PIP Mileage deterioration
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SouthBayEcoBoy, Mar 17, 2013.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    We could still probably load a awful lot in his PIP tho ! Merry Christmas
    retired4999 likes this.
  2. retired4999
    2,652
    627
    Eau Claire, Wi.
    (y) and the same to you! :)
  3. markabele
    5,084
    1,782
    Nebraska
    But if you need a big truck...there are no good HV or BEV options, correct?
  4. Andyprius1
    2,327
    859
    Cool CA
    I will definitely cut you some slack there. But, as many PC members have found out, upon revising their needs, they did not need a truck. I would not hesitate to say, " There are many people in this category " Are there any trucks that get 50 mpg?
    Not yet, but, they will be coming.
  5. blift
    blift Junior Member
    When I purchased my plug in, I was able to get over 150 mpg average due to driving around town. Now, even though I use the ICE for heating minimally, the average is down to 48. None of the driving habits have changed. I could not be more disappointed. If anyone is interested in joining a class action lawsuit against Toyota, let me know. I already have an attorney prepared to represent me.
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
    Good luck with that one!!!
    fortytwok likes this.
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    lmao, seriously??!?!?!?!?:whistle:
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    How far is your commute? Have you tried the electric heated seats?
  9. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    According to the Toyota website:
    "In hybrid mode, Prius Plug-in earns a remarkable EPA-estimated combined mileage rating of 50 mpg"
    When the ICE is running for heat- you're in hybrid mode, so you're within only 4% short of the quoted 50 mpg from Toyota.
    retired4999 and priuskitty like this.
  10. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I wouldn't take him seriously until he can provide more details. We want to make sure he actually own a PiP.
    You never know with these first post users with trollish posts.
  11. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    As others have said, the second you are using the ICE, it becomes a regular Prius. There are so many reasons why your car won't be as efficient during the winter (this site does a great job explaining those reasons from an ICE perspective), but you also need to account for battery performance being affected by cold temps (this is not a car thing).
    Toyota's website also has an FAQ specifically for the Prius Plug-in and clearly states that range can be affected by cold temps:
    If your lawyer is willing to take this case, then you either have a crappy lawyer ripping you off, or a dumb one which doesn't understand technology. All IMHO of course (don't want to get sued).
  12. Jmishica
    Jmishica Junior Member
    I AM AT 8.5 MILES PER PLUG IN. Does this seem a little low to anyone else? Purchased the car Aug 2012. I live in long beach, ca at sea level and commute the same way every day- I work 3 miles from my home.
  13. Electric Charge
    545
    133
    Syracuse, NY
    How fast are you going? Any hills? Traffic lights/stop signs? What about temperatures? That range is what I experienced during the winter in Central NY. There are so many variables, it's difficult to tell you what you range you are supposed to be getting.
  14. Jmishica
    I
    I Live in southern california- we are in a drought. Some traffic lights and a few stop signs- flat city driving for the miost part. - A hill that goes downhill one way and uphill the other. But 8.5?
  15. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    Mine says ~17 miles when the charge is full (Orange County). But I work 45 miles from where I live, so I mainly use a blended drive approach and have not tried seeing how far it actually gets on EV only.
  16. bisco
    52,805
    8.5 is a little low, but not so much that i would bother tying you up and waterboarding the details out of you.:cool:
  17. bisco
    52,805
    welcome to priuschat!:eek:
  18. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Is 8.5 the estimate, and if so, have you tracked how far you actually travel on a single charge? I have found that if I don't do any freeway/hybrid driving, my EV estimated range gradually drops from driving solely on EV. My estimated range after some freeway driving has been around 13-13.5 with the generally mild weather we have been having.
    You can reset the estimate by disconnecting the negative battery cable and see if it goes up to around 13. Bear in mind that the estimate is based on the kind of driving you are doing. YMMV.
  19. Electric Charge
    545
    133
    Syracuse, NY
    In that case, it does sound a little low, as 70F is the sweet spot for batteries in EVs.
    I'd check tire pressure, and as rogerv asked, do an actual run and see what the actual mileage is. Feel free to record the trip with your phone (point at the dash, but still keep the road a little visible), and I'm sure some of us here will check it out.
  20. bisco
    52,805
    disconnect the 12v for a minute. that will reset you to 13.3 and you're good to go.(y)
