Piece of skid plate? Stamped AD-ZR?
Discussion in 'Gen 3 Prius Main Forum' started by JFrentzen-closed, Jun 22, 2012.
  1. JFrentzen-closed
    JFrentzen-closed Junior Member
    43
    Pulled in the driveway yesterday and when I got out of the car and walked behind it, I found a piece of skid plate laying on the apron to my driveway? Thinking it came off my car as I didn't notice it when pulling in. It's stamped AD-ZR? It's black, filthy, and looks like it attached with a few screws and maybe some push rivots? About a 1 ft x 1 ft piece of black plastic.
    Any ideas?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Sounds like the oil-change door of your under-engine cover. Take a peak under the engine area.
  3. markabele
    5,084
    1,782
    Nebraska
    Find anything out about it? Updates please. :)
  4. Beauregard
    Beauregard Member
    89
    25
    Colorado
    2015 Prius c
    It's more than likely the plastic door that is used to change the oil and filter. It has a flimsy plastic molded in hinge that breaks after one or two oil changes leaving it dangling by the push in rivets.
    I, like you, was very lucky the thing fell off in my driveway instead of the road somewhere.
    I fixed mine by using some very heavy duty black duct tape (Gorilla Tape) and getting some new push in rivets.
  5. JFrentzen-closed
    43
    My apologies for the delayed response, and thank you for the feedback on this one... I think Spiderman nailed it. I've attached a shot of the piece that fell off. Not in a huge rush to attach it again, as I may be looking at an aftermarket skid-plate.
    Now that you're able to see the part in question, is this indeed what it is? The oil plate cover.
  6. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    When under the car can you see the oil filter?
  7. Paul Richardson
    Paul Richardson New Member
    Seattle
    Has anyone found an aftermarket replacement for this?
  8. NavyLCDR
    NavyLCDR Active Member
    188
    120
    Stanwood, WA
    Former Member 68813 likes this.
