PiP at -40 (F/C)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by iRun26.2, Jan 5, 2012.
  1. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    No wonder there are 35 Million people in California...
  2. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    I think it is resonable to assume that the charger cord that comes with the PiP can withstand the cold without cracking. If it does have problems I would expect it to be covered by Toyota.
  3. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    One of the very reasons I left CA! :)
  4. Roadburner440
    Roadburner440 Member
    316
    59
    Hampton, VA
    I guess maybe I have just been lucky in all my situations. Being deployed to the North Atlantic with a helicopter quite extensively I am used to all kinds of exterior parts getting ice. The physical external power connector (slightly bigger than the SAE spec plug, but similar in how it plugs in and all) itself would not freeze, but the cord would always ice up. So you could unplug the aircraft, but obviously not wrap up the cord. Just had to drag it in the hangar and let it thaw out when it went flying. Not to mention I was the unlucky soul at the time that had to go out every half hour and rinse the bird with fresh water to knock the salt off from the waves even though it was way below freezing out there which is why I was saying unless you are spraying it with water I don't think it would freeze. Cause that is what I attributed all the ice on rotor blades and stuff from was the sea spray, and me and the other junior guys rinsing it off every half hour to keep the corrosion down. I guess with the car it could be different. Honestly I hope to never find out for myself. The new house I am at now doesn't have a garage so I am charging outside. Although on the upside where I used to live did not want me to install an L2 charger. So I will take the L2 charger over a garage anyday. The L2 makes a huge difference.
  5. daniel
    14,487
    1,519
    Spokane, WA
    I didn't know the PiP came with anything but an L1 charger cord. I thought people who wanted L2 had to buy one from another company. Since I presume that cords rated to extreme temperatures would cost more, I thought there would be a choice, depending on expected use. Why buy a -40 cord if you live in CA and always charge in your garage?
  6. iRun26.2
    824
    169
    United States
    I'm sorry for the confusion. I was referring to the L1 charge cable that comes with the PiP. Since they didn't specify it as an 'indoor' cord (nor was there any optional 'outdoor' cord offered as an accessory) I will assume that what I get with my PiP should be good for all outdoor conditions of use.
  7. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Sorry but your facts are a bit off. Having lived most of my life on the north-east I too assumed CO was cold with more snow.
    Average temps in Colorado springs are higher than boston and most other places in the north east that are not directly on the water. And amount of precipitation is even lower. We may get a good storm or two but I'll take the warmer temps and 300 days of sunshine to the gray and cold any day.
    Compare
    Average Weather for Worcester, MA - Temperature and Precipitation
    Average Weather for Colorado Springs, CO - Temperature and Precipitation
    My Volt does very well here, though at 25F or colder the engine does run a a few times to keep the engine (and cabin) warm. Even with that and a few longer trips, I'm at 260+Mpg (~88 MPGe) in the last 90 days.
    Like others here I'm sure the PiP will what is needed to protect the battery. Hopefully it will only be about the battery and they will leave "comfort" control up to the driver not just the temp. I hate the ICE running for a quick trip to the grocery or home depot (4-5 miles).
  8. Trollbait
    12,832
    Does the PiP have another way to warm the battery, or does it rely on just cabin heat?
  9. iRun26.2
    824
    169
    United States
    I agree that Toyota certainly designed the system to protect the battery from operation at cold temperatures. However, if operation of the vehicle at extreme temperatures risks reducing the battery capacity (when it warms up in the summer) even a little bit, I would like to know about it. I will be very protective of my new car.
    I also hope we can choose to use the car without using the ICE for short trips when it is moderately cold outside (10F for example). When I drive to and from work, my 20+ mile commute will require me to use the ICE so I might as well generate some heat. When I am at home on the weekends (and my car starts out at my garage's temperature), I will want to take short trips where I won't need heat (and I'd prefer to not burn any gas). I hope the car doesn't override my EV mode selection unless it needs to generate heat to safely use the battery.
    If I get less range from the battery at very cold temperatures, that is fine (I may choose to be cold sometimes). If the long term health / range of my battery is at risk (even a little bit), then I want my car burn gas.
  10. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    Well call me crazy, but a PDF I downloaded a while back said Remote Air Conditioning System. Now on the web site they just say Remote Climate and it will use the grid electricity if plugged in. Perhaps they have a limited method of heating up the cabin for up to 10 minutes.
  11. Tideland Prius
    16,683
    I'd use the same warm-up techniques as the Prius Liftback since it's going to operate like one at those temps. That is to say, plug in the EBH, let the car idle for a minute (so don't charge the HV battery to full) and/or slowly drive (below 35-40km/h) to minimise battery draw and of course block the grille!
  12. iRun26.2
    824
    169
    United States
    Is anyone really going to block the grill of their new PiP?!
  13. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
  14. gwmort
    gwmort Active Member
    985
    211
    Delaware
    I had my first post-snow unplugging experience yesterday. The plug wasn't frozen into the car (much), but there was a lot of ice/snow mess in the socket area that interfered with the closing of the hatch or latching mechanism. This snow was pretty mild, even for Delaware, but I really think I need to come up with some sort of cover for the whole thing.
  15. Tideland Prius
    16,683
    Why not? Don't underestimate the members on PC :D
  16. iRun26.2
    824
    169
    United States
    I expect to become one of them...
  17. Tideland Prius
    16,683
    one of us.. one of us...:ph34r:
