PiP 'burns' EV range in HV mode (not regen)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PiPLosAngeles, Dec 22, 2013.
  1. bisco
    52,899
    using ev while ice warms. switch to hv as many minutes before you need it as it takes to warm up.
    PriusC_Commuter likes this.
  2. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    I've noticed the same apparent "drain" of EV miles once I'm on the highway but maybe 5-8 miles later the EV range I had as I switched from EV to HV on the ramp is fully returned. I've assumed that the hybrid mode intelligently uses all available energy when it first kicks on. I'm always in ECO mode so I don't know if that plays a part.
  3. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    If you get an aftermarket gauge, you'll be see that RPM is held to 1500 during warm-up. That's done to help reduce emissions. It's achieved by drawing from the battery-pack at a higher rate than in HV mode, hence EV range being burned during that time.
    We call that EV-BOOST, since you aren't really in HV mode yet. It automatically switches over once warm-up is complete, then works to restore the electricity it consumed during that time.
  4. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    That's good to know, thanks! Pretty darn clever.
