PIP transmission oil change @ 10K miles
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by tplus, Feb 10, 2013.
  1. Mendel Leisk
    41,463
    This is a clip from a downloaded version of the Canadian Owners's Manual Supplement, and to be fair, it varies from the version I've got sitting in the glove box. Toyota's not exactly organized in their statements. Anyway, what the clip seems to be saying is Camry (including hybrid), Sequoia, Sienna, and Tundra get transmission/transaxle fluid change at 72 mo / 96000 km. All others, good forever I guess, LOL.
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Because the other transmissions are conventional automatic transmissions with friction material that wears by design and ends up in the fluid.
    I removed your sarcastic musings on Toyota's plan for world domination.
  3. ACKPRIUS
    ACKPRIUS New Member
    Nantucket
    tplus or anyone, have the Toyota part number for the aluminum gasket in this project? I've had no luck with any fische's. Thanks
  4. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
    All i see is a waste of 2 pint glass'...
    Send it off to a lab, usually it costs about 10$ with postage included. I sent many, many many samples for cogen engines out in my time and I very rarely could tell you the results before I got them back.
  5. sardog
    sardog Junior Member
    25
    Tampa FL
    Nice write up & photos! I like your jack stand mod...can you make me a pair?;)
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    great pics tplus, keep up the very useful threads. If you are over maintaining, that's your affair. It will not do any harm. Cheers.
  7. Andyprius1
    2,327
    859
    Cool CA
    Ignorance is bliss. A lady. On Prius chat, Gen 2 remarked " I didn't even know the car had a battery", this after problems with the 12V battery, after owning the car 7 years. NOT TPLUS!
  8. Mendel Leisk
    41,463
    On a receipt from a Canadian Dealership, it's:
    Part No / Description: 90430-18008 / Gasket
    Could be you're overthinking this though: at the parts counter just asking for the transaxle drain/fill bolt washer will work.
    Andyprius1 likes this.
  9. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Thanks for bringing up the reminder, as my PiP approaches one year and 20,000 miles.
  10. mrbigh
    3,686
    699
    Long Island, NY
    20K miles already???? Wow ....
  11. Rebound
    3,996
    2,644
    Portland, OR
    85 mile r/t commute to work, Alameda to Sunnyvale. The commuter lane sticker is like gold to me.
  12. lensovet
    2,615
    496
    Burlington, NJ
    hey, that's almost as long as the 110-mile Berkeley→Cupertino commute I decided I didn't want to do at all and started taking Amtrak…
  13. Rebound
    3,996
    2,644
    Portland, OR
    I checked the Prius Maintenance Guide. It doesn't recommend replacing the transmission fluid at all, only inspections. But it mentions inspecting the Transmission fluid and the differential fluid.
    So with all the talk of replacing the transmission fluid, what about the differential fluid?
  14. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    There is no separate differential fluid.
  15. Rebound
    3,996
    2,644
    Portland, OR
    Really? Then I wonder why they tell you to check it. Odd. Maybe it's a generic thing they apply to lots of different cars?
  16. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    I hit 25K miles 2 weeks ago...
  17. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I'm 99% sure that this also applies to the Plug-in, but I've been referring to the manual for the conventional hatchback.
  18. Bill Norton
    Bill Norton Senior Member
    2,154
    734
    MONW, Ks.
  19. Rebound
    3,996
    2,644
    Portland, OR
    I searched far and wide on PriusChat, and the conclusion is that Prius does not have a "Transmission," it has a "Transaxle," which means that the transmission and differential are combined together. Ergo, "Transmission Fluid" and "Differential Fluid" are one and the same in a Prius. There is no separate place to check, change or add Differential Fluid.
    I wrote an e-mail to Toyota, telling them they need to fix their maintenance guides.
  20. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Just to be perverse I'll point out that there are transaxles that use separate lubricant for their differentials. But the Prius doesn't.
    lensovet likes this.
