PIP - Leaf - Or Volt ??? - Help Me Decide
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by NYPrius1, Nov 22, 2011.
  1. moolman
    moolman Member
    142
    16
    I'm deciding if I want to lease too but it'll depend what Toyota does with the lease numbers. Are they going to give a respectable MF and residual to make the payments low?
    I was in the same situation 2 years ago when I leased my Lexus HS250. I said to myself, surely in 3 years, their going to put in a Li-On battery and increase the mileage. The 2012 model came out and it's the same car, no change in battery. The car business is slower than the phone or computer business in terms of updates. I'm going to go under the presumption that PIP range will stay the same until the Gen 4 PIP comes out in 2016. It's been said many times that Toyota may be losing money on the PIPs or not making much. There's no incentive for them to increase the battery size so they can lose more money when the current PIP sells just fine. Also, the small batter size is what attracts me to the PIP, I live in a townhome that I rent, so no Level 2 charger for me. 3 hours of charge suits me just fine. If I owned a home, which is the plan in a couple of years. I'd be buying full electric.
  2. Roadburner440
    Roadburner440 Member
    316
    59
    Hampton, VA
    @ moolman if that happens and nothing changes then it will be a 50/50 toss up for me whether I keep the Volt at the end of my lease or buy a Leaf. If will depend on which car is better in the end I suppose. Also depends on where electricity is versus gas in the long run. At least with the Volt at the moment I have the option to run whichever is cheaper.
  3. NYPrius1
    NYPrius1 Active Member
    1,181
    125
    Middletown, NY
    Thanks for the reply.
    As for the company car - that was back in 2006. I purchased the 2007 Prius to replace a company car.
    I don't really need a new car - It's the New Toy Factor and the thrill of not sending any additional Oil $$$ To the middle east.
    The only thing I have made a decision on is - Leasing.
    Whatever I decide to go with - it will be leased.
    I will sell my Prius and put proceeds aside for a purchase 3 years from today. (My Prius is worth more today than in 3 years)
    That gives me the luxury of still having the equity from my current car to use and a Good Look around in 3 years to see what the latest toys are.
    You also have a point on the one day rentals.
  4. NYPrius1
    1,181
    125
    Middletown, NY
    I will put off purchasing any charger until after the lease expires (3 Yrs.)
    I think by than there will be a universal charging standard for the Home Ports and the Commercial Stations. Just another thing that is not certain right now.
    I plan to top off the car each evening and leave it on overnight.
    Even with a Leaf , I wouldn't use the full 100 miles on any given day. (I think I am right on this) With The PIP or Volt I have the mercy of the Gasoline Gods on my side.
    Thanks for some good points to consider.
  5. NYPrius1
    1,181
    125
    Middletown, NY
    Sort of Like a Dual Fuel Furnace :juggle:
    The Freedom to decade is nice.
    My Ultimate Dream is All Electric Car and a PV System to Charge it. I Ride Free Forever and no more $$$ To Support Terror. None of the Troops will be fighting for my ride. :bounce:
  6. NYPrius1
    1,181
    125
    Middletown, NY
    When I look at this from your perspective (Above) I would generally agree.
    BUT
    Tesla Motors changed everything with a 300 mile model s. Unaffordable right now BUT in 3-4 Years?
    What would be the resale value of my 100 mile range 2012 Leaf - When The 2015 300 Mile range Leaf comes out?
  7. Roadburner440
    316
    59
    Hampton, VA
    Like you I started off saying I would not want the 240 charger, and just trickle charge it everynight. With the PiP I would say you do not need it at all, and the Volt is a 50/50 split whether you would or not. I certaintly think it is more than adequate. The Leaf however I would 100% want the 240 charger as I would be tempted to use it for more stuff, and I would not want it sitting out for nearly 20 hours on a 110 outlet... The one thing you will notice with the Volt at least is that the 110 plug gets hot from drawing max volatage/amps for many hours straight. It actually started melting the plastic on my Kill-A-Watt meter I was using.... Not to mention if you charge outside someone can grab your trickle charge cord (they cost anywhere from 600-800 dollars to replace).. So I will be mounting the 240 charger in a box on the side of the house.
    I am looking in to the PV systems now. My father in law has a bunch of panels for his house to run the TV, computers, and other appliances. So far it has worked out well for him. My only draw back is my car gets charged at night. I guess it could be used to cancel out our daily usage in the house, and then just charge off the grid at night.
  8. NYPrius1
    1,181
    125
    Middletown, NY
    Your Reply have shown me that there is so much to think about with EV's Plugin's Etc.
    I am lucky we have the cars in a garage. But do not like wires getting hot. After all I sleep here too. :eek:
    I only drive 100 - 150 Miles per week. So I think a top off will fill the bill for me. (I could be wrong) need to do more research here.
    My other half :( is all for the PIP. They Say " We Have 2 Prius - We Love Them - We Love the Service at the Toyota Dealer - We Love Toyota - What Else is there to think about??
    This is one of the reasons I keep them around. :evil:
    I did write to one Leaf Owner and they said they did the Top Off Method for 6 mos. It was OK Than they purchased an after Market charger for a lot less money. :p
    I will test drive a Volt next week sometime. Already spoke to a dealer. Looking forward to the test drive not the dealer. At this point I don't even know if I will like the Volt. After that I will test drive a Leaf. I think I have a fun filled month of discovery ahead of me.
  9. Trollbait
    12,825
    It sounded like your wife's Prius was also a company car.
    Since you can't casually check the condition of the wires inside your wall, putting in a 20 amp outlet, or even a dedicated 15 amp circuit, for the charger will be cheap insurance for peace of mind. With luck, your garage outlets are on their own circuit, and you can upgrade them all to 20 amp. It might be easier, and cheaper if using an electrician, since you can use the old lines to pull the new ones through.
    If I followed that logic, I'd have gotten a Focus over the Matrix, and waited for the gen3 or other hybrid or EV.
  10. NYPrius1
    1,181
    125
    Middletown, NY
    No, Sorry if I gave that impression. Thanks Again.
  11. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    NYPrius1:
    Stop worrying so much and enjoy the fact that you have so many excellent options. Regardless of the car that you pick, it will meet your needs most of the time. If you get a Volt or a Leaf, you may find a new favorite, or you may re-discover why you picked Prius twice before. Enjoy ...
  12. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I would convert one Prius into a plug-in! Hal
  13. NYPrius1
    1,181
    125
    Middletown, NY
    You Sound Like My Other Half :p
    But That's Just Me :ranger:- Before I Buy almost anything I research, compare, test, shop - Than Read Some More.
    I Guess That's The FUN Of it For Me. :crazy:
  14. NYPrius1
    1,181
    125
    Middletown, NY
    Thanks - Just What The Doctor Ordered :playball:
    Another Option :eek:
  15. Roadburner440
    316
    59
    Hampton, VA
    LOL... To be honest converting your Prius to a plug-in is not worth it in my opinion.. I researched that option before finally deciding to get rid of our truck for the Volt. The Engineer system seemed good for the money, but reliability seemed to be a mixed back.. The best one I saw, and I strongly considered was almost $12,000 intalled... Plus my Prius was not designed to be a plug-in, and after a lot of careful thought possibly voiding my warranty was not worth it. That is what ultimately kicked off my search for a PHEV/EV after having such an awesome experience with our Prius. Granted converting one of your Prii is the cheapest option you have I just worry about possible problems later (not that your other choices don't have associated teething problems).
    Doing research and hanging out on a lot of the forums is half the fun. Granted I mostly come here and the Volt forums since those are the cars I have. Do go check out the Leaf owners one though to see how things are going with them. Is why everytime someone says the Volt is not the answer it really is not to far off from anything else that is out there.. It is the most expensive, but I do feel it is worth it.
  16. richard schumacher
    7,683
    1,066
    United States
    Check with your electricity supplier first. If more than half your power comes from coal please don't buy an all-battery EV until you convert to a non-fossil source.
  17. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    Since you drive more than 13 miles a day - I'd rule out PIP. You want your daily commute to be electric to feel a big difference.
    In NY cold, you will get 60 miles on Leaf. It sounds like that will work for you. But being your other car isn't really yours, complicates matters. Leasing Volt seems like a good option.
    Here my old Leaf vs Volt decision tree.
  18. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Cute kids! Thanks for posting the pics.
  19. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Want verses need...
    My first commute with an early model PHV (August 2010 with a little more than half at 70 MPH) ended this way:
    The production model should be even better.
    Why rule 80 MPG from 33.4 miles out?
  20. john1701a
    12,840
    5,312
    58
    Doctor Who ? ;)
