Pictures of Body Side Moldings and Mud Flaps
Discussion in 'Prius v Accessories and Modifications' started by M8s, Nov 29, 2011.
  1. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    I tried to get decent pictures but it is difficult to see the mud flaps for some reason. [​IMG]
  2. M8s
    614
    113
    33
    Mud Flap Installation Directions
    Forgot to mention. I'm not the only guy whose mud flaps came without installation directions. Danny got me the directions very quickly and I've saved them on my computer. If yours come without installation directions, shoot me a PM with your email address and I'll send them to you.
  3. Mike James
    Mike James Camaros and Prii go figure
    142
    35
    Lincoln, NE
    Looks good, thanks for sharing. :)
  4. ldbman
    ldbman Junior Member
    MA
    Re: Mud Flap Installation Directions
    I am in the same boat. I appreciate your offer and am submitting men email address. Many thanks
    ldbman
  5. DragonflyDM
    DragonflyDM Junior Member
    53
    Pittsburgh
    The dealer suggests not getting molding or door edge protection because they “are areas of rust”… and feedback?
  6. M8s
    614
    113
    33
    I'm not one to ask as there is no snow where I live, hence no road salt. I've never heard of any Prius getting rust but someone who lives in the snow/rust belt would be a better source of info.
  7. Cactus Hybrid
    Cactus Hybrid Member
    129
    46
    Paradise Valley, Arizona
    I just got some also...thanks for the post.
      File size:
      130.3 KB
      1,343
      File size:
      87.2 KB
      1,127
  8. russcarver
    russcarver Junior Member
    91
    Erie, CO
    Where can I get the moldings and mud flaps?
    --Russ
  9. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    Russ, you can get them at the PriusChat.com Shop
    Click on "SHOP" link above or here: 2012 Toyota Prius v : PriusChat Shop
    I just ordered and received the moldings, but can't put them on yet because it's too cold and I have no garage.
  10. jas1178
    jas1178 Junior Member
    44
    St. Petersburg, FL
    How necessary are the mudflaps?
  11. russcarver
    91
    Erie, CO
    How warm does it have to be to put on the moldings?
    --Russ
  12. Boo
    5,051
    485
    97
    Flushing, NY
    The car metal is supposed to be at least 74 or 75 degrees, which you can accomplish with a heat source of some sort (heat gun, hair dryer, heater, etc.). But what I wonder about is IDEALLY how long should it be at such temps in order for the adhesive to set completely or substantially completely?
  13. MarathonMarty
    MarathonMarty Prii 4-timer
    38
    Spokane, WA
    2013 Prius v wagon
    I had mine professionally installed by a body shop about 3 weeks ago when the temps were in the 20s and low 30s. They kept the vehicle inside all morning to get it up to a good warm temperature and then did the installation. Cost me $50 for labor. They're holding in place perfectly. No sign of anything loosening up at all.
  14. M8s
    614
    113
    33
    In my world, having a clean car is a desperate necessity for a happy life but not everyone feels the same about that.
    I don't think mud flaps protect the body from rock chips much, but they do prevent the accmulation of tar, dirt and brake dust on the painted surfaces behind the wheels.
  15. Cactus Hybrid
    129
    46
    I put on the moldings myself. Just a heads up...on the set I purchased, the 3m tape was not one continuos piece. The last 2 inches was a separate piece. Be sure to peal off the tape backing before you begin the install. I found out the hard way.
  16. PearlJammer
    PearlJammer Member
    112
    23
    Georgia
    2018 Prius
    Do it yourself...its not brain surgery.:thumb:
  17. elcano
    elcano Junior Member
    31
    San Juan, PR
    Have you noticed any change in MPG after adding the mudguards? They should have some impact on the drag coefficient, even if minor.
  18. Cactus Hybrid
    129
    46
    I noticed an increase in MPG after installing my Mudguards, Side Moldings and Shark Fin Antenna......Maybe it has to do with the fact that I now drive more slowly past store front window's to check myself out. :thumb:
  19. MaxNut
    MaxNut New Member
    PA
    These are not the side moldings I have seen ... where did you get these?
