PlastiDipping Imported LED DRL's for the 10-11 Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by El Nino, Sep 16, 2012.
  1. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    after plasti dipped.
    Hey El nino, I'm thinking of tinting the front winker led's and maybe the L shape led too, what do you guys think ?
    A light tint :p
    wagdaddy and ockevin like this.
  2. El Nino
    El Nino Member
    210
    Michigan
    Wow..Great Job! Did you use the glossifier to ENCAPSULATE! lol I wouldn't tint the winker but I have been thinking about tinting the Hockey Stick so I could have it on at night.
  3. ucsmfu
    1,498
    420
    canada
    Hey. I didn't really like how the plasti dip turned out. The edges weren't perfect. I ripped it all off and I'm going with the matte black vinyl wrap approach. Gonna tint the turn signal and the hockey stick :)
  4. El Nino
    El Nino Member
    210
    Michigan
    lol..after all that. Good Luck and keep us updated.
  5. ucsmfu
    1,498
    420
    canada
    I couldn't encapsulate all the black plasti dip, plus I can out ><
    A buddy is going to help me wrap them and tint them for $60
  6. El Nino
    El Nino Member
    210
    Michigan
    Can't say enough good things about Webelectrics DRL module..works great and easy to hook up -
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    This would probably be easier to power the DRL harness than the method I suggested.
    U can use something like this:
  8. ucsmfu
    1,498
    420
    canada
    where can I buy this Sean ? what is it called ? and how many do I need ?
  9. El Nino
    El Nino Member
    210
    Michigan
    sfv41901 likes this.
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Anytime.
  11. ucsmfu
    1,498
    420
    canada
    hey el nino, just wondering if you can take a pic of the module wires running to the L shape DRL's as well as the wires connecting to your fuse box
  12. El Nino
    El Nino Member
    210
    Michigan
    sorry bud...everything is taped up pretty good, but I made the picture above to help you out...it's pretty straight forward. Let me know if you need any help with a wire or two.
  13. El Nino
    El Nino Member
    210
    Michigan
    Hey UCSMFU..Here is a better illustrated connection pic for you. Hope it helps.
    E
  14. ucsmfu
    1,498
    420
    canada
    thanks, !!!
    i'm encapsulating the LEDS right now as we speak, been raining for weeks and today the sun is finally out
    on my 5th layer of glossifier right now
    soo the black and red wire from the DRL's, the red connects to the purple from the module, and the black connects to the black wire of the module ? or to the ground screw ?
    thanks !!!
  15. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    I thought the Prius uses low profile mini ATM fuses, the ones shown are mini ATM fuses.
  16. El Nino
    El Nino Member
    210
    Michigan
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    They do......this was just to serve as a reference..
  18. El Nino
    El Nino Member
    210
    Michigan
    Also...make sure wherever you squeeze in the module (I went on the left side of the fusebox) that is completely upright or water could pool in where the wires exit and damage the unit.
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Yes or if u don't want to run the grounds all the way to the black wire off the module, u can find any metal area near the bumper to serve as the ground
