Plastic Engine Cover: Why Keep It?
Discussion in 'Gen 3 Prius Main Forum' started by Rebound, Jul 18, 2017.
  1. NeilPeart
    NeilPeart Hybrid & PiP Convert
    75
    69
    Bay Area, CA (USA)
    Neither has Disco Stu...
    Mr. F and bisco like this.
  2. Shaun_Collins
    Shaun_Collins Junior Member
    48
    Tulsa / Broken Arrow / Catoosa Area
    It is usually designed to keep water spray out of coil over plug ignition/ spark plug wells preventing shorts and rare sudden contraction cracking.
    LG-H918 ?
    Patrick Wong and jerrymildred like this.
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    Cover; engine; appearance. Nuff said.
  4. Patrick Wong
    18,210
    6,517
    That would be the non-cosmetic cylinder head cover bolted to the cylinder head.
    That is certainly a 2G problem, so to the extent that #2 cover helps to keep water off the #1 cylinder head cover, that would be an excellent non-cosmetic reason for the existence of cover #2.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    OK...so if the debate is centered around keeping it on or removing it....and nobody is REALLY sure?
    I'm saying keep it on.
    Because I'm pretty sure any heat dissipation benefit is pretty minimal. To the point of being...well..no benefit at all.
    Keeping it on? Well, that's how the vehicle came from the factory. IMO it's looks nice. And if it keeps moisture from doing any damage to a vital area or part? I would take that chimerical benefit over the chimerical benefit of removal for heat dissipation.
    Plus there is no argument that the cover keeps Gremlins from directly urinating on your engine. That benefit alone has me voting just keep the cover on.
    Sometimes you can overthink something.
  6. Mendel Leisk
    42,271
    Yeah can we get onto something important, like how high to raise the hood before dropping it when closing? ;)
  7. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The industry name for these things is "Engine Beauty Cover." Its purpose isn't to keep water off the valve cover.
    Mendel Leisk and jerrymildred like this.
  8. Yippeekyaa
    Yippeekyaa Active Member
    137
    160
    North Carolina
    It's for holding hobo steaks against the hot engine so the steak doesn't falll onto the exhaust and get overdone. 15 minutes at 65 mph then flip it over and another 10 minutes yields a perfect medium cooked steak every time. It also comes in handy as a water bowl for my dog. The inverter is perfect for pancakes with its large flat surface. Still trying to perfect a shish kebab method but with no fan belt or pulleys to use as a turner its become frustrating.
    jerrymildred likes this.
  9. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Of course, with plastic wheel covers, you now have to pan ahead!
    Yippeekyaa likes this.
  10. CardiffChris
    CardiffChris Member
    94
    63
    Cardiff by the Sea, California, USA
    2014 Prius Plug-in
    I kept the engine cover from my previous Prius.
    So, Now I have a spare one in the garage.
  11. Hanging on with 286k
    Hanging on with 286k Junior Member
    26
    16
    Ontario, Canada - 300,000+ miles
    Hello. I would like to check the coolant in my radiator, but I can't because there is a cover over the cap! I can touch and see the reservoir but I am going to have to remove the "cover" to touch the radiator cap. Is this normal? Why?
  12. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,559
    2,599
    Taylors, SC
  13. bettergolf
    bettergolf Active Member
    493
    370
    Sanford NC
    You should only need to look at the side of the white plastic coolant reservoir. There will be min and a max levels indicated on the side. No need to remove the radiator cap just to check the level.
    Hanging on with 286k likes this.
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Cover is there to make the engine less noisey which these atkisson motors with solid lifters need and most new cars are GDI now and there high pressure fuel pump makes quite a racket so they all have a big cover.
    I got a new GDI car and removed the cover the noise does not bother me. All that cover does is trap alot of engine heat. And creates a big heat soak too when the car is shut off since it traps the engine heat so well.
  15. Mendel Leisk
    42,271
    3rd gen doesn’t even have a radiator cap.
  16. edthefox5
    10,096
    4,837
    Clearwater, Florida
    And yes you need to remove the radiator cover because on this whacky car the overflow plastic reservoir could be full and the rad empty
    So you are on the right track
    Just unscrew the plastic screws holding the cover on by snaking your hand behind the screw and push it out while unscrewing
    Once screws out not neccessary to put them back in the hood will hold the cover in place without the screws
    So it will be easy to check the rad levels
    My cover has no screws for years and years
    since your interested in the coolant side of things get a flashlight and look closely at the front of the engine where the engine water pump is it’s in the passenger side
    You’ll see the water pump belt so look for green corroded flecks in that area that means the pump is worn out and water is leaking out of its weep hole hits the belt and is thrown all over that area
    If the car is new to you I would replace that belt asap as it’s extremely critical. That belt tvurns the water pump no belt no pump
    If belt fails and falls off you will never know as there’s no temp gauge. Engine will quickly over heat and the Only thing you’ll see
    Is a thermometer icon on the dash meaning the engine is in severe over heat which sometimes will blow the engine.
    You can easily lose an engine over a $20 belt in this car.
    Btw you cannot see how worn the belt is till it’s off
    Good idea to check the tensioner pulley with belt off as the pulley bearing tends to wear out
    This is all just basic maintenance on this car
    so if the rad coolant level is low you probably have a leak as the coolant level will stay the sane for years.
  17. Hanging on with 286k
    26
    16
    Thanks so
    Thank you Ed. I had the Serpentine belt replaced recently. What is the name of the belt that you are referring to?
    edthefox5 likes this.
  18. Mendel Leisk
    42,271
    Ok, recent question is from a gen two owner, my mistake.
    Grit and edthefox5 like this.
  19. edthefox5
    10,096
    4,837
    Clearwater, Florida
    It’s the same belt it’s not a serpentine belt it’s actually a fan belt.
    Only belt on the engine and it’s only job is to turn the water pump
    That’s very good it’s been replaced but be aware it’s a very stiff belt and it’s a good idea too check it’s tension after it’s been driven a bit because after it’s been broken in
    the stiffness goes away and it may loosen up and will need to be tightened back up.
    Do not discount anything to do with this belt as it’s extremely important combined with a disastrous and horrible design with no temp gauge.
    You will never know if it’s failed till you start smelling burning smell by then too late.
    Grit and Hanging on with 286k like this.
  20. Hanging on with 286k
    26
    16
    Apologies for posting in the wrong forum. Thanks guys.
