PiP Extension Cord Weatherproof Box
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by brogrimm, Apr 12, 2016.
  1. brogrimm
    brogrimm Junior Member
    17
    CA
    2002 Prius
    Just sharing an idea which seems to be working well. I must use a 110VAC extension cord for charging my newly acquired PiP. During inclement weather I didn't charge out of fear that the line would short, trip the GFI, or worse - damage the PiP. I asked around and hadn't found anything like this so I made this to keep moisture out from the cord coupling. After several storms, snow, sleet/ice, and a flash storm with 70mph winds I've never had water in the box or the GFCI circuit tripped. If anyone knows of something made for this please do share the info. Thanks.
    N.J.PRIUS and bisco like this.
  2. Silver Pine Mica
    Silver Pine Mica Junior Member
    48
    22
    Columbia, Missouri
    There are several such products on amazon.
    Hot Headz Extension Cord Safety Seal Water Resistant Cord Cover, 8.25 x 3 x 3-Inch, Green
    On a related note, I would like to know if there is any sort of 120v magnetic disconnect that would safely disconnect an engine block heater connection if you forgot about it and drove off. The connections on deep fryers are made to disconnect easily so as not to pull the fryer full of hot oil onto someone, and a similar connection would be ideal for an EBH.
  3. brogrimm
    17
    CA
    2002 Prius
    Yes, I have one of these I use with my snow thrower. It leaks a little bit and doesn't keep out much of the melting snow without putting additional weather seal foam around the cord. They are pretty good.
    A magnetically attached cable would be nice! They are used in low voltage low current applications, but I don't know why not 110VAC.
  4. mrbigh
    3,686
    699
    Long Island, NY
    There was a development of such a product a few years back but I never found if it is commercially available> NEC regulations are very strict.
  5. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
    I sometimes put the connection under the car to keep it dry. What I also heard from somebody is having it inside the car with the cables through a slightly opened window.
    N.J.PRIUS likes this.
  6. bisco
    52,880
    well done o/p! thanks for the tip.(y)
  7. N.J.PRIUS
    N.J.PRIUS Member
    140
    50
    Fort Lee, NJ
    2013 Prius Plug-in
    When at the office and outside I plug in and put everything under the rear bumper out of sight. If the weather looks bad, I too did not want to take the chance of anything happening so I do not charge. Was also afraid of shorting something out and possibly doing some damage.
  8. bisco
    52,880
    i've plugged in outside in the driving rain and snow, no issues. makes me wonder why they completely revamped the prime charging port.
  9. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    Revamped the charging port on the Prime? Like how? Still in the same location, right? Or are you talking about the CHAdeMO hole they plugged?
  10. bisco
    52,880
    maybe. you have to take the cover off and put it in its holder? what was wrong with the current pips cover? pop it open, plug in, unplug, close, done.
  11. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    Maybe it was those focus groups Toyota relied on? They gave them something more than coffee and they all looked like Jeremy Clarkson trying to plug the EVSE in.
  12. bisco
    52,880
    these focus groups are a thorn in my side.:ROFLMAO:
  13. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    Something must have scared them enough to put a cap on the car charger. And I thought they had it right the first time when they put a cap on the EVSE business end. That can sometimes end up on the ground or dragged around.
    Hey they still have a few months to fix it. Hey @Prius Team, save your plastic. We don't need a cap on the car charger. The one on the EVSE was good enough. Thank you!
