PIP does not charge the plug in battery while driving
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by benalexe, Sep 22, 2012.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    EV
    52,677
    by slow and careful driving on flat roads, i have managed to bring battery charge down 5-6 miles while in hv. i t doesn't like that and eventually, the ice kicks on and recharges 3-4 miles of ev, sometimes while sitting at a light.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    The battery will be a "buffer" while the ICE is warming up. If the car isn't moving, the excess energy will go into the battery. The opposite is true if you accelerate hard (during ICE warm-up), the battery power will be used to minimize emission from ICE. The computer will soon recharge it and return to the target SOC.
  4. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    My 2004 Prius could be force charged by pressing hard on the brake and pressing hard on the accelerator at the same time. Can the same be done on the Plugin?
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    oooooh.......daja vue
  6. Try it
  7. Let us know what happens.
  8. CharlesH
    2,798
    1,166
    Roseville, CA
    As I understand it, a software update removed that behavior on all Prius models. Due to the "stuck throttle" issue, the control software was modified to disable the throttle if the brake pedal is pressed hard.
  9. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    IIRC, force charging was putting the Prius in park and pressing the accelerator and did not involve the brake pedal.
  10. I drove right thru my garage door like that, now I involve my brake pedal.
