Place your bets: Make your call on 2010 global average temperature
Discussion in 'Environmental Discussion' started by chogan2, Feb 18, 2010.
  1. Yes
    8 vote(s)
    44.4%
  2. No
    10 vote(s)
    55.6%
  1. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    C02 is estimated to have been maybe 20x current levels, when the sun was about 5% dimmer than now, yielding about the same average global temperature as now. The phrase in italics seems somehow to get deleted on all the denialist websites.
    So, if you only get your information from denialists, you might think that climate scientists have never been able to resolve that huge apparent paradox. Instead of the correct story, which is that modern climate models, when tuned for conditions of that ancient era, give roughly the right surface temperature, in so far as we can know the surface temperature some hundreds of millions of years ago. In fact, the estimated tradeoff between solar intensity and C02 concentration at constant temperature is a pretty good validation of the greenhouse effect of C02.
    Recent ice ages were caused by periodic changes in earth's orbit -- the Milankovitch cycle. There is absolutely no disagreement about that. They occurred regularly, exactly when Milankovitch said they would occur.
    The reason scientists disbelieved Milankovitch for so long is that orbital changes alone were not sufficient to cause a deep ice age. Only when they figured out the C02 feedback did that fully reconcile all the evidence.
    So, C02 didn't cause those changes, it amplified them. Warming released C02 into the atmosphere, largely from the ocean (just like warming up a Coke), and that additional C02 provided the feedback.
    Once again, the paleo data roughly validate the estimated greenhouse effect of C02 concentration. Without the C02 feedback, the temperature change over the ice age cycle would have been less than half as deep as observed.
    At this point, all you need to do to see the light here is to realize that different things may cause C02 concentration to rise. Once you grasp that, then, bingo, it's not some huge paradox that the best-and-brightest have somehow ignored, it's another piece of evidence that fits into a logically consistent picture of the world.
    If, contrary to fact, it were true that the only way C02 could increase was by driving it out of the ocean via increased water temperature (as during the ice ages), then your comment about 800 years (over the >100K year ice age span) would be on point. If, contrary to fact, the only way C02 could rise was as a feedback to temperature increase, then your point is well-taken.
    But that's not true. That little C02 feedback from temperature to C02 concentration is only the smallest contributor to the current rise in C02. Instead, the overwhelming source of C02 increase is the burning of fossil fuel. There is zero uncertainty about that -- all you need to prove that is some basic arithmetic. We know the quantities of fuel being burned, so we know the carbon we release every year, and we know that the annual increase in atmospheric carbon is much less than that, meaning that we know that Nature as a whole remains a carbon sink.
    How different is that ice-age feedback from the present situation? Compare the time scales. Typical recent ice age warming period, increase of 100 PPM C02 over ~100,000 years. At present, increase of 100 PPM C02 in 100 years. The modern C02 buildup is 1000 times faster than the buildup during the ice ages. It's a completely different animal.
    And that should give a hint as to why it's not irrational to think this may be a problem. Atmospheric C02 appears to be a key determinant of climate, any way you look at it, particularly if you look at the paleological data. We've increased atmospheric C02, in the last 100 years, as much as Mother Nature did, over the entire course of the last ~100,000 year ice age warming period. It's important, and we we've perturbed it a lot compared to historical norms. Knowing nothing more than that, I'd expect to see some kind of fallout.
    So, the straight scoop here is that both pieces of paleological evidence demonstrate the warming power of atmospheric C02. But you can't look at them in isolation. Twenty-times-higher C02 with same temperature is no paradox, as long as you realize the sun was about 5% dimmer. A lag from temperature to C02 in the ice age is no paradox as long as you realize that driving C02 out of the ocean is not the only way C02 can increase.
    But all of this is off-topic. In fact, I kind of wish you'd take the argument somewhere else.
    As of March, I say there's about an 85% chance of a new record this year. That's what the thread is about.
    3 people like this.
  2. icarus
    icarus Senior Member
    4,884
    976
    earth
    Chogan2,
    There you go again,,,, trying to confuse us with well thought out, logical arguments backed up with scientifically agreed on facts!
  3. tochatihu
    tochatihu Senior Member
    9,994
    3,859
    Kunming Yunnan China
    2001 Prius
    The ice core 800 year lag has been dealt with extensively in the past. Milankovich cycles change the radiative input by a watt (or a few) per sq m and this is amplified (on about the millenial time scale) by net CO2 release to the atmosphere. This feedback effect reaches a maximum within a few more millenia.
    This is how it goes (has gone) over the last million, in the absence of massive releases of fossil CO2. That process is of course now underway, and it seems entirely reasonable to anticipate that CO2 forcings on temperature will operate much as they have over the past million, ie 3 degrees CO2 per doubling. Could be a bit more or less, and naturally people who like the biosphere as it is now would prefer 'less'. But we shall have to see.
    People are not obliged to learn such things, but speaking out in willfull ignorance of them is probably not a good plan either.
    Tripp, the faint early sun thing has been getting a lot of attention lately, and Rosin et al. 'No climate paradox under the faint early Sun' in Nature on 1 April (no joke) suggests that continental albedo and lack of cloud (lack of biogenic cloud condensation nuclei) could have 'fixed' the energy balance w/o invoking much higher CO2. There is more to it than that, but better to read it for yourself. You may be sure that Ralph Berner (GEOCARB is his classic CO2 paleo-reconstruction) already has :)
  4. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    Shades of Mt Pinatubo...err, [FONT=Verdana,Sans-serif]Eyjafjallajokull (ay-yah-FYAH'-plah-yer-kuh-duhl) glacier. This could throw a monkey wrench into the pot.
    Note: this is NOT climate, and for once it's not weather either. But it will have some effect on global temperatures.
    [/FONT]
  5. chogan2
    1,066
    756
    Virginia
    Yes, if this is another Pinatubo, then there will be no record set this year. I see a smattering of reports that say it's not big enough yet to have any significant impact. Interesting to see people mention that immediately.
    I vaguely recall that its hard for a high-latitude volcano to have a large effect, but could not recall why. That's explained in the link below. The patterns of stratospheric air circulation tend to limit the spread in the stratosphere:
    Wunder Blog : Weather Underground
    That site also notes the exceptions. More-or-less, you need a large sustained eruption in the high latitudes to get a large effect.
  6. tochatihu
    9,994
    3,859
    2001 Prius
  7. chogan2
    1,066
    756
    Virginia
    April 2010 Update:
    The April temperature anomaly in the GISS series remains well above the annual record. The two satellite series fell to slightly below their respective annual records.
    Based on the historical data, there would be about a 96% chance that a new record would be set this year in the GISS series. (That is, only twice since 1950 can we observe cooling in the last eight months of the year that would be large enough to prevent this year from making a record.).
    Balancing that, the El Nino has ended. NOAA expects "ENSO-neutral" conditions starting in June and carrying through the rest of the summer. That definitely argues for cooler measured surface temperatures.
    The impact of the Icelandic volcano appears small, at least based on what I read among people who have a direct financial stake in understanding the impact: commodities speculators and reinsurers. So far, the only apparent impact on food production is on shipping.
  8. chogan2
    1,066
    756
    Virginia
    May 2010 update.
    Satellite data showed a modest increase in temperatures, NASA GISS showed a decline. Based on the first five months of 2010, there's now an 89% probability of a new record for the calendar year (same methods as prior posts).
    The most recent El Nino is finished, and NOAA's summary of expert predictions says that the Pacific is likely to move into La Nina mode over the next three months.
  9. chogan2
    1,066
    756
    Virginia
    June update: 93% chance that this calendar year will set a record in the GISS series.
  10. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
  11. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    Global average temperature is a meaningless metric. Ocean heat content is a much better indicator of changes in global climate.
    Over the past 50 years, the oceans have absorbed more than 80% of the total heat added to the air/sea/land/cyrosphere climate system (Levitus et al, 2005). As the dominant reservoir for heat, the oceans are critical for measuring the radiation imbalance of the planet and the surface layer of the oceans plays the role of thermostat and heat source/sink for the lower atmosphere.
    So how much change has there been?
    Domingues et al (2008) and Levitus et al (2009) have recently estimated the multi-decadal upper ocean heat content using best-known corrections to systematic errors in the fall rate of expendable bathythermographs (Wijffels et al, 2008). For the upper 700m, the increase in heat content was 16 x 10^22 J since 1961. This is consistent with the comparison by Roemmich and Gilson (2009) of Argo data with the global temperature time-series of Levitus et al (2005), finding a warming of the 0 - 2000 m ocean by 0.06°C since the (pre-XBT) early 1960's.
    So 0.06 C change in 40 years...not much to be worried about I'd say.
    Regardless, recent analysis shows ocean heat content has been falling since early this century...
    ...and is presently well below GISS projections:
  12. icarus
    4,884
    976
    earth
    Tim,
    I'm sorry, but you just don't get it do you? .06c (if I accept your premise) of average ocean temp is huge given the huge mass of ocean water. Now .06c may not mean much as an average, but how that temp rise translates to ocean/air temps, especially at higher latitudes is potentially catastrophic.
    If you are permafrost, the difference between melting and remaining may be just that .06c. Nearly every climate expert agrees that the effects of global warming are going to be much more significant at higher latitudes, setting up a catastrophic feedback loop, melting, causing more melting, causing more release of methane, causing more melting.
    So I ask you, Tim, once again, what will it take to convince you that this is real,, and significant?
    Icarus
    PS .06C in the last 40 years only reflects the CO2 emissions from decades past. Projecting forward, the effects are likely to be way more severe, and getting more severe, ever faster.
  13. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
  14. chogan2
    1,066
    756
    Virginia
    Laughable. Aside from the clear bias in the opening segment:
    "Most scientists believe that the greenhouse effect causes ... no rise in ... temperature and carbon dioxide .... has only a minor greenhouse effect."
    They conveniently managed to forget that:
    a) 70% of the earth's surface is oceans, not land-based temperature data at issue. If there had been zero measured increase on land, the data would still show a significant global temperature increase over the last century.
    b) Multiple countries do their own temperature analyses, so if we'd fudged it (the allegation), that would be clear.
    c) Composites of borehole studies show the same rise as the thermometer data, so that on a timescale of centuries, you don't have to rely on historical thermometer data to know there's been a rise in temperature of roughly this magnitude. That was one of the pieces of evidence used in the National Academies of Science report to demonstrate that the "hockey stick" graph is essentially correct.
    d) a "cold thermometer" is not the same as a thermometer showing little warming (trend, not level, is what matters)
    e) For the US, if you only take the thermometers that Watts approves of, you get the same trend as shown with the entire historical climate network dataset with edits.
    f) Multiple independent competent analyses have shown the same temperature trends despite variation in methods, the most recent of which was the Muir Russel report (the one that exonerated the research produced at CRU), where it took them all of two days to reproduce the temperature timeseries from scratch. Well, even if people ignore that, maybe at least it'll quiet the people who keep whining that the data aren't available.
    f) In the US, the new climate reference network shows the same trend, this decade, as the analysis of the historical climate data. So ... the presumed downward bias in temperature trend somehow ceases to matter in the modern era?
    g) Since 1980 or so, we've got satellite-based data that's in reasonable accord with the land-based thermometer data. So ... the presumed bias somehow ceases to matter in the modern era?
    EDIT: Some background on Coleman, the guy in the video:
    http://www.voiceofsandiego.org/environment/article_45f39d86-5be3-11df-9bf5-001cc4c002e0.html
    "His college major was journalism; his meteorology training came from a Penn State University correspondence course. He's no longer accredited by the American Meteorological Society. Too much politics, he says."
    And his take on global warming, in what appears to be his own words:
    http://icecap.us/index.php/go/joes-blog/comments_about_global_warming/
    "It is the greatest scam in history. I am amazed, appalled and highly offended by it. Global Warming; It is a SCAM. Some dastardly scientists with environmental and political motives manipulated long term scientific data to create an illusion of rapid global warming. Other scientists of the same environmental whacko type jumped into the circle to support and broaden the “research” to further enhance the totally slanted, bogus global warming claims. Their friends in government steered huge research grants their way to keep the movement going. Soon they claimed to be a consensus."
    It gets worse from there.
    We all have to make our own choices, but I don't think that's who I'd turn to for level-headed information on this topic.
  15. chogan2
    1,066
    756
    Virginia
    When the short-term trend in air temperatures was flat, your posts here talked about how that showed that global warming didn't exist.
    Now that air temperatures appear to be ready to set a new record (since the last record, all the way back in 2005, per the GISS data), its now hey presto, air temperature doesn't matter, you need to focus your attention on a short-term flat spot in a different (noisy, fluctuating) dataset.
    And, as ever, we must ignore the fact that if you'd moved your graph back a decade, you'd get a picture that is completely the opposite of what you've shown.
    Same old, same old.
    Since the point of this thread was prediction, I'll offer a new one: When the heat content data turn up again, you'll find some other short-term trend to look at.
    2 people like this.
  16. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    I think its obvious manipulation, and at the very least its junk science.
    Why select 1500 thermometers that are mainly in heat altered urban areas ,and disregard 4500 unadulterated rural readings?
    Why not increase reporting from more than 6000 thermometers?
    Why not use 60,000?
    If AGW is real, why is there a need to cheat ?
    If Im not mistaken, the "hide the decline" graph was hiding tree ring data which does not show a temperature increase.
    Contemporary tree ring data does not correspond to thermometer readings,even though in the past it has been completely reliable.
    Is the earth getting warmer, or cooler?
    UAH &RSS Satellites show a decline in temp from 1998-2008 .
  17. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    I've always felt ocean heat content to be the better metric. However, the use of Argo floats has only in the past few years permitted reliable ocean measurements (although there is some doubt in my mind still how well calibrated those sensors are). Regardless, if you wanted to look at temperature instead, I would not trust land-based measurement because of the countless well-documented biases. Instead I would rely on lower troposphere temperatures as measured by radiosonde or satellite.
    As you can see here, the trend LTL is positive but hardly catastrophic...just 0.16 C / decade (which is inclusive of BOTH natural and anthropogenic influences). That is 1.6 C over 100 years -- at the very low end of IPCC projections. Of course we don't have the satellite data prior to 1979 but since we began coming out of the little ice age around 1850, much of the warming before 1979 was likely natural and likely continues to be natural.
    • So will 2010 be a "record" temperature year? Quite possibly.
    • Is that expected - since we've been warming for the past 160 years? Yes.
    • Is it meaningful? Not likely.
  18. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    And by the way, if you DO trust the land and ocean surface temperature measures, then please explain why temperatures rose ~0.4 C from 1910 - 1940 without any significant human CO2 contribution and how they fell from 1940 to 1980 when human CO2 output soared. Finally, how do we know that the same natural factor that drove temperature from 1900-1940 was not active from 1980 onward?
  19. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    Temps have risen naturally since the little ice age 1800-present.
  20. chogan2
    1,066
    756
    Virginia
    From easiest to hardest:
    Select?
    They wish they could select. That ain't the issue. In the historical climate network, you've got what you've got. You've got 1200 or so currently reporting sites.
    The United States Historical Climatology Network (USHCN) Main Page
    Thats-f@#$ing-it. NASA GISS didn't drop them, NOAA didn't drop them. The-great-international-climate-conspiracy didn't drop them. They dropped themselves. There-ain't-no-f@#$ing data from the other sites.
    Get it? You've got about 1200 sites currently reporting. You have to deal with that.
    Why not 60,000: Because there ain't no data.
    Why not 6,000: Because there ain't no data.
    Why 1200: Because, that's what you've got.
    The important thing is that there are relatively few "degrees of freedom" in the temperature trend. To estimate the trend accurately for the US, I've been told you need fewer than 50 thermometers. For example, the trend in Washington, DC is going to pretty much like the trend in Baltimore, MD, and both are going to be similar to Richmond VA and Philadelphia PA.
    So if you have temp trend data from those four cities, you don't actually have 4x as much info as you'd have from (e.g.) DC alone.
    Or, for a thought experiment, consider adding 5,999 thermometers at Reagan National Airport, separated by 1' from each other. Yeah, you've got 6000 readings, but not 6000x as much new information.
    So here's how it actually works. You take all the temp readings from those areas, and when one of them jumps up or down relative to the rest, you bring it back into line with the rest, under the assumption that something (location, instruments used, whatever) changed. For example, it's not possible that the temp trend at Reagan National airport jumped 0.5 degree while the temp trend at Dulles airport didn't.
    That's called a homegeneity adjustment. If you're NASA GISS, you only take readings from outside the urban area, to avoid bias from increasing urban heat island effects. Whereas if you're NOAA, you keep all the data, and so a regression-based adjustment for urban heat island effects. The Brits, by contrast, just take them all, under the assumption that the (change in) the heat island effect is small.
    And you end up with the same temperature trend estimate.
    None of this, by the way, applies to the 70% of the earth's surface that is ocean.
