Plastic Rivits
Discussion in 'Gen 3 Prius Main Forum' started by Raphael Muscarelle, Dec 21, 2022.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Anyone know what size the plastic Rivits the gen 3 2011 Prius used for under the car shields?
    I got a bunch that aren't the correct sizes.
  2. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    Get the proper clips at your dealer, they are only a couple dollars each.
  3. Mendel Leisk
    42,348
    For the main under panel the parts numbers are in the attached. For all of them, have a look at the official Toyota USA website:
    Toyota Parts and Accessories - Official Online Store
    It takes a bit of rooting around; they're not all in one place.
    I've got a few tips for preserving them, in the oil change link in my signature.
  4. Raphael Muscarelle
    661
    222
    U the man got all the docs
  5. Raphael Muscarelle
    661
    222
    They break easily too so why bother.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,603
    Taylors, SC
    Toyota uses 7mm plastic rivets.
    These work perfectly and cost much less than those from the Toyota dealer.
    Ziruiautopart 100 Pieces Pin in 7mm Hole Compatible for Toyota 9046710183 Plastic Rivets Car Clips Fastener Push Clips Retainer for Cars for Scion Lexus
    Raphael Muscarelle likes this.
  7. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    True in most spots, but a few of them are 9mm size, including one on the oil change flap. I bought a box of 7mm ones through Amazon, much less expensive than dealer prices. They function about equally as (un)well as the original ones.
    The biggest irritation with buying them from Amazon is that half their listings for such fasteners fail to specify the fastener diameter---although they may show some scarcely relevant dimension, such as the size of the box they're packed in.
  8. Mendel Leisk
    42,348
    Two I think. The ones with the grey centre piece?
  9. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    On the flap itself? Perhaps you're thinking of taking the entire underpanel off?
  10. Raphael Muscarelle
    661
    222
    I haven't ordered them yet but this is what I found on ebay using part numbers. Screenshot_2022-12-22-08-23-07-42_260528048de7f2f358f0056f785be619.jpeg Screenshot_2022-12-22-08-22-10-00_260528048de7f2f358f0056f785be619.jpeg Screenshot_2022-12-22-08-21-55-41_260528048de7f2f358f0056f785be619.jpeg
    Montgomery likes this.
  11. Mendel Leisk
    42,348
    Could well be; I take the full panel off at oil changes, so not that conscious of the flap zone.
  12. Georgina Rudkus
    3,576
    2,603
    Taylors, SC
    Instead of plastic rivets, I used M6 rivet nuts that fit the large 9mm holes perfectly without drilling and M6 stainless steel bolts with large neoprene fender washers, They do not shear off like the plastic rivets.
  13. Mendel Leisk
    42,348
    In my experience at least, the plastic fasteners fail due to broken jaws and or snapped center caps, due to the mechanism jamming with grit. Rushed “professional” service doesn’t help. See oil change link in my signature for preservation tips.
  14. ColoradoBoo
    ColoradoBoo Senior Member
    1,349
    980
    Monument, Colorado USA
    Yep, I hate breaking those plastic clips...and there's quite a few different sizes on our Toyotas! I have two big plastic containers with assorted sizes and, so far, have been able to find suitable replacements. And, of course, small zip-ties can be a last-ditch savior if the piece will let you get one in there. (Often, you can't)
    The worst clips are those ones on the little doors under the rear seat that cover the air filter for the battery cooler fan....they break about 95% of the time.
  15. Mendel Leisk
    42,348
    Zip ties, and maybe heavy gauge copper grounding wire, are good items to keep in a "car first aid" kit. The copper wire can serve as heavy-duty twist ties, when something's dragging or whatever.
    ColoradoBoo likes this.
