are useful products. The remaining gases are used as fuel to run the plant. The bottom liquid from the fractionating tower, called a “reformate,†are used as gasoline blend.
    Most often, the catalyst used is platinum, rhenium, a combination, and/or proprietary elements. The catalyst must be regenerated – usually on site - every 4-8 months of continuous operation, more often if the crude feedstock is heavy with sulfur.
    This now concludes my brief discussion of the typical oil refinery process. If anybody would like me to expound on any part of the process, or certainly the waste handling aspect, please let me know. Likewise, if anybody would like me to discuss extraction techniques, please let me know
    I’m leaving tomorrow for another week or so, hopefully back next Tuesday. I’m sure at least some of you will have questions or comments
  8. darelldd
    6,059
    389
    Northern CA
    This is a compelling reason to keep the quad pickups off the road. For the sake of safety. It isn't the small cars that are unsafe. It is the large cars that pose the danger. That's already been covered. Odd that so many folks come at this from the wrong angle. (Bikes are the same way. Riding a bike isn't the danger. The cars around the bike are the danger.)
    Jayman. Hat's off to you, man. I'm in awe of your patience (especially the beginning of this thread). I just don't have it in me.
  9. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    Thanks Jay, very enlightening. Questions. It appears that a byproduct of the process is some hydrogen. Could this byproduct be captured and shuttled off to filling stations? When I used to cross the country by auto I'd often see flaring off of gasses high atop some structure. I always thought this was a waste of natural gas (is it even n.g.?) Do they still do this? Isn't this a needless way to raise global warming? Could you talk a bit about waste from this process?
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Hello John
    There isn't much excess hydrogen from a typical refinery process. Most of the hydrogen is needed in steps involving catalytic reactions, which I briefly touched on in other posts
    What little excess hydrogen left over, can be cleaned and sent offsite for lab use. There is no way you could expect enough hydrogen to power cars, it would be far more efficient to simply power the engine with regular unleaded
    Flaring is still done to gases that cannot be used in the process and have little to no commercial use. A lot of the sour gas from fractionating towers used to be flared off. In the past 20 years a lot of research has resulted in the capture of these former waste gases
    Primarily, the waste gases can be used as part of a co-generation process to generate electricity in the refinery. The excess power can be put into the grid.
    In the event of a process upset - which is fairly common with older plants and old control systems - you will generate enormous volumes of naphthas, hydrogen, butanes, and other explosive gases. Without a quick way to deal with that, you could have a catastrophic explosion
    Parts of the process most likely to experience sudden pressure upsets are connected to a flare gas header system. When pressure exceeds a setpoint, the excess is sent to the header pipe system
    There is always a small flame at the tip of the flare pipe, think of it like a pilot on a gas water heater or stove. There are also damper systems and steam injection nozzles at the flare tip.
    When there is a process upset, the excess gas is sent to the flare pipe header system, then into the flare column itself. The small flame at the top will ignite the excess gas, automatic dampers are supposed to control the flame (Not too rich or a lot of black smoke will result), and the steam injection minimizes visible and particulate emissions.
    There is a lag time for everything to respond. The sudden burp of gas tends to create a huge orange/black fireball out the tip, then as the steam nozzles and dampers respond, it becomes a bluish/white flame until it dies down as pressure bleeds
    International law calls for minimising and even forbidding routine flaring. Not sure if folks are aware of this, but globally about half the natural gas needed to run the US is flared off oil wells each and every year. This is primarily in African, South American, and Russian oil fields.
    It's a very wasteful practise
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    Try heavy drinking. That seems to work for me!
  12. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Jayman,
    That was an amazing description of modern refining. Its much more complex than anybody could guess at from outside the industry.
    I also find it ironic, that somebody would critcizse the nickel use in a Prius battery, when there is that massive nickel uses for gasoline. Also, the nickel refining process seems to be somewhat less damaging than the tar sands processing. Its seems that Art Spinella is really living up to his name to try to imply that a vehicle that uses 3 to 4 times the fuel of a Prius is more enviorementally freindly when the fuel processing is such a big deal.
    There also is the rare earth magnet versus catalyst situation. It seems bizarre that both EV and Gasoline cars rely on these same comodities to a high degree.
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    That's why I've always gotten quite hot under the collar when a doo-fus brought it up.
    I'd suggest that back in the "good 'ole days" of Sudbury, it was as bad as tar sands is right now. It took INCO a long time to clean things up, using technology they had access to +40 years ago.
    Currently, with the effluent sludge rich in toxic heavy metals, nobody really has a clue what to do about it. Thus the giant man made lakes chock full of the stuff. And the occasional "whoopsy-daisy" moment
    Syncrude Canada Ltd. - News Room
    He never admits to being wrong. He'll make up new numbers, change the outcome, but of course, he is NEVER wrong
    A pure EV would rely on far less of it. Modern petrochemical processing has massive and continuous demand for rare earth catalysts, compared to the one-time demand for a rare earth magnet material
  14. hill
    8,808
    Re: I have betrayed you all.....sorta
    Your guess is wrong. In fact, it's somewhere out there around Neptune. It doesn't become truth either ... the more you repeat it, unfortunatly. Dr. Marion King Hubbert clued us all in on the answer, way back in 1956, as to why we'd start capping wells off here in the U.S. ... and that our gluttony would outstrip our own supplies around the early 1970's.
    M. King Hubbert - Wikipedia, the free encyclopedia
    BTW,
    The Middle Ease is our largest source for oil. Weren't you promulgating this "Canada is our largest source" thing last year? You have to section off the Mid-East countries individually, to arrive at the conclusion that the U.S. is MOST dependent on Canada for our oil - crack addiction. Last year, in THOUSANDS of barrels per day, we got over 2,700 from the Mid-East, compared to 1,900 from Canada.
    Crude Oil and Total Petroleum Imports Top 15 Countries
    But if it makes you feel more cozy, that our crack dealer is a border country ... then, "as you were".
    Bottom line: We are way up, do-do creak, with no paddle, and totally ignorant that the crack pipe is nearing empty. We need a plan as complex as our 1st Moon Landing. But rather than find alternatives, we hear screams, "Drill off the CA & FL coasts ... and drill in the arctic". Right. Use up our kid's reserves, and leave THEM with the "no plan" mess. Let's just keep talking big trucks, and repeat after me, "we got a God given right to drive what ever we want".
    I second that. And eventually Jimmie just stops, and rides his trike off into the sunset. Where'd he go? :p
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    Of course, even a short 20 years ago, folks in the engineering community already had fear of WAG's (Wild Assed Guess) of oil needing to be +$100 a barrel to ever think of uncapping some wells, or considering goey tar-like stuff in Wyoming, Utah, ND, and Alberta.
    IOW, we'd have to already be in very deep s***. Guess what? Looks like we're at +$100 a barrel. So we're now in very deep s***. As in FUBAR
    No no, patience has nothing to do with it. I credit Kokanee beer and Bombay Sapphire Gin, not necessarily in that order or even mutally exclusive. The sudden upswing in petrochemical consulting is a direct consequence of scarce resources
    Now that I think about it, a lot of the more depressed engineers and policy planers I know appear to be stocking up on hard liquor, rather than food supplies. They also appear to be almost constantly s***faced. I guess whatever helps you cope with bad news that cannot be fixed
    Not to mention the booze has a much longer shelf life than boring, ordinary food
  16. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    How much flexibility is there in generating propane vs. benzene, etc.? Are the volumes determined by the crude or does the market cause the process to shift to match demand?
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    Well, that would depend on how the particular refinery is constructed. Eg: the naphtha hydrotreater, the isomerization unit, and the catalytic reforming unit. Each step can introduce bottlenecks and obvious upsets
    For the most part, you can expect to change the yield of propane vs benzene most economically by changing process setpoints in the frac tower. Minor changes in the iso unit and the cat reform unit can also influence gas output
    For the most part, unless there is a wild change in demand for one gas or another, there is a fair amount of flexibility in process gas output. Keep in mind that the design of the various catalyst units is about as optimized as can be made.
    Unless we have a dramatic breakthrough, don't expect any sudden efficiency gains
  18. hill
    8,808
    Beer & Gin ... hmm never thought to mix 'em :D
  19. dogfriend
    7,512
    1,190
    Carmichael, CA
    Beer :thumb:
    Gin :thumb:
    Beer & Gin :sick:
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    Oops a rushed sentence on my part. Nope, I've also never thought of using beer as a mixer for gin. I usually drink them separate. For some reason, I prefer cranberry juice as a mixer for gin, gives it more of a Pucker Factor
    Anyhoo, leaving this afternoon on a business trip. Should be back Saturday
