PIP & MPG Spreadsheet
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ukr2, Apr 5, 2012.
  1. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Done
  2. Hank101
    Hank101 Member
    108
    SC
    Where can I view entered results for PiP mpg ?
    52,847
    just click on the spreadsheet link in the first post.
    52,847
    ken, i entered new data, thanks!
  5. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Line 2 shows totals and averages.
    If you want to analyze or even sort the data, please select File/Download As to copy and do your work on Your copy.
    This file is shared and any change you make affects everyone. THANKS.
    lensovet likes this.
  6. Jonas Studebaker
    Jonas Studebaker Junior Member
    93
    Maine
    Ken - Maybe if I pay attention to these numbers they will improve. Thank you. I just clicked on the spreadsheet and wrote down all the column headings. It looks like it'll take longer to write the info than to pump the gas! (There ought to be an App - via Bluetooth - for this!) Just to be sure, the interval at which you record your data is only at fill-up time, starting with next fill-up, correct?
  7. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Right, I've mentioned a few times that the PIP needs a Data Logger.
    I used to photograph the displays, but now I write down the screen data while I'm waiting for the pump or right after.
    I use a Kill A Watt meter at home and one at work, record the daily kWh at each location on a calender and then reset them. Then I add up the total kWh for the Fillup.
    I use Trip B and EV2 for the Fillup Data, then reset them. I use Trip A and EV1 to get daily data when needed.
  8. bisco
    52,847
    thanks ken! the link to the spreadsheet is not there today?
  9. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    It's there. I change it to point to the "Enter Data Here" tab and it changed the link to "Welcome to Google Docs".
    I added a 2nd link at the top of the message too.
    So just click on "Welcome to Google Docs".
  10. bisco
    52,847
    when i go there, there is only one line filled by you.
  11. bisco
    52,847
    oh, i see, i have to click the mpg tab, thank!
  12. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Right, you add you data to the "Enter Data Here" tab and I move it to the MPG tab.
  13. Jonas Studebaker
    93
    Maine
    Kill A Watt meter as in this? P3 - Kill A Watt
    Is that necessary to determine column E? I think I've captured the relevant data via photo.
    I have taken photos for my last three fill-ups, so I have entered just the first fill-up, then will wait to see if you think it was entered properly. Thanks again.
  14. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Yep,
    P3 International P4400 Kill A Watt Electricity Usage Monitor by P3 International
    • $50.00
      $18.99
    • Order in the next 23 hours and get it by Tuesday, Jan 8.
    • More Buying Choices
    I bought 3 from Amazon. One for PIP at Home, one for Work and a 3rd to check my other appliances.
    Home Depot only has the more expensive EZ Meter.
    $28.97
    P3 International Kill A Watt EZ Meter
  15. Jonas Studebaker
    93
    Maine
  16. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    External kWh is the value for Column E. It's not required, but we compare it to the PIP value from the EV screen used for Column H.
  17. Jonas Studebaker
    93
    Maine
    Got it. My last three gas tank fills were all on one charge anyway, so it should work. Do my entries look correct?
  18. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Jonas, You only added 1 entry. I already moved it over. -
    1/4/2013 Jonas Studebaker 163Miles 4.4Gallons
  19. Jonas Studebaker
    93
    Maine
    Other two are done. Thx.
  20. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Glad to do it.
