Plastic wrapping on front side windows?
Discussion in 'Gen 3 Prius Main Forum' started by mediahound, Oct 8, 2013.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Almost all Gen III Priuses I've been in have this in the front small windows:
    Does yours?
    What's the deal?
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Never noticed that until now
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Looks like the shipping/assembly plastic was not removed. tsk tsk, lazy dealers! ;)
    WE0H likes this.
  4. SJ PiP
    SJ PiP Member
    190
    35
  5. gliderman
    gliderman Active Member
    751
    225
    I dont have it. Not sure if thats good or bad?
  6. 102mm
    102mm Junior Member
    30
    As a matter of fact I just noticed that today, then I see this post lol
    swyped from my Note II with Taptalk 4
  7. David Beale
    5,963
    1,990
    Edmonton Alberta
    Just to underline my comment above that it is "shipping plastic", I checked mine and there was a tiny bit left over when it was removed. I -suspect- it's there to prevent the window from being scratched when the dash or interior plastic is installed.
  8. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    Mine had the shipping plastic left completely intact on the right side. It was shaped to cover the white felt-like material around the window. When I yanked it off a small bit remained which was removed using tweezers.
  9. WE0H
    WE0H Senior Member
    3,247
    528
    Damn, I better check mine ;-)
    Mike
    Mobile on my SGH-i717 now Free
  10. Nora
    Nora Member
    128
    44
    CO
    No! Don't remove THAT! It keeps the battery from discharging when the car is off. ;) But if you notice any sounds before or after you remove it, when the car is running or not running, these sounds would be perfectly normal and no cause for concern. :D
    WE0H likes this.
