Planning an engine replacement @ 400,000.0 miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Paul Schenck, May 10, 2015.
  1. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    Anyone decided to do this themselves? I've got another 12,000 left to go.
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Not worried about traction battery and transaxle problems, or have those been replaced already?
    52,848
    i don't keep my cars long enough.
    Paul Schenck and PLSPUSH like this.
  4. brucebee
    brucebee Junior Member
    84
    vista, ca
    Please do it! I hear motors are dirt cheap and you live , oh sorry fresno. My o 04 has been to key west, etc in april, was in parker yesterday, socal, valley center etc today. 176k but put 40k at least in 11mo. let me know because i like my car and plan on at least 500k. 5k oil changes w dino. how about u? I bought w 100k dealer serviced but just oil and filter since. Burning oil or what? Just paid 367/gal 2day. only in socal. BTW my car does not need oil between changes and I do not baby it.
    Paul Schenck likes this.
  5. Patrick Wong
    18,210
    6,517
    I'm wondering what fault symptoms your engine is demonstrating?
    If you are going to replace the engine, I suggest that you also replace the transaxle since the labor effort is essentially the same and between the two components, I would rate the transaxle as much more likely to fail than the engine.
    Paul Schenck and orenji like this.
  6. orenji
    orenji Senior Member
    5,887
    3,488
    Are you experiencing engine issues, or are you just being proactive?
  7. Paul Schenck
    524
    307
    Fresno, California
    Due to Oil Burning (1 qt every 800mi) the Catalytic converter isnt converting any more, Codes P0420, P0441,P0446.
    I think your Idea of replacing the transaxle at the same time is good
    Im also hoping to get a salvaged exaust manifold replace the one I burned through when the CAT clogged.
    m.wynn likes this.
  8. Paul Schenck
    524
    307
    Fresno, California
    replacing an engine after 400,000 is just due diligence and respect. I want to see whats holding it together???
    orenji and m.wynn like this.
  9. Paul Schenck
    524
    307
    Fresno, California
    What are the symptoms of a transaxle failure?
  10. Paul Schenck
    524
    307
    Fresno, California
    I know the feeling Bisco I had 9 cars in the nine years from age 16 to 25. I bought the Prius because I was impressed with the engineering and thought if it broke I'd take it apart and figure out how it worked. It just never broke! If I don't stop at 400,000 I may be too old to wield a torque wrench
  11. bisco
    52,848
    if you do, i hope you'll post pics and commentary. i wish i could be there to help, i'd love to learn how something like that is done.
    i watch the guys on tv, they make it look easy, but they don't show enough detail.
  12. Paul Schenck
    524
    307
    Fresno, California
    I got myself a Toyota Certified replacement at 300,000, it was made up of GEN III cells. So I'm good till i get to 600,000. Patrick Wong suggested I replace the transaxle at the time I do the Engine and past experience says thats a good call.
  13. Patrick Wong
    18,210
    6,517
    There are three general failure modes:
    1. A burnt stator winding which means that one of the MGs will fail to operate
    2. An electrical ground fault (similar to #1 but not as severe, the winding still conducts electricity so the car can still operate if the 12V battery is disconnected to clear the DTC)
    3. A mechanical problem like a failing bearing which will cause excessive noise as a warning
    I would expect that the used engine would include the exhaust manifold. It would be nice if you could also get a used catalytic converter but that may not be legal for sale.
  14. Paul Schenck
    524
    307
    Fresno, California
    I have none of them though I think I will replace Transaxle too as you suggest. Want to rebuild one!
  15. Paul Schenck
    524
    307
    Fresno, California
    I will post progress notes and perhaps i can download a time laps app. :)
    ILuvMyPriusToo and bisco like this.
  16. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    If you do replace the engine and transaxle at the same time, perhaps rebuild the old transaxle (if possible) and the dying engine?
    Would be a great learning experience. Assuming you have the space, tools, patience, and finances for this big project.
  17. Paul Schenck
    524
    307
    Fresno, California
    Engine+Transaxel swap. I so respect the engineering that went into the Gen2.
    It took me a year to get up the nerve though, :) Salvage 2006 vehicle for $1000, Lens post on DIY Transaxel , a manual.
    Then 2x4, Rachetting tie down straps x2, 2 ton jack, four jack stands, 10mm 12mm 14mm 17mm 19mm and a 12point -1 1/4" sockets, 2lb sledge 1/2" breaker bar with four foot pipe for a handle extension.
    I set it down on a piece of plywood using a couple of wedges to stabilize it and keep it off the oil pan. Then, with some welding rods slid under the plywood with the help of a pry bar, rolled it out from under through the wheel well with 1/4" to spare. Didn't even need a beer to get it out!
    m.wynn likes this.
  18. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Put the 400K guts back into the salvage 2006 to drive it to the recycling yard?
    Still waiting to see the time lapse video! (y)
    b100 and Paul Schenck like this.
  19. Mendel Leisk
    42,343
    Hopefully someone didn't already do that, lol.
  20. Paul Schenck
    524
    307
    Fresno, California
    It wasn't quite that fun
    iPhone ?
