Plastic Engine Cover: Why Keep It?
Discussion in 'Gen 3 Prius Main Forum' started by Rebound, Jul 18, 2017.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Hanging on with 286k likes this.
  2. aperry1971
    aperry1971 Junior Member
    50
    17
    mass
    Took mine off years ago and yes it makes a difference when it comes to New England weather as the aluminum is oxidizing.... Removed my sister's 2005 Toyota solar and WOW what a difference the valve cover and hardware look new!!! Pictures attached of mine and my sister car..
  3. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    If you think it's difficult to access or see the reservoir you ought to try checking the coolant level on some motorcycles. Plastic panel(s) have to be removed. Just plain dumb engineering.
  4. Canard
    Canard Member
    223
    Ontario, Canada
    I can't quite tell, but do you think one of the three mounting points is broken on my cover? It's rattling at certain engine r/min, which has just started after some recent heavy engine work:
    (make sure to select 60 fps for the frame rate; 30 fps gets a funky effect going that makes the wobble look super-slow!)
    #44 Canard, Oct 3, 2024
  5. Mendel Leisk
    42,345
    Are all these guys present:
    Heavy engine work?
