Planing CanView and BMS+ conversion with lithium
Discussion in 'Prius PHEV Plug-In Modifications' started by Mr-plugin, Oct 27, 2011.
  1. Flying White Dutchman
    4,376
    313
    a you added a picture!! nice!
    your runing the 20ah 70 cell pack? or is this with 72 cells? or with the new 20ah added so 40ah total pack?
  2. planetaire
    planetaire Plug in 20 kWh 85 km/h or > 208km range
    190
    139
    France
    Graph was done with 70 A123 cells, from 40% depleted to 80%.
    Because you love pictures, one more: :D
    next project comming soon with 144 cells, so 72 x 40Ah need more plates between cells (more then 200) :
  3. Flying White Dutchman
    4,376
    313
    OMG thats a lot of recourses.:eek:
    i used recycled/reuses plastic ;-) with a small amount of alumiuim plates to pressure the tabs together:):D
  4. Flying White Dutchman
    4,376
    313
    mmm some more bad news about the A123 cells
    jack from EVTV got a real A123 OEM battery pack like used in the fisker karma
    and what happend! one of the cells shorted that was inside the pack
    EVTV Friday Show - April 27, 2012 - YouTube
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,436
    3,304
    Madison, Wisconsin
    There is a lot more than meets the eye to the cells Jack got.
    If you want to read more details I encourage you to read the thread on Endless-Sphere about these A123 packs that are coming on the market from China.
    And if you can't sit through the extended Jack video you can read some summaries of it beginning on this post of the Endless-Sphere thread.
    There may be some possibilities. But we won't know more until later this week.
    Some of their members are getting packs and will do more in-depth testing, photos, and overall investigation of them.
    2 people like this.
  6. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Hey
    Eric are you a forum member on endless shere?
  7. ericbecky
    4,436
    3,304
    Madison, Wisconsin
    Yes. EVPowers. Do more lurking than posting, though. :)
  8. Mr-plugin
    Mr-plugin Member
    98
    51
    Sandy,UT
    5 people like this.
  9. Flying White Dutchman
    4,376
    313
    how many km or miles? is that trip
  10. Flying White Dutchman
    4,376
    313
    a 33 miles or 53.1 km
    1.56 L/km
    nice
  11. Mr-plugin
    Mr-plugin Member
    98
    51
    Sandy,UT
    I use out of gas mode in 90% of my driving, but I did this test just to show people what it is able to do for the normal person who has to do freeway driving. I used about 20kw from my pack according to the Can view. I could probably get 45-50 miles out of a charge. so even if you had to commmute 90 miles a day, and you could charge at work, you could get some great gas mileage. ;)
    3 people like this.
  12. NortTexSalv04Prius
    915
    115
  13. Flying White Dutchman
    4,376
    313
    :rolleyes:? this is on topic i think:)
  14. Flying White Dutchman
    4,376
    313
    first drive today after a while.
    installed the battery case and did a manual ev200 control
    now to get a wire from canview to the back of the car.
    ohm during drive was between 0,15 and 0,05
    you guys also get that ohm range or more lower?
  15. Flying White Dutchman
    4,376
    313
    it seams to that the ohm is mie higher
    but ofcourse i have 9 anderson plugs connecting the 5 boxes now and 2 ev200 relays inside a relaybox with lots of wires... so ohm will go up
  16. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    It has been a while since I made a post on this thread. Just put in a fire extinguisher into the front door pocket. See photo. Just in case. Hope I will never need to use it.
  17. lopezjm2001
    1,146
    407
    Sydney Australia
    I am looking at buying this item on Ebay and using it to drop out the 200A contactor when the regenerative braking current is too high. The price looks OK.
    http://www.ebay.com/itm/Programmable-Digital-Dual-Display-90V-200A-Combo-Meter-Voltage-Amp-Power-Ah-Hour-/180856335786?pt=LH_DefaultDomain_0&hash=item2a1be0adaa
    It appears that the OCP (over current protection) can be programmed between 0.01 amps and 200Amps. Downside is that it can only measure current in one direction only. Still it can also be used to measure how many AH go into your lithium battery pack whilst charging overnight. I will probably use a voltage divider to reduce the voltage from about 240Vdc to about 24vdc, ratio 10:1, as it is only rated for a maximum of 90Vdc. It has a relay output PCB which I can use to drop out the 200A contactor when OCP value is reached. I am guessing that the OCP alarm is self-resetting.
  18. lopezjm2001
    1,146
    407
    Sydney Australia
    Can you explain what is going on in each YouTube video of the Elcon charger.
    I believe that at the end of charge you get either:
    1. Flashing green LED. Charger has finished CV mode and completed the whole charge program. Charging can be cycled with a AC Plugin timer on charger.
    2. Green and red flash. Charger did not finish charging program after being interrupted by HVC relay. Charging cannot be cycled with a AC Plug-in timer unless HVC relay was reset. Mine is reset by powering up the Prius using the ready signal. Cycling the charge on a HVC can overcharge the cell which is causing the HVC. For this reason the HVC needs to be reset manually.
    Tested and verified.
  19. Flying White Dutchman
    4,376
    313
    mine came one installed already underneath the passenger seat
    the toyota brand is printed on it so its dealer installed
