Planing CanView and BMS+ conversion with lithium
Discussion in 'Prius PHEV Plug-In Modifications' started by Mr-plugin, Oct 27, 2011.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    I like your design you should sell them on ebay
    2 people like this.
  2. Flying White Dutchman
    4,376
    313
    any you guys have logged info about the cell temp? during driving end charge?
    i do a manual log where i have a wireless temp sensor inside the battery pack.
    i started at somewhere 24 Celsius ( 75,2 F ) after a short drive and then charged and after that i did a 45km trip and went up to 33,4 Celsius.( 92,12 F )
    then after that i charged again and this dropped to 32,6 C ( 90,68 F ) and after that, and at the end of charging it just went down more.
    so no small increase during or after stopping charge.
    i think 33 C is a bit high .. outside was around 14 C ( 57,2 F ) so what to expect during the summer? i think i need a good Fan attached to the pack.
    at what temp of the cells do you guys think its starting to be a risk? 50 C? ( 122 F ) for things like termal runaway.
  3. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
  4. Flying White Dutchman
    4,376
    313
    so you ad a ~3,175 Mohm over R1?
    your R1 and R2 are close to mine
    i have R1 600Kohm and R2 8,x Kohm and its higher because my endvoltage is 292V so i think that will be ok?
    edit
    i do think opening a elcon charger mod topic is better then having 3000+ posts in 1 topic about a lot of stuff ..
    people need to really dig into the topic to find what they need.
  5. lopezjm2001
    1,146
    407
    Sydney Australia
    R1 - 482300 ohms
    R2 - 8680 ohms
    Trim Range (Decreasing it only):
    Note I only tried this quickly on my unit, it seemed to work, but tread carefully.
    In this case you want to make R1 a bit smaller so you will add a large parallel resistor
    between Pin 2 and DC+ (see the following photo).
    1) Measure the upper resistor R1 (between pin DC+ and pin 2). R1 - 482300 ohms
    2)
    RatioMax = Vmax/ Vorig = 252v / 256v = 0.984375
    RatioMin = Vmin / Vorig = 256v - (256v x 0.10) = 230.4v / 256v = 0.9
    Vmin = 10% reduction of original voltage Vorig​
    3) Parallel Resistor total for R1 (in this case)
    RPmax = RatioMax X R1 = 0.984375 x 482300 ohms = 474764.06 ohms
    RPMin = RatioMin X R1 = 0.9 x 482300 ohms = 434070 ohms
    4)
    RAddmax = 1 / ( 1 / RPmax - 1 / R1) = 1 / (1 / 474764.06 - 1 / 482300) = 30384900 ohms
    RAddmin = 1 / ( 1 / RPmin - 1 / R1) = 1 / (1 / 434070 - 1 / 482300) = 4340700 ohms
    I think I got that right!!! It should end up a resistor about 10 times R1 for a 10%
    reduction.
    Raddmin / R1 = 4340700 / 482300 = 8.6 (not exactly 10 times)
  6. lopezjm2001
    1,146
    407
    Sydney Australia
    I think the control voltage of 5.1v should be 5.0v which gives me more accurate results.
  7. Flying White Dutchman
    4,376
    313
  8. lopezjm2001
    1,146
    407
    Sydney Australia
  9. Flying White Dutchman
    4,376
    313
    mm so we have ~786kohm or ~494kohm ( with a 5 volts instead of 5,1 )
    what wil it be?
    i have 600Kohm and 292volts end now, a 10% decrease would be 262 that i want so 10 x 600 = 6Mohm
  10. lopezjm2001
    1,146
    407
    Sydney Australia
    Using values from FWD's Elcon charger.
    R1 - 600000 ohms
    R2 - 8500 ohms
    1) Measure the upper resistor R1 (between pin DC+ and pin 2). R1 - 600000 ohms
    2)
    RatioMax = Vmax/ Vorig = 292v / 292v = 1.0
    RatioMin = Vmin / Vorig = 292v - (292v x 0.10) = 262.8v / 292v = 0.9
    RPmax = RatioMax X R1 = 1.0 x 600000 ohms = 600000 ohms
    RPMin = RatioMin X R1 = 0.9 x 600000 ohms = 540000 ohms
    4)
    RAddmax = 1 / ( 1 / RPmax - 1 / R1) = 1 / (1 / 600000 - 1 / 600000) = infinity (open circuit) ohms
    RAddmin = 1 / ( 1 / RPmin - 1 / R1) = 1 / (1 / 540000 - 1 / 600000) = 5400000ohms
    reduction.
    Raddmin / R1 = 5400000 / 600000 = 9 (not exactly 10 times)
  11. Flying White Dutchman
    4,376
    313
    wrong calculationss
  12. lopezjm2001
    1,146
    407
    Sydney Australia
    Too hard to use Excel on my IPad. 504kohm is R1.
  13. NortTexSalv04Prius
    915
    116
    Please explain
  14. Flying White Dutchman
    4,376
    313
    (10000/(5/252)) - 10000 = 494
    (10000/(5.1/252)) = 484 ( but then with a control of 5,1 volts )
  15. Flying White Dutchman
    4,376
    313
    problem with my charger is that when i want a 10% decrease using that 10x for 10% decrease example i get 6Mohm ( 600Kohm is my R1 so R1 X 10 = 6000000 ) buth when i use the (8500/(5/262)) - 8500 = 436.9Kohm.
    so.. do i need to have a 6Mohm or 439Kohms paralleled over R1
  16. NortTexSalv04Prius
    915
    116
    If "if" I am building a DIY battery pack with Lifepo4 and I go with 72 cells 40ah 3.2 volt.prismatic battery pack suggestion number (one)
    or
    "If" I go with 72 cells 60ah 3.8 volt prismatic suggestion number(two) can either work or not?
  17. lopezjm2001
    1,146
    407
    Sydney Australia
    I calculated your Radd = 5.4 Mohms using the calculations given in this PDF
    http://priuschat.com/forums/attachm...n-lithium-how-trim-endpoint-volatge-elcon.pdf
    Your calculations can be found here ....
    http://priuschat.com/forums/prius-phev-plug-in-modifications/99420-planing-canview-bms-conversion-lithium-57.html#post1492224
    The value of 436.9Kohm is the Rtotal = Radd//R1 but this depends on whether to use 5.0 volts or 5.1 volts.
    Radd = 1 / (1 / Rtotal - 1 / R1) = 1 / ((1/436900)-(1/600000)) = 1607235 ohms
    Using 5.1v control voltage instead:
    (8500/(5.1/262)) - 8500 = 428167 ohms
    Radd = 1 / (1 / Rtotal - 1 / R1) = 1 / ((1/428167)-(1/600000)) = 1495057 ohms
    I would go with using a 6Mohm trim pot if they exist. But I would not adjust it to any lower than 1 Mohm. So say a 5 Mohm trim pot in series with a 1Mohm resistor.
    2 people like this.
  18. Flying White Dutchman
    4,376
    313
    yes thats confusing haha
    so what do you think.. your calculations or the one in the pdf? 1,6Mohm or 1,49Mohm
    i think i need a pot meter so i can variable adjust and see.
    did you already do your mod? in the pdf there is a picture where you can solder into the DC+ for the decrease voltage.
  19. lopezjm2001
    1,146
    407
    Sydney Australia
    Do you think I am stupid enough to do this mod which has never been tried out to decrease the voltage endpoint. It has only been used and tested to increase the endpoint voltage. I rather just use the current control pot and charge @ 1amp overnight. The calculations are too speculative. It just not worth taking the chance of wrecking my Elcon charger.
  20. Flying White Dutchman
    4,376
    313
    ok well because you where doing the cal. for you own charger i was under the impression you where going to do that
    for what ever reason would you do this then?
    increase<>decrease
    anyway its been done to increase the voltage and in the pdf he also did t he decrease.
    not sure to what point
    i want to do this mod anyway i dont like my charger to go to 292 volts end..
