PiP pure-electric range ?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by freedom45, Mar 6, 2012.
  1. freedom45
    freedom45 New Member
    24
    Montreal, Quebec, Canada
    Hello Prius fans,
    We saw recently a few announcements stating the PiP to offer a 14.3 miles pure-electric range.:)
    ex: 2012 Toyota Prius Plug-In Hybrid now offers 111 MPGe
    Based on recent PiP posts, it seems the best electric range is 13.3 miles. :(
    Can anyone comment, is the pure-electric range 13.3 or 14.3 miles ?
    Thanks,
    Dan
  2. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    When mine is fully charged, it says 12 miles. But because of regenerative braking and when touching the "gas" pedal lightly, I think I am probably getting about 14 miles I'll be interested to see what others are seeing.
  3. H2OSkier
    H2OSkier Member
    276
    16
    I'll trade you cars and I'll let you know how well I do :)
  4. freedom45
    24
    Hum... Strange ???
    This post shows 13.3 Miles
    http://priuschat.com/forums/toyota-prius-plug-in/104294-first-day-my-prius-plug-in.html
    I wonder what could explain the difference... Anyone getting 13 Miles or better ?
    Thanks,
    Dan
  5. bisco
    52,758
    i'm not sure i'm understanding you correctly freedom, do you think the pips are all going to get the same ev range no matter how they are driven and under differing conditions?
  6. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    I'm sure the Prius computer adjusts to your driving and will increase or decrease your EV miles available based on your history. I'll let you know in 3 or 4 weeks when I get mine. I don't believe the value is fixed.
  7. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    When the car is fully charged, it gives you an estimate based on some calculation. But that number is probably only useful to you if you drive on a flat road, non-stop, at moderate speed until you ran out of electricity. Like SimiPrius, said, it doesn't factor in any regeneration opportunities.
    The image you posted above was from the morning of my first commute to work. The engine started that morning for heat, but I made it to work (13.3 miles) with 1.1 mile of EV range remaining (IIRC). My mpg for the trip was 763 (reflecting the tiny amount of gas I used when the engine started for heat). I drove all the way to work yesterday on pure EV and I had 0.6 miles of EV remaining.
    If you drive in hilly areas or roads with higher speeds (50mph, for example) and very little regen opportunities, it will affect your EV range.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Exactly
  9. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    I wish we could dump data from the PIP to a Thumbdrive and load it into a Program to display the data we're all looking to compare.
  10. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    Also, a BIG factor is the temperature the vehicle is at when you look at the "range" meter. If your car is outside, the battery is colder and as we all know temperature affects lithium battery capacity. If you garage your car, it will be warmer and likely show more initial range, that probably accounts for the different initial range numbers you are seeing. Once the car is underway, the pack will be warmed by the cabin air, but that will take quite a while to show up, meanwhile the battery is "discharging".
    Note: If you want to argue about this point, please remember, the lithium battery is NOT an electrical device, it is a chemical storage device, and temperature is a major factor in its ability to hold/store charge.
    2 people like this.
  11. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    LOL! Funny!
  12. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Yes, I wish it were easier to collect data. Maybe something like a laptop with a data logger.. Anyone suggest anything like that? I dont have an Android phone (well, I do but it's ancient, the Tmobile G1)..
    Edit: interesting..
    http://priuschat.com/forums/gen-ii-prius-technical-discussion/24924-prius-can-monitor-data-logger-windows-pc-17.html
  13. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
  14. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
  15. mmstuart
    mmstuart New Member
    53
    30
    My car also show 13.3 also on a full charge.
  16. freedom45
    24
    Great, thanks for the feedback.
    2 people with the same value of 13.3 Miles initial range after a full charge !! :)
    I wonder if all brand new PiP will have the same initial range after a full charge (ie. 13.3 Miles).
    Forget regen, and lets suppose all PiP are in mild weather.
    Right after a full charge, no driving at all. What is expected range that is displayed ?
    Why is there a difference between the value provided by Toyota (See web link above 14.3 Miles) ?
    Thanks,
    Dan
  17. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Toyota told me last September that the computer does learn and adjusts the ev estimation based upon past drives.
    EVO 4G ?.
    2 people like this.
  18. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    The most that I have shown is 12.0, and most of the time it is about 11.5 after a full charge. Should I be concerned that my batteries are not fully charging. Since I live in SoCal where temperatures are moderate, I would think I should see more that 11.5. Thoughts anyone?
  19. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    I really think the Prius ECU learns your driving habit. before my plugin conversion, my distance to empty was always 589 miles. after conversion, the DTE would raise after each fill up. The highest DTE I got was 915 miles. As you exceed the range on the display, the Prius will update with new range that matches your actual range.
  20. daniel
    14,487
    1,519
    Spokane, WA
    It all depends on how you drive and what are the conditions. Gasoline cars have far more variation in actual MPG than that.
    Even if it does, it will still be an estimate, which will not be accurate unless driving style and conditions are constant.
    My Tesla gives me TWO range estimates: One estimate of "ideal" range (assuming gentle driving at, I presume, 55 mph) and another estimate assuming I drive exactly as I have been driving the last 20 or 30 miles (I forget which). I can achieve the ideal range if I choose to drive that way, or even beat it if I drive slower. But with 245 miles of ideal range, I never need to.
