Plasti-Dip!!!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by tecmo04, Apr 3, 2012.
  1. tecmo04
    tecmo04 Junior Member
    detroit
    I just finished plasti-dipping the front and back emblem on my prius. super easy to take the parts off the vehicle. I also painted the plastic backing to silver to match the paint.
    Next step will be to finnish the other emblems on the side and back. woohoo!!
    just wanted to share
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    You don't need to take the parts off if you use plastidip though. :confused:
  3. tecmo04
    detroit
    i wanted the silver backing too...
  4. ockevin
    ockevin Active Member
    493
    148
    Orange County
    How do you do it without taking off the emblems...?
  5. kschramm
    kschramm Junior Member
    40
    Poolesville, MD
    2018 Prius Prime
    Very nice.
  6. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    Mask off areas and you can carefully peel off the areas of overspray.
  7. macmaster05
    4,050
    730
    Ohhh gotcha. Thanks for the pictures too. It looks great.
  8. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    It's still a lot easier to remove them for a perfect look. ;)
  9. HI MPG
    789
    133
    93
    Orange County, CA
    Very true... ockevin was asking how it would be possible without removal, so I answered it. :)
  10. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    I found it much easier to do it without removing them. And I ruined the hybrid badge when I removed it. See .sig for link to pics.
  11. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    its actually hard, using plasti dip with the emblems. I did it on my back logos, when I tried peeling it off from the sides, everything came out. Even masking off areas.
  12. ucsmfu
    1,498
    420
    canada
    tecmo04, how did you remove the emblems ?
  13. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    74
    98
    Brunswick, GA
    removing the HYBRID emblems from the front fenders to put my turn signals/markers there ruined those emblems.....not that I was going to use them for anything anyway, but still, it ruined them removing them.
  14. tecmo04
    detroit
    Process was super easy.
    The front: no tools required
    -Remove three plastic locking screw things (they are total
    Garbage) at the front of the hood.
    -Take off the black plastic cover
    -Use your hand to squeeze the clips on the back of the emblem and it should pop out (plastic backing and chrome emblem)
    The back: need a credit card
    -slide the credit card under the bottom of the emem at the bottom
    -slide it around the side working about half of it under the plastic cover
    -apply pressure and it popped right off!
    Taking off both took literally 3 minutes
  15. Corwyn
    2,171
    659
    23
    Maine
    Ah, you didn't take off any of the ones that are taped down. That explains it.
  16. tecmo04
    detroit
    No. I plan on masking the car for those...
    That's next weeks job!
  17. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    I plan on tackling this option also. Wondering what the Plus Performance badge will look like in Plasti Dip? I will post pics when I'm done.
  18. tecmo04
    detroit
    I did the rest of the emblems and they came out pretty good. front left "hybrid" logo needs some touch up but very pleased. definitely worth the effort
  19. RCDrifter
    RCDrifter Junior Member
    Southern California
    I tried removing the rear emblem, but it isn't coming out! Its actually starting to permanently bend the emblem! I used a credit card like you said. Any tips?
  20. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Got a heat gun? Be careful, you don't want to strip the paint...
    Galaxy Nexus ? 2
