PiP, the mistery electrical guts....
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by simply_me, May 7, 2012.
  1. simply_me
    simply_me New Member
    North Eastern USA
    I took some time to strip the rear panels to uncover the "guts" of my PiP.
    and some pictures to fallow......................
    10 people like this.
  2. simply_me
    North Eastern USA
    and some more......with some measurements
    john1701a, pfile, JamesBurke and 2 others like this.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Are those two white things on the back of the pack fans?
  4. PRPrius
    PRPrius Active Member
    327
    198
    Yes, those are the battery's cooling fans
  5. mrbigh
    3,686
    699
    Long Island, NY
    Nice !!!!
  6. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Those scroll fans, they would be exhaust fans right? extracting heat/air from the pack and exhausting it into that area beneath the cable storage box? So would that mean that black tube is something like a cold air intake (if you're pulling air out of the pack with 2 fans, then it has to draw air from somewhere)?
  7. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Looks like there's still quite a bit of room back there. An 8kwh PiP seems like a no brainer.
  8. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    I think that is crumple zone space behind the pack and isn't that where the little storage compartment is?
    The orange cable looks to be the AC mains. Connects to the pack under the left side cooling fan housing. (set1 pic6) Looks like you could get a couple of split CT's (Current transformers) around the single wires right at the connector. I'm thinking onboard kwh meter/recorder. Black ground T's down below the charge port to the fender well. (set1 pic3)
  9. simply_me
    North Eastern USA
    Re: PiP, the mystery electrical guts....
    I just add some information over some pictures.
    The 2 large white blowers are sucking exhausted air ffrom the battery container.
    Fresh air is introduced trough the black rubber duct from out side the vehicle and the cabin interior rear vent.
    The battery charger is located underneath the battery container and is a fairly large enclosure with its own pancake blower.
    Not visible is the batteries connection to the battery charger/manager system.
    More likely this interconnection is available behind an armor plate between the rear seat and the battery container.
    The safety plug is actually a service disconnect and doesn't carry a fuse like in the Gen II; I don't know about MY 2010/11.
    3 people like this.
  10. mrbigh
    3,686
    699
    Long Island, NY
    This is neat information !!!!
    Thank you for the time you invested in providing us this "tasty" inside information.
    Now, don't blow it; we still need you for some more :rolleyes:
