Plastic grille bar
Discussion in 'Prius c Technical Discussion' started by novaz, Jun 3, 2017.
  1. novaz
    novaz Junior Member
    47
    arizona
    2015 Prius c
    What the heck is that grille bar for is it Toyotas try at keeping cold air off the engine
    also having been a hot rodder for many years most of the cars I had always ran better with cold air intakes especially the supercharged engines I built ,
    I have seen a lot of threads about foam insulation being fitted to the grille during winter temps.
  2. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    Aerodynamics make a larger contribution to the efficiency of a Prius, especially at higher speed. The engine runs cooler than a typical automotive engine because it's more efficient.
    In the winter time, many Prius owners do a "grille block" where they put foam pipe insulation in the radiator grilles to reduce the amount of air hitting the radiator. This makes the car warm up faster in the winter. The engine uses more fuel during warmup, so reducing the time it takes is the idea. The heat will also work faster. Many diesel truck owners will also block part of their radiators off in the winter for similar reasons.
    The aims of most Prius enthusiasts are different from typical car modifications. We mod for economy rather than for more power. If you added a cold air intake- for cooler, denser air - you're also going to have to inject more fuel to make use of it. You'll have more power, but you'll loose mpg. Some people will take a bit of a trade off for more power. Then again you can get a TRD exhaust for a Prius so there's something for everyone lol.
  3. novaz
    novaz Junior Member
    47
    arizona
    2015 Prius c
    Thanks for the reply totally new to Hybrids so lots of questions but this is a great forum
