PIP Mileage deterioration
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SouthBayEcoBoy, Mar 17, 2013.
  1. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Most I ever got was 11.3 estimate, maybe if I drive very carefully I can squeeze an extra 2 accual miles out of it.
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Estimated value calculations remain elusive. I watched mine climb to a record high of 13.9 miles following a multi-day trip milking just a single-charge with +400 mile drives in between. It made no difference with actual miles.
    After 1.5 years and close to 30,000 miles, the real-world results are consistent. The morning commute runs out of EV in the same span of road it has from the beginning.
    markabele likes this.
  3. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    We do do that. ( reply to post 160 )
  4. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    I can't think of any logical reason for this but I'm wondering if mist/fog can somehow kill range ?
    Now that its not summer my daily driving is the same every day, every week and this morning driving my wife to the train I saw a big drop in actual. Pea soup type fog but not cold - 57 degrees which is a good 10 warmer than some recent morning drives and wasn't driving any differently... PiP went a good 3 miles less than recent norm
    Should have a new MPGe entry by the end of the week - guess I'd better take full advantage of the predicted 70 degree days ;)
  5. markabele
    5,084
    1,782
    Nebraska
    Fog at higher speeds would affect it some but shouldn't much at lower speeds. Fog obviously means the air is more dense which takes more energy to push it out of the way.
  6. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    I agree with John. At 18 months, and almost 22k miles in, I have seen my estimate rise and drop many times, from a low in the low 10s to a 14.1 (once). Regardless, on the same trip every day, I get the same amount of EV use. The battery rarely cuts out early or leaves me with excess range. And when it does, I can almost always point to some event that happened during the drive that caused it. Actually, I'm waiting for the inevitable decline in battery health, and by extension, capacity. I wonder how many years it will go, go, go. I'm sure the fact that it's never completely discharged or completely charged up goes a long way into that equation.
  7. tiger62
    tiger62 New Member
    I had my 2012 Prius PIP in Oct 2012 and it started out about 12 miles and now it's about 9.2 miles. I drive the same way. The other thing I noticed was: When I just got the car, ChargePoint station showed that it charged about 3.4 kWh for a full charge. Now it says about 2.8 kWh. So I think the battery is deteriorated. I have not talk to the dealer yet.
    I got my Prius PIP a little more than a year ago. It had about 12 miles and now it has 9.2 miles.
    I just don't believe "the mileage displayed will adjust to your driving style". I have not changed my driving style at all. I use cruse control most of the time. The other thing I noticed was: When the car was new, the Chargepoint Station showed about 3.4 kWh for a full charge and now it shows about 2.8 kWh for a full charge. I think the battery is deteriorated. Should I talk to Toyota about this? I don't really want to waste my time.
  8. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :confused: I once thought the some thing. I've had my PIP since January 2013. When new, my estimated EV range was 12 miles. My daily work commute is 9.8 miles one way, 75% interstate, mostly flat, cruise set at 60. I charge daily, home and work. I can normally make the trip all EV, unless the ICE cuts on. During the summer, my max EV range after charging was 10.1 miles. Coincidence or not? I could never understand how others are achieving 14 - 18 miles on a EV charge? One day this summer, I took a longer, more rural, stop and go route, with one stop. I was surprised I made it home with some EV charge left. I would estimate the route was at least 14 miles. Less confused now than before.
  9. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    So the idea is to drive like like a 90 year old lady, not happening where I live!
  10. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)I'd prefer "90 year old man". My Prius has made me more mellow. With a PIP, my objective is to drive as many miles EV as possible. The difference between driving 60 vs 65 (interstate) for a 9.8 miles commute is minutes.
    fortytwok likes this.
  11. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    I agree with -1- above. Most of us don't have the luxury of ideal EV commuting conditions, but if you could drive 15-20 mph on a perfectly flat road on a nice warm sunny day with no stops, you could do over 20 miles all EV. OTOH, on a cold winter day with mostly freeway speeds and hills, you're likely to get 10 mile EV or less.
  12. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Less than a minute.
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Weather conditions play a big part in EV range ESTIMATES as well. My Volt range estimate varies by as much as 10 miles depending on weather, heater usage and driving speeds. I usually see a range of 45-50 miles in summer but it's dropping to 38 miles so far this winter.
  14. bisco
    52,807
    welcome to priuschat! the estimated range doesn't adjust to your driving style, it adjusts to how many mles you drive in ev before the charge runs out. it's not exact and tends to be a bit conservative. i.e., my estimated range is currently 12.4. but i can eek out 13 or 14 if i try. my first winter, i thought as you do, but found out the next spring that it's just the dropping temps. all the best!(y)
  15. john1701a
    12,840
    5,312
    58
    That estimated value pretty much goes down for everyone. The system collects driving data and adjusts to give you a more accurate idea of what you might get. It's only an approximation though. Focus on what you actual results instead.
    2.8 kWh is dead on. That's what you are supposed to get. More would come about if you run the A/C remotely.
  16. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    45 seconds
  17. LenP
    LenP Member
    257
    69
    Morris County, NJ
    I hear your problem, and first you need to calm down. There are many factors that effect electric range and a lot of them can be managed. If you live in a hilly area that’s where most of your EV mileage is going,
    Cold weather also causes a big drop. I get 12 miles of range in the warm weather and down to 8 to 9 in the very cold weather here in the east. Come warmer weather above 50 deg it all goes back up. If your area is very hilly like mine is here, let the car switch into ICE assist mode, once this happens after a short heat up cycle you’ll switch back and forth from hybrid to pure EV quickly and your mileage will be 80 to 100 MPG. Where you save big time is on short trips, what I do all day long. Running any gas engine even a Prius never does well on very short trips, but your PIP will give you 100 MPG all the time driving around town. In two years I have filled up my PIP twice with gas! I use a high-speed charger and just plug in and go.
  18. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :DAre we there yet?
  19. retired4999
    2,652
    627
    Eau Claire, Wi.
    My wife asked if she should get out and push! :D
  20. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    My problem isn't driving fast on interstate its on local streets where if you don't drive at lest 5 mph above the limit they crawl up your behind.
