PIP charge timer memory setting
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mlgooden74, Apr 25, 2012.
  1. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    I had previously replied to this and said:
    Well, last night I did the same thing, and came out to a car with no EV miles on it and a big ol' "Charging Interrupted" message on the MID this morning. Hubris, it'll get you every time.
    Unfortunately, I can't remember the exact sequence of events. I think it might have had something to do with me plugging in the car end first, then the EVSE into the wall socket, and then setting the timer.
    I may have to do some experimentation this weekend...
  2. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    I have been hitting the "timer" button before shutting off the car, then connect the EVSE, has worked every night this week correctly.
  3. mlgooden74
    mlgooden74 New Member
    24
    So-Cal
    Well since I started this thread I might as well throw in my two cents on what has worked for me.....
    1. turn off vehicle
    2. press charge timer button and hold to activate timer
    3. get out and close driver door
    4. look thru driver window to make sure clock is blinking - it is!
    5. walk around back (or front) of car and plug in charge cable
    6. listen for car to make beeping and whirring sounds
    7. check entune app before bed to make sure charge time is set - it is!
    Seems like alot of steps but goes pretty quick. Paranoia of things NOT happening is a bitch though..........I'll give you that!
    :rolleyes:
  4. Jozo
    Jozo PIP PIP HOORAY!
    145
    27
    Sacramento
    Same process that I use EXCEPT I wait a second to hear the L2 charger click on and then wait another second to hear the L2 charger click off as soon as it 'realizes' it's on a timer.
  5. COIllini1
    COIllini1 Junior Member
    34
    Colorado
    Is this feature/app available with the base model?
  6. CharlesH
    2,797
    1,164
    Roseville, CA
    Nope. Charging app depends on the built-in SafetyConnect cell phone that is only in the Advanced.
  7. Arthur1
    Arthur1 New Member
    Seattle
    My Prius plugin will no longer charge up to 12.9 it now charges to 11.3, is this normal?
  8. Sandiegomom
    Sandiegomom New Member
    109
    28
    San Diego
    Glad I'm not crazy. :) Thanks for the chuckle!
  9. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Yes. The EV Miles value updates based on past driving history and the estimate will also drop when the fan is on.
  10. mwbprius
    mwbprius Junior Member
    22
    Connecticut
    Mine seems much more simple. I have my timer set to turn on at 5:00 AM. When I want to charge the car I do the following:
    1. Open the driver door and reach in and press the timer button. It displays the timer start time: 5:00 AM
    2. Close the drivers door, walk around and plug in the cable.
    Works every time, very simple.
  11. longterm
    longterm Member
    152
    Nashville, TN
    I totally agree on that.
    Not only should there be more than one timer start/stop setting, but I would prefer that you have to press when you do NOT want to use the timer settings.
    The worst offense, in my opinion, is that the charger port is on the back left of the car, which is as far as it can physically be from the driver. In my garage I now have to walk around to the back side, unplug the cable, then get in; in 2 weeks I've already forgotten 2 or 3 times, which means exiting the car and unplugging the cable.
    They should've left the charge port near the driver's door as it was on the prototype.
  12. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    I feel your (and most owners') pain and you're quite correct.
    If it makes you feel any better (and I'm sure it doesn't), my charge port parks about two feet from a dedicated 15 amp outlet that I put in four years ago, as an afterthought, next to the inverter for the solar system that was being installed.
  13. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    Hi everyone,
    I am 6 years late to this chat : but did anyone recently tried using a smart switch? Something like a WeMo switch? It supports 15 Amps, 120V
    Wall socket <=> smart switch <=> PiP charger => PiP
  14. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    I briefly tried a "smart plug" and have two concerns. First, the car charger's amperage/wattage is very close to the smart plug's rated maximum. I could live with that, but my other concern is that the power should always be connected and disconnected from the charging port on the car. Using a smart plug would be like yanking the plug from the wall outlet or jamming it in while the car is connected. Either way would usually create a visible spark at the outlet and a surge passing into the car. With the smart outlet you won't actually see the spark, but the surge is still there.
    jerrymildred likes this.
  15. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    No, that would not be the case.
    Let me explain my plan :)
    1. Connect 12 gauge extension cord to the smart plug.
    2. Plug in the PiP charger in the smart plug - and don't fiddle with that setup again - since home garage is the only place I charge my PiP
    3. Since Smart plug controls the flow of energy - and is controlled over wifi : On/Off/Scheduling happens without touching anything.
    4. For anytime I need a charge
      1. I drive in the garage
      2. Unhang the PiP charger from wall mount & plug in the PiP
      3. Let the Smart plug do it's scheduling
    5. For anytime I need to use the car
      1. Walk in the garage
      2. Unplug the charger and hang it back on the wall mount
      3. Drive away
    What do you think :)
    Thanks!
  16. Pluggo
    608
    534
    Strictly speaking, Toyota wants power going to the charger before you plug into the car. They want the car unplugged when the charger powers up. I would just remove the smart plug from your plan and use the plug for something else. If your electric company offers a discount during overnight hours you may decide to deal with the inconvenience of returning to the garage to plug-in. Otherwise, just enjoy your Prius and drive safely.
