PiP A/C Guide
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PiPLosAngeles, May 13, 2013.
  1. 3PriusMike
    3,101
    2,420
    Silicon Valley
    Actually, the most efficient, IMO, is to lower the windows to exhaust all the hot air. But "auto" is not going to do this for you. :)
    Mike
  2. El Dobro
    El Dobro A Member
    7,101
    3,279
    You wouldn't want the system doing that when it's pouring rain outside. ;)
  3. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    The problem with that is that there is no logic to it. Federal regulations require that even when all vents are off and closed that the interior of a car remain ventilated with outside air, albeit not to the extent as with the vents pulling in outside air (without outside air CO2 levels with 4 passengers in the 94 cubic-foot Prius would reach the point of being fatal in less than 45 minutes). That means the pollution is entering the car for as long as you're driving it, even if the ventilation system is set to recirculate. If you set the ventilation to draw outside air you're creating positive pressure in the cabin. The passive ventilation and every small air leak will no longer be drawing outside air, but will instead be exhausting the cabin air. If you filter the outside air being drawn into the ventilation system you're creating an envelope of positive pressure which will prevent the infiltration of unfiltered air.
  4. PiPLosAngeles
    1,551
    724
    Not if you live anywhere were the sun shines on your car. The interior of a car parked in the Sun can reach 150°F. Surely it's more efficient to cool outside air and push it into the cabin than to try and cool 150°F air.
  5. El Dobro
    El Dobro A Member
    7,101
    3,279
    It may or may not be more efficient, depending on your weather conditions, but the system is programmed to do this.
  6. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    I'm comforted to see others are perplexed by the PiP's HVAC system. After reading other's comments and trying various combinations I decided to try using Auto mode. In the past week I've driven in temperatures ranging from 42° - 100° F, and I'm starting to trust using Auto. It's actually interesting to embrace the system, trusting that Toyota engineers have put many hours into automating the many possible combinations of air flow.
    Now I have no idea if there is any real depth to the HVAC's logic, but I'm willing to keep testing to see what happens. I have observed the settings change from recalculate to fresh, lower to upper vent, and fan speed 4 to 1, all during my 20 minute morning commute. Observations continue...
    markabele likes this.
  7. El Dobro
    El Dobro A Member
    7,101
    3,279
    It's all in the owner's manual.
  8. JimPHL
    JimPHL Member
    74
    33
    Cinnaminson, NJ
    OMG, I just realized why Prius drivers cannot smell their own farts!
    Tracksyde, thanks for clearing the air :)
    Tracksyde likes this.
  9. DLee
    DLee Junior Member
    81
    High carbon dioxide levels are seldom fatal, but it is a surrogate indication of poor ventilation. The occupants would likely die from lack of oxygen if they were in a sealed compartment.
  10. DLee
    DLee Junior Member
    81
    What about the dashboard air vents. Most like to point them right at their face and body. I find the car most comfortable with the air vents directing cold air along the inside surface of the top and side windows. This provides a more uniform temperature throughout the interior. The only problem is that air directed toward the ceiling interferes with the hands free microphone, so I have to turn the fan to slow when talking.
  11. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Im surprised at the dissatisfaction with the PiP's automatic climate control .
    It works perfectly in AUTO for me. I leave it there all the time. I have it set for 72deg. in the summer and 68deg. in the winter.
    If I desire a higher fan speed or cooler temp, i simply reduce the temp setting a few degrees. If I desire a lower fan speed or warmer temp, I simply increase the temp setting a degree or two.
    The only occassion that will require a deviation from this is a fogged winshield, then I select the front windshiled defog/defrost button. Then switch back to auto when defogging is no longer necessary.
    It a great system in AUTO.
    The key is using the temp adjustment.
    And the switch setup is quite intuitive. The temp control and AUTO buttons are all placed together on the left side of the control panel all within a simple single fingers reach.
    AUTO, warmer, colder, how simple is that? with occasional defog.
    Chazz8, DLee, ryogajyc and 1 other person like this.
  12. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    I have to agree, until a week or so ago, I would use the fan speed button to turn the HVAC on, and manually adjust everything, but I gave AUTO another chance, and now I'm doing what 9G-man described above, and it actually works out pretty well. There have been days where I needed heat in the morning, only needed to drop the temp a little, while on my way home, I needed A/C, so I just needed to bump the # back up.
    Just need to get used to seeing the A/C light on all the time, even when heat is running, that's all.
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Put me into the "Auto User" group. I generally only use it when my girlfriend is in the car but it works great. In fact she loves riding in my car because of the AC. The quality of air is better than in her 2013 Acura RDX. :)
  14. PiPLosAngeles
    1,551
    724
    Dissatisfaction is bound to happen in any system that gives the operator a set of controls and then proceeds to override their inputs to those controls. I do not like AUTO because I am trying to squeeze every inch out of a charge that I can. I'm up to 20.6 miles range when I start the car in the morning, but that incessant need for the A/C system to ignore my settings is irritating.
  15. PiPLosAngeles
    1,551
    724
    In an enclosed space a person will die of CO2 poisoning long before they deplete the oxygen supply. That's why space capsules carry lithium hydroxide, it captures the CO2 out of the cabin. You can breathe a small fixed amount of air for a long time if the CO2 is removed.
  16. El Dobro
    El Dobro A Member
    7,101
    3,279
    Drove down to Va from NJ with Auto on for a little more than half the trip and got almost 56 mpg pencil & paper. My speeds were from 65 to 72mph.
  17. CharlesH
    2,798
    1,166
    Roseville, CA
    While we continue to drift off topic, I would like to add that CO2 was the big concern on Apollo 13, where they had to fit together incompatibly shaped LiOH canisters with duct tape.
  18. DLee
    DLee Junior Member
    81
    OK< I take back my comment, and agree carbon dioxide poisoning will take place before the oxygen is depleted.
