PiP 'burns' EV range in HV mode (not regen)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PiPLosAngeles, Dec 22, 2013.
  1. CharlesH
    2,798
    1,166
    Roseville, CA
    As I understand it, if the traction battery in the Prius (plug-in or standard) gets depleted below that magic threshold, like can happen when driving when out of gasoline, that it takes special (expensive) charging equipment to resuscitate it.
    52,891
    that didn't happen to me when i ran out of gas in my gen II, so i wonder if there is protection built in. i believe the car quit and the dashboard lit up when i hit 2 purple bars.
    52,891
    good point on the time of use benefit, but i'm pretty sure the manual states to "finish charging just before using when possible." so there must be a benefit to that as well.
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    No interpretation necessary. We've known since before rollout. They said it was for BOTH.
    Cold soak (rest time before recharging) helps with longevity.
    So, it's a win-win to wait.
  5. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Worst thingfor longevity is to leave it sit for hours fully charged in direct sun of a hot day.
    markabele likes this.
  6. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    Hi Everyone,
    This is a great conversation and thanks to all to for this discussion. I am looking for the info regarding the length of time I leave my PiP fully charged, what page in manual? My habit is as follows; get home at midnight and plug in and leave it charged until I leave at 1 pm the next day which is about 10 hours of sitting in the fully charged state. I then charge at work and it sits for about 2 hours in fully charged state. Is the 10 hours too long to sit and will it reduce my battery life? Do I need to make a change?
  7. bisco
    52,891
    too long. your best bet is to learn how to use the charger.(y)
  8. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    Is the 10 hour limit mentioned in the manual? I remember Toyota's admonition not to leave the car fully charged on a hot day. If ten hours is too long to sit, even in winter temperatures, is it then advisable to "drive off" some of the full charge before the ten hour sit so the battery is no longer fully charged? If so, drop it just 2-3 miles maybe? Is a fully charged battery sitting at 25-30 degrees for hours in the same predicament as the same sitting in the summer sun?
    The daily commute during the week is easy to plan in order to have the battery full just minutes before your regular departure time. It is the weekend that's difficult to plan for. There's no guarantee you will use the car Saturday morning after the usual early morning charge you're in the habit of doing during the week. Same goes for Sunday. Our weekend trips are often spontaneous, and I'd like to have a full charge in place and waiting to go. Perhaps the solution is to not charge at all for the weekend, only for the weekly commute, but this tends to defeat the purpose of having a plug-in.
  9. john1701a
    12,840
    5,312
    58
    Keep in mind that "fully charged" is actually only 85%.
    So when consulting with generalized information about lithium batteries, it doesn't apply directly to the plug-in Prius.
    Nonetheless, there is still reason to avoid leaving the battery-pack in a "full" state for an extended amount of time.
  10. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    I always charge as soon as I get home, if I don't use the car until the next morning so what, that's why I lease!
  11. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    Thanks john1701a. I guess that until I have several years of battery experience under my belt and can feel easier about how to treat it, I'll always wonder just how long "an extended amount of time" is. I'd like to think it's measured in days and not in hours.:confused:
  12. john1701a
    12,840
    5,312
    58
    That amount becomes obvious when you get in your Prius, after it having sat in temperatures over 100°F baking for a few hours.
    It doesn't take any special knowledge or equipment to determine room temperature is clearly not as hard on the battery-pack.
  13. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    That's a relief to hear. Thanks. I'll conclude then that as it sits at present in my 25 degree garage fully charged for the rest of the weekend it is nothing about which to be concerned. In this region of the country, as in yours, we'll have to wait quite a few months before hot, sunny days are a concern.:LOL:
  14. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    At 25 degrees you could leave your PiP plugged in indefintely. Cold weather really doesn't do anything bad to a battery.
  15. bisco
    52,891
    i have the same problem on weekends. so, i got an L2 charger. i charge it for an hour, and when i find out i have to leave, it's only a half hour to fill up. and if i have to leave right away, at least i have 8 or 10 miles.
  16. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Am I the only person on the planet who doesn't drive on a schedule? When I arrive home from work I plug in because I don't know if I'm going to have to do a diaper run, get a call to go out for some coffee with old friends, or who knows what. The PiP, like any good electrical tool, should be charged and ready when I need it.
    We need to be mindful of our goals here. Is our goal to have a PiP with the longest lasting battery? If so, just keep the battery half charged and leave the car in HV mode all the time. Your battery will last for decades. If the goal is to get the most EV miles out of a battery, then you've got to charge whenever you can so the EV miles are available at every opportunity.
    Just to put it in everyday terms: If I plug in my PiP every evening when I get home from work so it's ready to go on an errand later, the odds are that it will sit until the morning. Let's say only one day a week do I actually need that charge in the evening. 52 weeks a year will give me 520 - 750 EV miles that I would have missed if I diligently refrained from charging until three hours before my morning commute. At my current 20,000 miles per year, I'd get about 2,600 - 3,750 additional EV miles out of the battery pack before it went out of warranty by plugging it in immediately. How much damage would I have to be doing to the battery to lose so much capacity that the net balance was less EV miles driven? The answer is I would have to kill about 30 percentage points more of my battery's capacity over the course of 5 years. I doubt the effect is that strong. Temperature is a much stronger influence over battery life. Don't park in the sun if you can help it.
    Astolat and Lourun like this.
  17. bisco
    52,891
    that's the great thing about the pip, we don't have to follow the rules to enjoy a great vehicle!(y)
  18. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Yup, efficient with either fuel.
  19. Astolat
    Astolat Member
    229
    73
    Guildford UK
    I have to say that, though I appreciate all the advice given by the really knowledgeable people here, and can (just about) follow the logic, I am also convinced by the random scheduling argument. Fortunately we rarely get what you would consider extremes of weather over here, and on the rare occasions we get periods of unbroken hot summer sunshine forecast I might be a bit more careful, but otherwise the unexpected journeys I make in the evening are almost always ones that I can do most or all EV if charged, so it has to be worthwhile - especially since it only takes me 90 minutes for a full charge anyway.
    Edited to add: I am pleased to say that I'm way past the stage of having to do a nappy (diaper) run for my children. I suspect, however, that I may be doing them for my grandchildren within the lifetime of this car...
  20. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    Back to the PiP "burning" EV range in HV mode, I noticed something that I wanted to ask about. I have a relatively short drive to the freeway in the morning, and where I get on I can get up to 65 for a while before hitting traffic.
    At first, I would run EV mode until on the freeway ramp, then switch to HV mode. However, I would notice that with the gas engine running, my EV range would go down quite quickly for 1 or 2 miles on the "range". Is this because the car is still using EV while the gas engine heats up, or just recalculating the range based on my speed? I started just turning on HV in my driveway in the morning to allow the engine to heat up before getting to the freeway, and no longer notice the drain when getting on the freeway with a warmed up engine.
