PIP & MPG Spreadsheet
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ukr2, Apr 5, 2012.
  1. stacey
    stacey ☆☆☆☆☆
    115
    23
    Lancaster, PA
    Something looks off to me... looking in the combined spreadsheet, your Gal. (column I) entries are all over 100 and MPG in column T are 600 or over 1000 when Raw MPG in column F is between 30 and 39.
    52,847
    i just multiply the car value times 1.15. it's not exact, but an average of what everyone is getting with the meter.
    52,847
    jonas, i think your hv miles are way off.
  4. Jonas Studebaker
    Jonas Studebaker Junior Member
    93
    Maine
    I see what you mean. Most everyone else's Column D and Column I are close to the same. My entries in Column I are the running total gallons (since I bought the car in November) that are displayed on the HSI. The gallons I pumped per fill up are entered in Column D. I'll leave it alone until someone has good counsel.
  5. Jonas Studebaker
    93
    Maine
    Yes, thank you.
    Those entries in Column N are the cumulative HV miles (for the life of the car) that display on the HSI.
    Same for the EV entries in column L.
    Looks like I made the same mistake with gas in Column I ?
  6. bisco
    52,847
    each entry should reflect the stats for that one fill up. so every line has i's own fill up date and related stats. nothing is lifetime on this spreadsheet.
  7. bisco
    52,847
    best to wait for ken tho, he's the man.:)
  8. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Jonas,
    Columns G-N should be recorded for the Tank of Gas, then reset at fillup.
    Why did you fillup 3 days in a row?
    Are you only driving 4-5% EV miles, as you listed? The Table average is 47% EV miles.
    I adjusted your Columns I, L & N.
  9. Jonas Studebaker
    93
    Maine
    Why do I fill up? To avoid walking! :)
    EV is up to 5% after today. I'm largely a highway driver, but today I did a bit of tooling about town (without a fillup). Plus, it's been COLD out there. I did better when it was warmer in early November when I bought her.
  10. Jonas Studebaker
    93
    Maine
    I'll fill up again by Wednesday morning. How do I ascertain on the HSI the per tank metrics as opposed to the cumulative #s ?
  11. janie
    janie 2016 Prius 3 Touring
    175
    42
    Three Touring
    FYI - today I traded in my pip for the RAV4 EV, so I won't be adding any more info to the spreadsheet. Thanks for your diligence and time you put into putting the spreadsheet together :)
    Tracksyde likes this.
  12. lensovet
    2,615
    496
    Burlington, NJ
    wow, that was quick.
    are you keeping another second car? what is it? or do you never plan on traveling more than 100 miles?
  13. janie
    175
    42
    Three Touring
    no plans to go over the range (when it is full it says 124) - in the past 3 years, I have only driven once from bay area to southern California- I was getting frustrated with the PIP because I loved to use it mainly electric, but charging up every 10 to 12 miles was driving me crazy - so now I am grateful that I won't be charging up so frequently on my longer trips . . . and it is nice to have more space.
    John Hatchett likes this.
  14. lensovet
    2,615
    496
    Burlington, NJ
    Congratulations and enjoy the car! While I don't really have a commute, I can't imagine a car with such a short range. Just yesterday I drove up from LA to Berkeley. Winter is here and there will be at least 3-4 trips to Tahoe, 180 miles each way. The 124 miles it's showing you is probably close to the 13 miles the pip originally shows – only attainable if you drive very gently.
  15. bisco
    52,847
    congrats on the rav4ev! if you have time, please keep us posted in the ev section, your thoughts and review of the car as you go along. also, if you don't mind sharing, what did they give you for the pip? thanks janie, all the best!
    lensovet likes this.
  16. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    If you didn't Reset the Trip or EV values after the last Fillup, subtract the last values you recorded from the current values and use them in the MPG Spreadsheet.
    Then Reset Trip B and EV 2 and use them for your Fillup Data next fillup.
  17. Jonas Studebaker
    93
    Maine
    That's something between Sanskrit and Swahili, but I'll figure it out.
  18. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Jonas, What is your usual daily drive? distance, speed, hills, stops?
    Can you charge the PIP at home and at your normal destination?
  19. Jonas Studebaker
    93
    Maine
    It varies. Home office, but travel days are in the 100s of miles. Highway. Maine is rural up north, with a 75 mph speed limit on I-95. (So we go 82.) I'll plug it in when home pretty much every night, if it needs the charge, which it usually does.
  20. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    You're right, northern Maine is sparse.
    My brother got married in Caribou and the trees were short.
    I escorted a Motorcoach last year thru Maine to Saint John.
    Hard to find a Restaurant between Bangor and the border.
