PiP charger or Prime charger
Discussion in 'Prime Main Forum (2017-2022)' started by jfschultz, Jul 17, 2019.
  1. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    In a few weeks my new 2020 Prime should arrive and I'll be trading in a 2004 Prius. So I will have both a 2013 Plug-in Prius and a 2020 Prime. Is there a particular reason to use one charging cable over the other? I will probably drive the Plug-in Prius once a week to keep it healthy and happy for my wife's occasional use.
    (Lesson learned: There have been a number of times I needed to crawl through the back to open the rear hatch to connect a charger to the auxiliary battery on the 2004 Prius.)
    Arctic_White likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Congrats on the new car!! The cables should both work the same even though they have some minor differences. (BTW, re: the thread title -- the chargers are in the cars.)
    A few considerations:
    • I've read that there is a limit on the number of times the EVSE cable can be used. It's a big number, though. Don't know if you want to preserve the new by using the old primarily or not. I wouldn't obsess over it.
    • The manual advises against letting the car set for "long" (whatever that means) periods with a full traction battery.
    • There's no need to open the hatch to charge the aux battery. There are connection points under the hood.
    Enjoy the new ride. I also upgraded from a 2013 PiP back in March. I think you'll be very impressed at the improvements, and hopefully not too annoyed by the occasional "Why'd they do that?" features. (y)
  3. jfschultz
    639
    115
    Germantown, TN
    2020 Prius Prime
    Being extra cautious with all the complex electronics, I make it a practice to pull the ground cable when charging.
  4. schja01
    schja01 Senior Member
    1,820
    1,207
    Chicagoland
    2024 Prius
    Limited AWD-e
    So removing and reattaching the battery ground is less disruptive to the electronics than attaching the leads of turned off charger and then turning the charger on?
    Arctic_White and jerrymildred like this.
  5. bisco
    51,142
    prime evse has an 8 amp option, if you have a bad circuit, or maybe it is part of the in car charger.
  6. jerrymildred
    11,517
    14,137
    Tampa, FL
    More like hyper cautious. :D
    That's a function of the car, not the EVSE.
