PIP-A versus Jaguar XJ starting in blizzard
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by cheallen, Jan 11, 2014.
  1. cheallen
    cheallen Junior Member
    Williamsville, NY
    I had an interesting conversation at dinner last night with the owner of a new Jaguar XJ, I drive a 2012 PIP-A. During the recent 3 day blizzard in Buffalo (morning temps below zero and single digit highs, 40 mph sustained winds, blowing and drifting snow, etc.) my PIP started perfectly and had no problems while on day 3 of the blizzard the Jaguar would not start and spent a full day at the dealer being repaired.
    The two of us (average age 83) live in the same retirement complex in similar houses and use our cars in very similar ways. Most of our trips are about 1/4 mile long - to the dining room, mailbox, meeting rooms, etc. with "long" 2 mile trips to the grocery store several times a week. Then, once a month or so we take long trips to visit grandchildren, etc., but not in the time period discussed here.
    It turns out that the problem with pussy cat (as the Jag is known) was not the battery but that the exhaust system was completely blocked with ice such that the back pressure was too high for the car to start. After the dealer removed long cylinders of solid ice from the exhaust pipes, the car started fine. So the question is what should the owner do to prevent this in the future. Moving to Florida or buying a Prius are not under consideration. His suggestion is to run the car for at least 20 minutes on every trip regardless of how long the trip is, to let it warm up. This should do wonders for his gas mileage!
    Our PIP does not have this problem because we used it in EV mode through the entire blizzard. Maybe I'll just offer him a ride when pussy cat is indisposed.
    usbseawolf2000 likes this.
    52,863
    i wonder if she was parked with the tailpipe facing the prevailing wind?
  3. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    Foam exhaust plug when parked in a blizzard.
  4. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    I would think a 20 minute drive once a week would keep the ice from building up in his exhaust here in tropical WNY
  5. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    Combustion condensation which would collect throughout the exhaust system after a number of very short drives as described, due to not completely warming the engine and drying exhaust system. EV is the way to go!
  6. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    Drill a small (<1mm) hole in the exhaust at the lowest point to let the condensed water from the combustion products drain away before they freeze.
  7. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Visit grandchildren more often?
    Simtronic and markabele like this.
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Drive 20 mins before the snow storm.
  9. SLOW_RR
    SLOW_RR Member
    155
    84
    Finger Lakes Region of NYS
    Quarter mile.... Walk over for dinner. You'll both have a better appetite....:whistle: Call a taxi? Car pool? Buy a Tesla.... At the next Inmate/Resident meeting have them get a bus that will go around and pick up/deliver residents from their houses to the dining room for meals....;) ;)
  10. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Jaguars are emong the least reliable non-Italian cars - always have been - while most Japanese cars are excellent at cold weather starts. It's hard to say how much of the ice was from condensation of exhaust water vapor and how much was 'blown in' snow that melted and refroze. The first step is to protect the exhaust from snow, and then see how much improvment there is. As for your PIP, you could try a loose-fitting exhaust pipe cap, but even that could freeze in place if you forget to remove it and cause real problems, so I'd just park facing away from lake effect winds as much as possible.
