Piping A/C to HV battery air-cooling inlet port
Discussion in 'Gen 2 Prius Technical Discussion' started by aaroncv3, Jul 11, 2016.
  1. aaroncv3
    aaroncv3 Member
    95
    51
    Yucca Valley
    I saw somewhere on PC--perhaps the 'Priuck' thread--A/C being piped in to the HV battery cooling channels. In regions with warm-to-hot weather year-round, what do I need to be aware of when employing this tactic as a temporary means to reduce stress on a vehicle temporarily under the increased stress of much cargo?
    looking forward to your thoughts.
  2. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    I don't think this is a very common hack, so the question would be if the cure is worse than the disease. Before you do this, I would think you'd want to clean out existing cooling fan and monitor temp of the battery via OBD2 reader to establish a base case.
    49,434
    i think the battery suffers more from sitting all day in the hot sun, than from driving with the a/c on and the oem cooling fan operating properly. if you have to park in the sun in a warm climate, that would be my first area of attention.
  4. jeff652
    jeff652 Senior Member
    606
    623
    Idaho
  5. aaroncv3
    aaroncv3 Member
    95
    51
    Yucca Valley
  6. bisco
    49,434
    where were they 30 years ago!
    aaroncv3 likes this.
  7. aaroncv3
    aaroncv3 Member
    95
    51
    Yucca Valley
    when i was young, we had only a small Zenith B&W TV. No cable TV, and no A/C. If it was hot outside, you went to the shade or inside. If it was hot inside you sat in front of the fan and made noises against the rotating blades.
  8. bisco
    49,434
    i wasn't young 30 years ago, but my kids were. i was younger tho. 50 years ago, now yer talkin:coffee:'.
  9. aaroncv3
    aaroncv3 Member
    95
    51
    Yucca Valley
    you seem pretty well put together around here, i guessed you had some years on me!
  10. bisco
    49,434
    put together, and falling apart!:p
    cosmo64 and aaroncv3 like this.
