Plastic push pins (replacement) DIY oil change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bill075, Jan 5, 2010.
  1. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    +1 LOL
    I may have to try that just to keep my spare stock rotated :)
  2. mikebull
    mikebull Junior Member
    Thousand Oaks
    Confirmed the following part numbers are correct for oil change undercover:
    Large size (9 mm hole, 22mm head) : 90467-09227
    $9.50 for 10 pack (clipsandfasteners.com)
    Small size (7mm hole, 20mm head) : 90467-07201
    $10.15 for 10 pack (clipsandfasteners.com)
  3. Den49
    Den49 Member
    498
    272
    Maryland
    Thanks GreenClipper. Below is the link to my thread. Note that there are two types of hinges that I tried. The continuous hinge (Post#30) is the better of the two because it secures the entire length of the hinge area.
    http://priuschat.com/forums/gen-iii...903-oil-change-door-permanent-solution-3.html
  4. GreenClipper
    GreenClipper Senior Member
    116
    Tulsa, Ok.
    Thanks for the post regarding the updated hinge. I had long ago suggested a "piano" type hinge for this application, but everyone that posted comments about it thought it was a bad idea, seemingly. Said it would corrode and become frozen, etc. I think it is an excellent way to go, as I was thinking about what type of scrap plastic I could use for a "stiffener" across the hinged are, that I could attach under the hinges. This takes care of that! Does this firm you ordered this hinge from not have a ready made length of hinge that would work w/o sawing it off to length? Quick read of your post sounded like you had a 72" piece to cut down, is that what I read?
  5. GreenClipper
    116
    Tulsa, Ok.
    Third time to the web site and I see that their "stock" lengths are 72", & 96". So I guess I answered my own question. Sorry that I didn't see that before I asked you to clarify. I may see if I could find a similar hinge locally that was maybe a foot long, or 18"..... Six foot of hinge for 14" of use seems like a lot of waste material, but then I'm kind of at a loss as to where to start to look. But think I'll beat the bushes, and see if anything can be found. This piano type of hinge doesn't allow for "removal of the pin" does it? I kind of liked the idea of being able to get the door completely away from the opening. Two of my neighbors have lifts, but I hate to ask them to use them, + I use and "extractor" for the oil, and am only under the car to R&R the oil filter anyway. Thanks again for sharing your experience and knowledge. :cool:
  6. Den49
    Den49 Member
    498
    272
    Maryland
    The pin does not come out, but the door opens completely and can be pinned up to the undercover so it is as good as being removed.
    I would be happy to cut a 14" piece from the remaining continuous hinge I have and send it to you. The original 72" piece cost me $32.28 so 14" would be $6.30 plus shipping which will probably be $10.00 to $15.00 for an estimated total of $16.30 to $21.30. Send me a PM if you are interested.
  7. Seymour1
    Seymour1 Member
    266
    33
    During my 1st oil change, I replaced broken and missing push pins with ones from a kit. Some were the one-part friction type. I had to hammer some in. Since then, I have bought more kits. It is rare to find a proper fit from a kit.
    A garage just did the 2nd oil change. They did not fasten the door flap at all. Plus other pins were missing. When I backed from my gravel driveway, I scooped up a bunch of rocks and at 65 MPH the entire cover flapped in the wind. I thought it was a bad tire at first.
    One of the holes at the oil change door has ripped open. I am tempted to do what the youtube oil change guys do: remove the under-engine cover permanently. A new OEM cover is hundreds of dollars.
    How many different size fasteners mount the under-engine cover?
  8. Eddie25
    Eddie25 Active Member
    502
    212
    MI
    A new aftermarket under-side "engine cover" off rock auto is $55 shipped for me. I think I got mine from ebay or amazon for less than that about 6 years ago (looks like it's ~$70 now). It's worked fine since then. You can also get push clip sets from amazon and as a bonus some of them come with the best push clip tool ever.
