WTB plastic engine covers underneath?
Discussion in 'Private Sales' started by mountaintodd, Oct 9, 2016.
  1. mountaintodd
    mountaintodd Junior Member
    61
    Western North Carolina
    I am looking to replace the missing plastic engine covers underneath my 2013 Prius. See pictures! I know it's going to be a little weird to find a box and ship them, but at least it shouldn't weight a lot. Let me know if you can help please? I am willing to pay for them of course. Thanks!
  2. Air_Boss
    Air_Boss Senior Member
    4,248
    1,195
    New Yawk
    ebay is your friend, for both oem and repro covers. The full under-tray/engine cover is somewhat spendy, in the $240 area, shipped. The front cover (below front bumper is in the area of $40, shipped.
  3. milkman44
    milkman44 Active Member
    591
    386
    Ky
  4. Mendel Leisk
    42,305
    There's nothing missing in your second picture, that's the engine under panel, and it has several openings. For comparison, here's a pic of ours:
    In the first picture, what's missing is a flap portion of the engine under panel, at the engine oil pan. This portion is often unfastened and bent back at it's "hinge" by service departments, and is prone to break off, due to the thin/brittle nature of the plastic used. Basically a fail by Toyota.
    The simplest way to restore the whole thing (as mentioned above) is to spring for a complete new engine under panel. The flap that's broken off will also require several fasteners, that more-n-likely will be gone. That said, there's a possibility more of the fasteners are knackered or missing, best to assess.
    Here's a snapshot from the attachment inset picture, you'll need two #5 (larger, grey headed fasteners) and the two fasteners and spanning piece of item #4:
    There are aftermarket versions of the engine under panel available, for around $50. They'll be missing the interior insulation pieces, and there's been comment about uneven quality and some fit issues. That said it'll probably do.
    Me, I'd get the official Toyota one, then never use that flap again, always remove the entire panel (it's not that hard), and wash the plastic fasteners whenever they're removed, in hot/soapy water. Doing all this, the panel should last the life of the car. I've done all the oil changes on ours, about 12 so far, following this regimen, and no problems.
    I'll attach a diagram of the panel and the fasteners, with part numbers. There's a few typo's in it. for example, in one place the type "5" fastener references "thinner material", and in another it is "thicker material". The latter is the case I think, it is a heavier fastener, the one with grey centre piece. Also, the main picture id's some fasteners within the inset circle as type #3, then in the inset they're id'd as #5. Again, the later case is correct.
    Bottom line, there's (11)-#3, (2)-#5 and the (2)-#4 with tie piece. With the latter, if you always remove the whole panel, you never need touch those.
    As far as I know the part numbers are correct. Like a lot of Toyota documents, it's cumbersome, but you can muddle through.
    #4 Mendel Leisk, Oct 9, 2016
  5. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    You could try finding a wrecked Gen III Prius and pull it off of that.
