PiP vs standard
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Dbrew, Feb 15, 2016.
  1. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    How would replacement cost compare of the 2 different batteries? Do you we know the difference in cost?
    52,861
    the lift back is in the low $2,000.'s, the pip i'm not sure, maybe $4-5,000.? no one here has had to replace theirs yet. someone mentioned low mile junkers for $1,500.
  3. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    Do you have many miles on yours? Have you noticed any battery difference since new?
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    4 years for mine. 73,000 miles. No difference.
  5. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    Do you usually plug in or do you use it like the regular non plug-in prius?
  6. john1701a
    12,840
    5,312
    58
    I couldn't imagine anyone not plugging in, even if their original purpose for buying the plug-in was for the sake of HOV privileges. It takes only a minute and the gain is obvious. So, of course I do, and not just at home either. At work, the electricity for charging comes from a massive (85 kWh) solar array.
  7. bisco
    52,861
    i have 38,000 miles, with 25,000 of that in ev mode. maybe lost 10%, it's hard to know for sure.
  8. markabele
    5,084
    1,782
    Nebraska
    I think the people that are seeing very little change might be getting fooled a little bit. Unless they have new tires, the OEM's wear may be helping their distance. That, combined with learned efficiencies in driving in electric.
    Redpoint5 likes this.
  9. CharlesH
    2,798
    1,166
    Roseville, CA
    How does the wear effect things? Is it the radius of the tire getting smaller as the tire wears, or the thinner tread providing less rolling resistance, or the rubber getting harder as it ages and lowering rolling resistance? I just got new tires (at 66000 miles), and my first impression is that my mileage has taken a dive.
  10. markabele
    5,084
    1,782
    Nebraska
    Good question. I don't know the details of how it exactly changes things. But I've always heard it makes a big difference.
  11. bisco
    52,861
    without standardized testing when new, and then every so many thousands of miles, it would take a major reduction in miles for a human being to recognize a drop.
    we're like frogs in water coming to a boil, we don't recognize anything until it's too late.
    N.J.PRIUS likes this.
  12. dalmore
    dalmore Junior Member
    My experience with the PiP uncharged in stop and crawl freeway rush hour traffic is that the PiP will regen beyond what the standard Gen3 Prius will. I have noticed that post rush hour crawl, the status display will be on the "big" battery instead of the little one and will list an EV range of over 1 mile when I was operating in HV on the little battery with no EV range at the start of the stop and crawl.
    Overall I'm getting about 53-55 mpg without charging and about 57-58 mpg with nightly charges driving about 150-200 miles a day as a Uber driver in the Atlanta area.
    I do miss the extra gallon from the gas tank and have started topping off the tank when I can. I don't miss the spare tire since I've not needed a spare since my college days in the 80s.
    Heated seats are a must for me so score 1 for the PiP
    Don't use the Nav and the apps opting for the phone. It's a learning curve thing for me. Why learn a different way for my car and my wife's car when I'll have my phone with me in both cars? So that the PiP has those is meaningless to me.
    Given the wheels and the extra trim looking better to me, I'd pay a premium to get a plug-in so I'd definitely buy another PiP at a discount.
    Oh,I forgot to mention that PiP is eligible for Alternative Fuel plates in GA which grants HOV lane access with just a driver. Huge benefit if you commute in the Atlanta area.
    #52 dalmore, Mar 16, 2016
    Redpoint5 and bisco like this.
  13. bisco
    52,861
    very progressive for georgia.(y)
  14. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    All of the above. With worn tires, the wheels have to turn more revolutions to travel the same distance compared with new tires. The odometer then uses the extra distance in the estimated range calculation.
    Deforming the tread on a new tire increases rolling resistance and decreases efficiency. Bald tires have less rubber deforming, and therefore are more efficient to drive on.
    I'm not sure harder rubber has much effect though.
  15. Mendel Leisk
    42,352
    If you ever go from well-worn tires to new without a drop in mpg, you've got a mpg keeper.
  16. N.J.PRIUS
    N.J.PRIUS Member
    140
    50
    Fort Lee, NJ
    2013 Prius Plug-in
    Never knew that. They may be more efficient until you need to stop in the rain!
  17. Mendel Leisk
    42,352
    I think bald tires (slicks) are better at dry braking too. Same for accelerating: just picture a drag race vehicle. It's a balancing act, weighing dry vs wet traction.
  18. markabele
    5,084
    1,782
    Nebraska
    Do we see a day, technology-wise, that we see tires somehow do both (become slicks and great depth for snow and ice)?
  19. Mendel Leisk
    42,352
    There's a thought. Yeah I can recall needing sudden/fast acceleration to jump into a short left-turn opportunity, with snow tires on dry/bare pavement, and spinning the wheels.
  20. fuzzy1
    10,710
    With modern steel belted radial tires, the rolling circumference of the tire changes much less than one might expect from simply applying tread depth wear to the normal circle equations. The road contact patch is flat, nor circular. With tires loaded and inflated within their normal operating range, the rolling circumference is determined mostly by the length of those steel belts just beneath the tread. Belt length changes very little with tire wear and inflation pressure.
