PIP touchscreen protector
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 7-0-SAV, Aug 17, 2014.
  1. 7-0-SAV
    7-0-SAV Junior Member
    23
    2014 Prius Plug-in
    The touchscreen on our 2nd gen Prius has stopped working in high-use areas. On touchscreens, this happens due to a failing digitizer.
    Where can I find a touchscreen protector for a base PIP? We want to keep our new PIP screen functional for as long as possible.
    I'm looking more for a plastic adhesive that sticks onto the screen, as opposed to a cover. The oils in our skin can also be a cause for malfunctioning touchscreens.
    For more information on digitizers:
    How the Digitizer / Touch Screen Works
  2. GregP507
    GregP507 Senior Member
    3,002
    481
    Not necessarily is it a malfunction. It may be due to contaminants on the touch screen. A good cleaning with a mild soap and lots of water may be worth a try. I'd recommend removing the cowling first.
    52,849
    could you cut down an iPad screen protector?
  4. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    The Prius uses a resistive touchscreen, which depends on a conductive layer beneath the surface. Nothing you do to the surface will prevent problems underneath. And a screen "protector" may make the screen's top layer less flexible so the resistive layer will not sense touch as readily.
