PiP pure-electric range ?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by freedom45, Mar 6, 2012.
  1. daniel
    14,487
    1,519
    Spokane, WA
    A five-seat car that will allow you to to 24 km on pure electric and will also allow you to do long vacation drives on gasoline does not exist.
    So you either stick with a conventional car that uses gas all the time, or you settle for four seats, or you get a Leaf for your commute and use a different car for long drives, or you settle for the PiP which WILL burn gas on your commute, but much less than a conventional gas car.
    What you want does not exist, so you must decide which compromise you want to make:
    All gas in a conventional car.
    A small amount of gas in a PiP.
    Only four seats with a Volt.
    All-electric Leaf that does not make long trips.
    I like the fourth option best, especially if you're going to have a gas car (maybe Prius) in the family anyway.
  2. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Dan,
    Best way to get to work and back on EV is to get a Charge at work.
    I'm installing an outside 120vac 15-20 amp weather-proof outlet at the building I work at. The owner of the building doesn't care, as long as it doesn't cost him. AND I'm going to pay him the added cost for my kwh used. He's 100% OK.
    So ask and the building owner may allow it.
  3. fberger
    fberger Junior Member
    66
    VA USA
    Thanks, I'll wait to hear from you how it works once you receive it. My PiP won't be here for another month at least, I have time...
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    If you want the best, get OBDLink MX. 62 PIDs per second and very tiny!
  5. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Not sure I'm "$245-serious" about collecting data :)
    Is that the one you have? With the (much) cheaper ones, how many PIDs per second would they be capable of?
  6. fberger
    66
    VA USA
    I am with you, that's ten times the price. How much better can it be?
    How about the mid range priced units such as the $86 PLX?
  7. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I have the PLX Kiwi bluetooth. It does about 20 PIDs per second. I believe the ebay clones are said to get about 13 PIDs per sec.
  8. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    My Vscan is getting 12-20 PID/sec (depending on how many fields and such) by my normal setup and logging is only 10 so that is fine with me. Only time I find the speed and issue is when I'm scanning looking for PIDs. Really how many things do I want on my screen updating faster than a second or so. how much do I really want in log files?
  9. mrbigh
    3,686
    699
    Long Island, NY
    Agree !!!
  10. tomkessler
    tomkessler Junior Member
    28
    Campbell, CA
    Here's my latest results from a pure electric commute.
    1) I'm 12.1 miles from my driveway to the plug at work.
    2) 1/3 of the commute is 25mph and 35mph residential/feeder side streets
    3) 2/3 of the commute is a 50mph expressway.
    4) traffic was light
    Today I made the trip entirely on electric with 2.8 miles of EV range to spare.
    Yesterday I made it with about .1 mile to spare and the day before the ICE
    kicked on for the last 1/2 mile.
    The big differences are I set my timer to complete charging about an hour before
    I left for work. I think this helped a lot because the ambient temperature was more
    like 50deg instead of 40 or 45.
    The other difference is based on some recommendations I used a modified pump and
    glide technique. What I did was accelerate up to speed at the max of the EV only part
    of the power bar and then back off and glide with the bar providing just a tad of power
    (i.e. just a sliver on the right side of the regen line)
    climate control was off but vents were on.
    Anyway, that seemed to help range a great deal.
    6 people like this.
  11. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Tom, do you mean the fan was on? but it was not on Auto? If your fan was on, what was the temperature setting? on "low"?
  12. mrbigh
    3,686
    699
    Long Island, NY
    In other words, with a little care, it is posible to attain 15 Emiles or even more....:rolleyes:
  13. bisco
    52,779
    that's a beautiful thing!
  14. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    So it sounds like a Pip will 'glide' in EV mode. And it helps efficiency.
    It'll be really interesting to see what how EV ranges increase when spring and summer temps get here.
    I think we'll all be impressed.
  15. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I cannot see why this is true, other than perhaps an average lower speed. That, however, is cheating ;)
  16. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    Tom,
    Thank you very much for your post. I have not yet read a more complete evaluation of the new PiP in EV mode (you seem to have thought of most everything).
    This is most encouraging news of the car's performance. I am very much looking forward to doing similar drives on my commute.
    Keep up the good work!
    (...and please keep us updated on other things you note).
  17. calbear
    calbear Member
    180
    30
    SF Bay Area
    I'm really bummed they didn't integrate the lock for us... Luckily my company has a charging station (their plug) so I can leave mine at home.
    Are you planning to secure the plug somehow to prevent theft?
  18. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    I highly suspect experienced drivers will be able to get more than the advertised range on EV mode. For example, the EPA says the Leaf has 73 miles of range. Many drivers have managed to do a lot more than that. I think some have had over 120 miles on a charge. I've never personally driven my Leaf more than about 65 miles, so I can't really attest to that.
    But I bet if you drive the PiP on city streets with a low speed limit, such as 30 to 40 mph, and be very gentle on the throttle, I bet you can exceed the advertised range.
  19. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Yes, the EPA EV estimates are more easily surpassed than the gasoline mpg estimates. Most electric vehicles (roadster, LEAF, probably Volt) seem to find their ideal efficiency down around 15 mph.
  20. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    From Tesla Roadster blog:
    Roadster Efficiency and Range | Blog | Tesla Motors
    Very informative reading.
