PiP Regen Behavior?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Redpoint5, Feb 14, 2016.
  1. drysider
    drysider Active Member
    823
    337
    Liberty Lake WA
    The engine is coming on based on the coolant temperature. Running in EV/Engine Off will eventually drop the coolant temp below the minimum allowed by the Synergy firmware (around 110F) and the engine will come on, taking the car out of regen. The A/C has little or no effect since it is electric. However, using heat will accelerate the cooling process. You can see this by watching the coolant temp while either turning the fan off or lowering the heat set-point to Low.
    roflwaffle likes this.
  2. markabele
    5,084
    1,782
    Nebraska
    So much bad info in this thread. And so many people commenting on this when they don't even own a PiP.
  3. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Once the system is fully warmed, the minimum threshold drops.
    Last month, I had the heater running with the engine still off when the coolant was at just 82°F.
  4. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I just got back from my trip to Yosemite, and I'm not any closer to figuring out the regen behavior.
    With no EV range left in the battery I began descending into Yosemite valley from 6,000 feet. Using regen to control my speed, the gas engine came on after about 5 miles of range was put back into the battery, and regen rate was limited to about 40 amps. Any further braking merely used the friction brakes rather than increasing the regen rate. MG1 and MG2 temps never went above about 165 F, and the 3 battery temps never went above 75 F. Finally, inverter 1 & 2 temps never went above 70 F.
    As far as MG, inverter, and battery temps are concerned, I can see no reason why regen would be limited after sustained regeneration.
    This behavior was observed about a half dozen times, with temperatures for these 3 components never increasing to high levels. Normal regen would allow 90-100 amps up until a certain point, and then the gas engine would kick on and regen would limit to around 40 amps. Speed never exceeded 58 MPH.
    I'm at a loss to explain this, and perhaps my question will forever remain a mystery.
  5. bisco
    52,878
    i think it's in the o/m addendum that came a few years after i bought mine. something about the vagaries of descending yosemite sam and the potential for ice firing. i'll look around and see if i can find it. i know it's here somewhere...
  6. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    I'm no Prius expert (planning on buying one), but could it be engaging the ICE for engine braking when certain conditions are met while descending, even if you don't change to "B"? Not sure on the specific roads, but I drove to Yosemite last year and used "L" (in the Chrysler 300 I rented) regularly on the many steep descents. I normally drive a manual diesel and would make good use of engine braking in low gears in such situations to avoid wasting energy by braking. With modern electronic fuel injection there will be no fuel consumption with engine braking and closed throttle.
  7. Redpoint5
    1,026
    509
    Portland, OR
    I'm sure that the ICE is engaging after certain conditions are met, but I'm uncertain what those conditions are. It's not turning on for engine braking though because no further braking happens once the engine is on. I would have to shift to "B" mode for it to run the RPMs up and engine brake.
    Ideally, not only would the car not consume fuel on the steep descents, but it would only use regenerative braking to slow the vehicle as to not waste any of the kinetic energy on the friction brakes as heat.
    As it is, when the car turns the ICE on after a long steep descent, it also reduces the amount of regenerative energy it will accept. Controlling speed then requires use of the brake pads.
  8. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    I was able to see it doing this a few times this weekend, and I think it's kicking on the engine to soak up some of the regen. Can you see battery pressures/temperatures? My guess is there's some limit there the ECU will avoid. I also noticed that the engine would turn off when I took my foot off the brake/turned off cruise control.
  9. Redpoint5
    1,026
    509
    Portland, OR
    Thanks for confirming the behavior.
    Yes, I can monitor the 3 battery temperature sensors. None went above 75 degrees. In fact, no temperature parameter I'm monitoring even appears to increase at the time I observe the engine coming on and reduced regeneration. There must be something I'm not monitoring that goes above the temp threshold.
  10. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    I'm switching my guessometer to catalyst temp, probably the 2nd reading. I haven't confirmed this, but if I'm remembering my downhills right, I don't think the car has ever kicked on the engine when it was hot out and the battery was a less than full charge.
    I had it turn on me yesterday in colder temps at higher speeds, but once it warmed up after a ~2k drop in elevation and I set the CC to 48mph to charge on a downhill, the engine didn't kick on at all.
  11. Nougatti
    Nougatti Member
    119
    59
    Norway
    I'm thinking more and more that this is the case, and that the ICE stays on and propels the car after the downhill for the exact purpose of letting the MGs "rest".
  12. bisco
    52,878
    maybe the software is programmed to fire the ice after so many miles of regen, to prepare it for use.
  13. Nougatti
    Nougatti Member
    119
    59
    Norway
    My thinking exactly. As you can see from my video, regeneration actually continues after the ICE fires, though slightly slower.
    What you should be looking at, Redpoint5, is if the MGs propel the car at all once the hill is done.
    Is there any anomaly in power draw that suggest they are being spared and that the ICE takes most of the job propelling the car once the hill is done?
  14. bisco
    52,878
    it's a shame to lose the regen, and have the ice fire, i hope they have come up with a better system for folks in hill country.
  15. Redpoint5
    1,026
    509
    Portland, OR
    It's not that. If regen is gently applied, you can go an infinite amount of miles without the ICE kicking on until the battery nears full charge. It has something to do with the rate of regen in a given period of time.
    The MGs power the car normally after the hill is done, so I don't think it has anything to do with MG or inverter use. In fact, MG2 is used for both propelling the car, and capturing regen energy. The energy going through MG2 is much higher to propel the vehicle than it captures during regen, so regeneration should not pose any difficulty to it.
    My best guess is some algorithm that reduces regen when a certain rate of regen is maintained for a certain amount of time. This might just be an extra safety measure for the battery.
  16. bisco
    52,878
    i wonder if ambient temp also comes into play?
  17. Redpoint5
    1,026
    509
    Portland, OR
    I haven't noticed ambient temp to be a contributing factor, but I wouldn't rule it out considering the variables at play. It would be difficult to test as I would have to descend the same grade with the same battery charge at the same rate of regen under different temperature conditions.
    I've pretty much given up hope of figuring this out unless a Toyota engineer chimes in, or Bob remembers reading it in some technical document.
  18. Nougatti
    Nougatti Member
    119
    59
    Norway
    The temperatures are closing in on freezing here these days (0'C/32'F). Today, while going down a tiny hill that takes about 20 seconds to go down and WITHOUT braking at all (just normal off-pedal coasting regen), the ICE fired up. It's never done that before (then again, it's never been this cold since I bought the PiP).
    HVAC completely off. Charge level at about 90% from full.
  19. bisco
    52,878
    i have a small hill on my way out of town. just enough to take me from 25 mph at the top to 35 mph at the bottom with foot off the gas. when i leave the house with a mile burned off of a full charge and temps below about 40f, the ice has fired every time for the last 4 1/2 years. i can defeat it by putting it in neutral until i get down to about 30 mph, but it's a 40 mph road, so if any traffic behind me, i'm out of luck.
  20. Nougatti
    Nougatti Member
    119
    59
    Norway
    Can't you have it in neutral at almost any speed?
