PIP display screen auto off?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Marcus T, Nov 19, 2012.
  1. Marcus T
    Marcus T Junior Member
    86
    Northern NJ
    In the 2010 Gen 3 the Nav/Audio screen would automatically turn off after a few minutes. Is there any way to have this same setting in the PiP?
  2. Adam Leibovitch
    498
    102
    I manually turn it off, once you know where the buttons are going to pop up on the screen you can do it pretty fast. Settings-display-screen off
  3. Just push car button.
  4. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    so is the idea behind this that it saves charge?
  5. Marcus T
    86
    Northern NJ
    Doesn't save anything. Just that once I've selected the music I want to hear, nice to have a blank screen. 2010 Gen 3 turns display off after about 30 secs if not pressed. Got used to it and wondered if PIP could do same thing. Settings-Display-screen off is the manual way to do it. Automatically would be much nicer.
    Adam Leibovitch likes this.
  6. bisco
    52,848
    no idea, have you checked settings?
  7. Marcus T
    86
    Northern NJ
    Yes, all you can do is manually turn it off from what I can find.
  8. So you would rather have a blank screen than to look at consumption? Put a piece of cardboard in front of screen, for peace of mind.
  9. Marcus T
    86
    Northern NJ
    Easier to just press Settings-Display-screen off. If I care about consumption I press Car. Usually just constantly glance down to see what song is playing. If screen is blank no temptation to look at anything except the road ahead!
  10. Marcus T
    86
    Northern NJ
    It's the default setting on the 2010 Gen 3. Got used to it.
  11. lensovet
    2,615
    496
    Burlington, NJ
    so you're saying if you do this once, the car won't remember that you turned off the screen and will keep it on next time you press any of the buttons? that's odd.
  12. Marcus T
    86
    Northern NJ
    It was called Setup, General, Auto Screen Change in 2010. Can't find anything like this in PIP setup. PIP Nav with Entune is very different from Gen 3 Model III with Nav.
  13. lensovet
    2,615
    496
    Burlington, NJ
    minor correction: *any* car with Entune is very different from Gen 3 with Nav. The liftback Priuses being sold today have the same Entune system and are similarly different from your 2010 Prius.
  14. Marcus T
    86
    Northern NJ
    I realize that now. Not a big deal as I can just manually turn off the display. Auto off was better but just a few screen presses and same effect achieved. It only did it in audio mode. Once you picked the source, in less than a minute the screen would go blank so as not to be a distraction. Pressing Audio would bring it back again and then it would go auto off again when time was up.
