PIP Charging Cable
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Johnny C, Jan 4, 2013.
  1. Yes, hook or something similiar
    26 vote(s)
    65.0%
  2. No, just hang from outlet.
    14 vote(s)
    35.0%
  1. Johnny C
    Johnny C Member
    162
    16
    Boston
    Finally got my PIP from the dealer today. I found out that Toyota does not recommend letting the charging cable hang from the outlet. Instead, it should be hooked onto something. What kind of hook is everyone using? Pictures would be great.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Sometimes I use a 24 inch extension cord. or the set up in the pic. shown here:D S1190001.JPG
    Tracksyde, rogerv and DadofHedgehog like this.
  3. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Small #8 ell hook put into wall just below the outlet.
    Mike
  4. lensovet
    2,615
    496
    Burlington, NJ
    oh my god that looks scary…
    anyway, when i charge at home, the outlet is in the laundry room, and next to the washing machine, so the brick rests on the washing machine. when i plug somewhere outside, i do try to make sure that the brick rests on something, even if it means contorting the charge cable weirdly when it comes out of the outlet.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    it DOES doesn't it. I don't have that setup all the time and I come outside frequently to check on it when I do use that setup.:D
  6. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    The charging cable's brick has a hole in one corner. Loop a Ziptie or a wire loop through it and then you can hang the heavy brick from whatever is handy nearby.
  7. El Dobro
    El Dobro A Member
    7,102
    3,281
    There's no catagory for my situation, which is uses an extension cord to reach the car, so PIP cable is always on the ground. :D
  8. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    I'm plugging in right next to my workbench, so I hang the brick on the pegboard.
  9. If, I must charge outside using a extension, the I put a small piece of rug over the junction at the eXtension plug, in the rain.
  10. lensovet
    2,615
    496
    Burlington, NJ
    Isn't that like an electrical fire waiting to happen?
  11. El Dobro
    El Dobro A Member
    7,102
    3,281
    If the brick is outside, like at work, I unplug the extension first. I've never covered the brick.
  12. More like a lightning bolt hitting me.
  13. Johnny C
    Johnny C Member
    162
    16
    Boston
    Wow, that looks complex. Probably is a OSHA hazard. LOL
  14. Johnny C
    Johnny C Member
    162
    16
    Boston
    That's what I did... for now. I might just install a hook like Mike.
  15. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    I changed the Plug of my Cable to a Right-Angle Plug, so the weight of the brick doesn't pull the plug out.
  16. Johnny C
    Johnny C Member
    162
    16
    Boston
    Where did you get the 90 degree plug or are you using an adapter?
  17. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I use a rubber-coated hook designed for hanging bikes from the garage rafters or ceiling. One of the larger ones holds the coiled cable and the connector just fine. I used to have photos on here, but can't seem to find them now.
    Maybe this link will work?
  18. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    At work I use a small stretch bungee looped to itself, that then hangs of the outlet in the underground garage I park at, I'll update with a picture
    delrey likes this.
  19. Johnny C
    Johnny C Member
    162
    16
    Boston
    That sounds like a novel idea. I am going to install a hook, but I like the concept of a bungee cord. Where did you get the bungee?
  20. mitch672
    1,077
    198
    Randolph, MA
    Came on a giant pack of them at Costco or BJs, can't remember I've had them so long
