Pics: EGR pipe at 230k miles
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ATlam, Aug 13, 2017.
  1. Mendel Leisk
    42,354
    Yeah @NutzAboutBolts had good results with maybe 10~15 minutes of cleaning, I believe with BraKleen, or similar. Maybe the video doesn't really represent the total effort, but didn't seem too hard.
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    It's easy once it's out;).
  3. JC91006
    16,936
    8,647
    Mendel.....Mendel....Mendel.....we need low mileage data LOL
    Or Ray can simply do his again when it reaches 10k miles
    m.wynn, Raytheeagle and Mendel Leisk like this.
  4. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Too late (already at 40 k miles on this cooler);).
    But maybe @Rebound would agree to do so soon(y).
    m.wynn likes this.
  5. Mendel Leisk
    42,354
    Could all this coking be coming from the PCV valve??
    I don't have my 12mm ratcheting box wrench, or an E8 socket yet. That's my excuse. :p
    m.wynn and Raytheeagle like this.
  6. ATlam
    ATlam Member
    66
    57
    San jose
    Update: this is the egr cooler condition. Listen to the pros in this forum and clean your egr people! No light is coming through, completely clogged.
  7. NeilPeart
    NeilPeart Hybrid & PiP Convert
    75
    69
    Bay Area, CA (USA)
    What's your mileage? The EGR cleaning sounds like it should be an official 100K interval maintenance item (full system including cooler, valve, pipe, intake manifold, PCV replacement, throttle body). Might as well clean the MAF sensor and replace engine/inverter coolant while you're there, and why not replace your spark plugs & clean injectors too.
    Mendel Leisk and Raytheeagle like this.
  8. ATlam
    ATlam Member
    66
    57
    San jose
    it has 230k on it. I have done all of this on the list :)
    kc410 and Raytheeagle like this.
  9. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Those are some good pictures of the dirty EGR coolers! Here's my wife holding up a cleaned EGR cooler for the newbies to compare against
    I did the following in order:
    1. soaked 4 times sealed in old brake fluid. Allowed to sit for a day. Rinsed with garden hose.
    2. Used @danlatu's copper wire and drill method
    3. soaked 4-5 times in diluted vinegar water + oxyclean. Sat for a day then lots of filling with water alternating between hot and cold (this helped). Vigorous shaking and emptying over utility sink.
    Having just bought the car when I cleaned the cooler I wanted it as clean as it would get. It was soaked and rinsed until few carbon flakes fell out.
