Pictures of a clogged fuel injector, Gen 2 Prius - Possible reasons
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SWprius08, Feb 16, 2015.
  1. insaner
    insaner Junior Member
    96
    Atlanta, GA and Huntsville, AL
    I put a tank of chevron in yesterday and she's already running better
  2. GodIsAmazing
    GodIsAmazing Junior Member
    -Chap[/QUOTE]
    You may want to disconnect the fuel rail from the engine and then disconnect from fuel, I tried to put injectors back in several times and kept getting a leak, disconnecting the rail and remove the outer support and then squeeze the cushion to disconnect, you have more play and they will go back in evenly, check out attached to another post step (-i )will give you a picture of what to disconnect
  3. goodMXguy
    goodMXguy Junior Member
    44
    Philadelphia
    @ChapmanF and @tommymommy, if you have that video, PLEASE share. I did 4 attempts yesterday,, but I think I busted the small O-rings on top (didn't know I had to use lubricant)....Yikes.
    My Email adress is [email protected]
    #23 goodMXguy, Mar 13, 2019
