Pics: EGR pipe at 230k miles
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ATlam, Aug 13, 2017.
  1. ATlam
    ATlam Member
    64
    57
    San jose
    Got the engine code P0401 Insufficient Air Flow again (replaced EGR valve few months ago with warranty) so I decided to clean the EGR pipe. It was a mess! previous owner probably didn't clean it. I have been holding it off but it was pretty easy to do.
    Also seems to help with engine vibrating at 5mph with low battery charge (as if engine couldn't get any air in) that everyone has problem with, keeping an eye out to see if that problem is really solved.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Good idea to inspect and clean(y).
    Now you have an idea of the whole circuits condition, which will be littered with carbon deposits :(.
    Next step would be to clean the intake manifold and egr valve and cooler.
    If you need help, let me know(y).
    SFO, Jayw13702, m.wynn and 1 other person like this.
  3. ATlam
    ATlam Member
    64
    57
    San jose
    Thanks for the offer Ray, I will keep it in mind. We tried cleaning through the hole of the intake manifold (lot of stuff there too...) but felt like taking it off is a bit more complicated than the pipe so we didn't mess with it too much.
    But yes, it was everywhere! Toyota replaced the EGR valve for me, but not the cooler. If the code doesn't disappear I'll work on the intake and cooler, thanks for the advice.
    Assuming EGR valve is replaced and working properly, would the carbon deposit come back?
    Raytheeagle likes this.
  4. Mendel Leisk
    42,302
    To replace the valve the service department must have had that pipe in their hands. Those guys were obviously "mailing it in". I would show those pics to the service manager.
    If he's not interested, time to talk to to Toyota.
    m.wynn and Raytheeagle like this.
  5. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    How many miles on your Prius?
  6. ATlam
    ATlam Member
    64
    57
    San jose
    I thought about that, but since the TSB called for a EGR valve replacement and not pipe cleaning, am i in the right for complaining?
    my car has 230k miles.
  7. Mendel Leisk
    42,302
    I'd vote yes. To just go in there, put a fresh valve in that carbon-clogged mess: completely unprofessional.
    m.wynn, ATlam and Raytheeagle like this.
  8. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Deposits wil return(and will for the life of the car as the exhaust gas has carbon in it). Replacing the valve will only get one component. You got a second component. But until all are cleaned or replaced, the same behavior you experienced can reccur.
    I pool my cleaning / replacement of the cooler with the spark plugs and engine coolant to reduce time soent in clean up or removing the windshield wiper cowling. But can be done off this cycle.
    Keep us posted (y).
    ATlam likes this.
  9. ATlam
    ATlam Member
    64
    57
    San jose
    I will come back tomorrow and have a talk with them :) because the code came back too, thanks for the idea.
  10. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    While it leaves the deposits there, there are also many occurrences where the dealer takes a "professional liberty" to do something and then the retort comes back as "why did you do that?". The right thing to do would be to advise the customer of the situation, replace the valve and suggest further work.
    But that didn't happen here:(.
    m.wynn and Mendel Leisk like this.
  11. Mendel Leisk
    42,302
    I think @Raytheeagle and his crew have a better grasp of what's happening than Toyota right now. Or maybe not...
    If the pipe is bad, the EGR cooler (other side of the replaced valve, upstream) will be pretty much solid carbon inside. The intake manifold too, that the pipe feeds in, should be pulled off and cleaned.
    While waiting to talk to the dealership, have a look at @NutzAboutBolts videos, pinned at top of maintenance sub-forum. In particular the EGR pipe cleaning, intake manifold cleaning, and EGR cooler cleaning.
  12. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Thanks for the vote of confidence, I think :cautious:.
    m.wynn likes this.
  13. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,788
    Bay Area
    Time for you to open a Mobile Bay Area Hybrid repair service. :ROFLMAO::ROFLMAO::ROFLMAO:
  14. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    If it were only that easy:cool:.
    I still have a day job which is slowly eating away at any discretionary time left :(.
    But wrenching on a car is a good way to channel energy(y).
  15. NutzAboutBolts
    1,756
    1,788
    Bay Area
    Maybe weekend Mechanic? :D
  16. NutzAboutBolts
    1,756
    1,788
    Bay Area
    btw, I ordered the OCC, I will film it once I get it.. hopefully it'll turn out good as I hope. lol
    RMB and Mendel Leisk like this.
  17. Mendel Leisk
    42,302
    That maybe doesn't read the way I intended. What I meant to say is that maybe Toyota is well aware of the problem, waiting on it to "go away"?
    bisco and Raytheeagle like this.
  18. bisco
    52,805
    it will, in 5 or 10 years. to be fair, it is 230k.
  19. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Everything has a life span. If you can extend it, why not?
    Congrats on 57k by the way(y).
  20. bisco
    52,805
    agreed, i just can't lay it at toyota's feet. at 100k, absolutely.
