Planing CanView and BMS+ conversion with lithium
Discussion in 'Prius PHEV Plug-In Modifications' started by Mr-plugin, Oct 27, 2011.
  1. Flying White Dutchman
    4,376
    314
    at the moment i dont now i did not look at that and have the batery caase out of the car so try and finisch it.
    i hope that i can place it back soon.. but not before next week i think.
    i am closing the housing right now and still have to place the EV200 contactors in a housing and do the same for t he 72 bleeding boards and 9 celllogs with al the 73 wires.
    i am going to place them in a box next to the battery housing with 2 x 36 pol centronics plugs so i can connect and disconnect them.
    inside the box i wil place the relays to for the charger shutoff
    all of this i did not yet have time to do yet.. when thats finisched and the battery pack under the floor.... well then... then... omg then its time for a holiday ;-)
    maybe i can do a temp connect a again before that and then i can do some more tests and give you the value
  2. Flying White Dutchman
    4,376
    314
    do you guys use the relays of the canview( for those using canview to connect the add pack ) to control the ev200 contactors or what your using or do you first control a relay and with that control the contactors? because the canview got reedrelays and what about arc etc.
  3. mrbigh
    3,686
    699
    Long Island, NY
    I'm using one relay to fire-up the OEM batteries blower at High Speed.
  4. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    My Canview has 6 relays.
    Canview relay 4 is dedicated for add-on packs. So I used relay 4 to switch a 12v relay to switch my 200amp contactor. The Canview relay is not rated high enough amps to control the 200amps contactor directly.
    R1 - dedicated for EV mode.
    R2 - Enginer kit 1
    R3 - not used
    R4 - Lithium pack - dedicated for add-on packs.
    R5 - control HV battery cooling fan modification.
    R6 - Enginer kit 2
  5. Flying White Dutchman
    4,376
    314
    o ok.. wel at firsy i would think that would be enough for the canview relays to switch the Ev200 contactors... but reading below i no longer sure.
    you dont have to drive a contactor or do you? and if you do.. you control them direct from the canview?
    i have the ev200 contactors with the lower power coil for less energy use.
    maybe use 1 relay for a shutt off and on of temp hack.
    trying to get in contact with norm but no reply for a while?...
  6. Flying White Dutchman
    4,376
    314
    connecting the canview to ev.. never done this before ( always by hand using the standard EV mode button on EU prius ) and no longer have the pinouts
    pin 8 and 15 are EV try? ( and is the EV already shorted to ground or do i still need to connect a ground wire?? EV is just a Prius H14 pin 27 to ground switch.. so maybe canview already internal connected to MIN? its a dedicated relay for EV )
    5 and 12 are phev contactors?
    of the 15 pin connector for the relays
  7. lopezjm2001
    1,146
    407
    Sydney Australia
    The Australian Prius also comes with factory fitted EV switch. I connected the Canview R1 across the EV button. The pin outs are only needed for USA Prius which does not have a factory fitted EV switch.
  8. Flying White Dutchman
    4,376
    314
    yes! what i wanted to check is what the pinouts in the canview relay output are
    but i think i am right that pin 8 an 15 on the canview are for the ev try
  9. lopezjm2001
    1,146
    407
    Sydney Australia
  10. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    Plug-In
    I still have more questions:
    First can you take some shots(images) of your wiring set up?
    Did you have to get a "liliput" like screen for the BMS plus?
    You went with 70 cells like 10Kw and for my vehicle I just thinking 57 cells like 7Kw?
    Plus any more photos thanks
  11. Flying White Dutchman
    4,376
    314
    70 cells or 72 are because of the voltage
    you can not go with 56 cells
    these are 20ah then you need to buy 15 ah or 10ah x 70-75 units
  12. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    10-15ah is too small, the C rate would be massive (12.5C for the 10ah). I think even the PIS kit with 16ah cells is pushing it - Headway are good but still 7.8C is high.
  13. Flying White Dutchman
    4,376
    314
    ok did a 2e test today
    45 km and o.8 l/100km
    then one cell dropt to 2.6 and lowist others where still at 2.8
    so what happend here....
    at end charge before drive cell where within 10mv diff
  14. Flying White Dutchman
    4,376
    314
  15. NortTexSalv04Prius
    915
    116
    ACTUALLY not sure what you are trying to state. I have seen 76 cell count (PIS) 76 cells 40ah. Plug-in went with 72 cells I thinks. I am not sure why you have issue with (57)LifePo4 40ah cell
  16. planetaire
    planetaire Plug in 20 kWh 85 km/h or > 208km range
    190
    139
    France
    All cells are serialy connected.
    If you use less then, say, 69 cells, voltage will be too low and it will be impossible to connect these cells directly on the nimh. If you do it, you will have a huge current and nimh will send energy to lithium. Then lithium will be overcharged and will be destroyed.
    When paralleling lithium and nimh, you need that the voltage of the two battery be very close. Voltage is usualy between 220-230v dc.
    So if you want 7kWh, use 15Ah and connect them two by two, you will have 30Ah and 70 to 72 cells x 2 = 140 to 144 15Ah cells.
    This is called 70s2p
    2 people like this.
  17. Mr-plugin
    Mr-plugin Member
    98
    51
    Sandy,UT
    The screen is for the Can view. If you do not want to do the can view then you will need at least a ScanGauge or similar to keep a eye on the pack voltage.
    You need the 70-72 cells to match the battery voltage of the OEM pack. you will need either 20ah cells or the 40ah cells.
  18. Mr-plugin
    Mr-plugin Member
    98
    51
    Sandy,UT
    I have different cells but mine reads .10 to .20 depending on temp of the batteries.
  19. NortTexSalv04Prius
    915
    116
    Okay so you are using your MFD for the BMS plus viewing. My understanding for 2007 Prius you can not use MFD and must go with alt plan.
    thanks
  20. NortTexSalv04Prius
    915
    116
    I understand about the serially connected sort of. So let me ask this differently. We are all aware of limited space in rear trunk area of Prius . If some kits are 4kw how are they doing this and matching voltage from lithuim to nimh. I am thinking LifePo4 prismatic cell pack with high(energy density)(16ah,20ah,40ah,60ah,80ah,or 100ahcells). However, total cells, weight, size and fitment are just as important.(for me) The tradeoff (for me) would be that I must go with either 4kw pack or 10kw pack. I do not want a 10kw pack for these reasons additional weight, adding coil springs modification for additional weight, increased cost, and somewhat reduce interstate MPG performance.
    Which ones for a 4kw ??
