Plastidip, Blacked out prius, or some white?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Austin5, Mar 6, 2013.
  1. Black Rims, Black Emblems, Tinted Windows
    83.3%
  2. White Rims, White Emblems, Tinted Windows
    16.7%
  1. Austin5
    Austin5 Go Bruins
    34
    Boston MA
    What do you think?
    Black out the already Black prius, with black emblems and black rims..
    OR make all the emblems white, with white rims?
    I'm going to be plastidip-ing, am and wondering which you think will look better. And maybe if anyone has used white plastidip? Does it dirty easily, and is it harder to clean because of the white??
  2. 2fastplus
    2fastplus Junior Member
    56
    26
    Tampa Bay
    Black the emblems out! I just got finished blacking my emblems with Plasti-Dip and love them. It is just as easy as all the videos show. Putting white rims on a black car, NOT!!
  3. Austin5
    Austin5 Go Bruins
    34
    Boston MA
    So far I've just done the two main emblems because they were so easy to take off and I was exciting to try the plastidip, but I'm looking at doing the others such as the prius and hybrid ones. It's 10 degrees out so ill wait a couple weeks for the masking ones. I also added some hidden LED's behind the grill which look pretty nice so far.
  4. 2fastplus
    56
    26
    Tampa Bay
    Cool! I sprayed all my emblems on the Prius without taking them off. Any Plasti-Dip overspray pulls right off the paint, no fuss -no mess.
  5. f1rst 1
    f1rst 1 Junior Member
    Denver
    did you tape anything off or did you just spray them as is?
  6. 2fastplus
    56
    26
    Tampa Bay
    I used blue painters tape and created a square around the emblem, size appropriate of course. There was about an 2 inch spacing from the emblem. Then newspaper to prevent overspray and your good to go. Go to You-Tube and search Plasti-Dip videos.
  7. f1rst 1
    Denver
    Cool, sounds good. Thanks for the info.
  8. Austin5
    Austin5 Go Bruins
    34
    Boston MA
    For the Toyota logos it's WAY easier to take them off, just use a credit card to get the back one off, and pinch the clips under the hood for the front one! No peeling or tape required just some newspaper
  9. 2fastplus
    56
    26
    Tampa Bay
    Now you tell me Austin5! I figured it wasn't that hard, but didn't feel like fooling with it. Great Tip, THANKS!!
  10. detroit11
    detroit11 Junior Member
    doesnt that leave a hole ? so then what ?
  11. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    I believe he is talking about the "T" emblems on the front and back. They are easier to spray off the car. The are only held on by clips, no tape.
  12. 2013pearl
    2013pearl New Member
    Not sure if adding plastidip to the whole car will look good. I it my rear panel glossy black vinyled and plastidip the Toyota emblem
  13. detroit11
    that looks good. i like the black t's
    so they dont have placement holes. and can just be removed.
  14. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Way harder. Sometimes the badges get ruined in the process (I ruined my HSD badge). Plus you need new tape to put them back. I taped, plasti-dipped, removed overspray, cleaned up mine faster than just removing and cleaning up the ones I removed.
    To OP, That seems a personal choice, do what you think will look best. Or since plasti-dip is easy to change, do what you think will look less good, live with it fora few days, and change to the other option.
  15. Austin5
    Austin5 Go Bruins
    34
    Boston MA
    Not the sticky ones, those you need to mask and shouldn't pull off.
    Exactly.
