PlastiDipping Imported LED DRL's for the 10-11 Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by El Nino, Sep 16, 2012.
  1. El Nino
    El Nino Member
    210
    Michigan
    Yeah...he was testing them with the lights off so that's why he couldn't get a correct reading. The parking light whip is so much easier and it is right there where you need to be. We verified it also is black and white so he should be good to go now. He's working under a tent really trying to get it done.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Poor guy......it was 5deg C last night when he was working on it.
    He had said that he wanted to be able to keep the DRLs on with the parking lights, that why we were trying to tap the headlight. He had the right connector just need to find the right wire.
  3. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    hey Sean, do you have whats app ?
    I bought a bulb circuit tester this morning.
    I made sure it was grounded. I tested all 6 holes from the grey connecter, with the car in ready as well as with the car not in ready. Non of them showed a live wire.
    I did the same test like El nino said with the parking lights. my parking bulbs work both sides, I put the power pin in the connector hole with the white and black wire, and grounded it as well.
    No live wire.
    I gotta get my car ready, got to work soon. i will go at it again after work 6pm, luckily my buddy has a garage i can work in. I bought work lamps this morning too ><
    To be continued............................
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    I'm playing hooky today from work so u can FaceTime me if u want.
  5. El Nino
    El Nino Member
    210
    Michigan
    You don't need a tester when you have a black and white wire coming from the parking light whip...just splice into the white wire (with the blue wire from the module). This is just a trip wire for the module to turn OFF the drls when the lights are on. Also..if you are testing any light wire..then you have to make sure the light is ON as well....it's not enough for the car to be on and lights off.
  6. ucsmfu
    1,498
    420
    canada
    apparently i have a faulty light tester, lol, and I wasnt grounding it properly, lolll
    nhl 2013 ?
  7. El Nino
    El Nino Member
    210
    Michigan
    UCSMFU's New Project! Duplicolor Painted White DRL'S !!
    I think it would look awesome E..you should try it. I'm sure it wont be an exact match but probably close enough. I used to think that the duplicolor plastic paint I used on interior would come off with Hand car Wash Jets...but I just tried to take some paint of an interior piece I had...and the stuff would NOT come off! lol. I did use adhesion promoter so def use that if you decide to try something new. Glad we got you fired up today! Still waiting on pics. :)
  8. ucsmfu
    1,498
    420
    canada
    here's the long awaited pics, LED's light up for the very first time :)
    Plasti dip and tint removed
    Thanks to sfv41901 and El Nino for their help :)
  9. wotcher
    wotcher Member
    403
    97
    16
    LA
    you non2012-ers get all the cool mods.
    youre not done yet. now have you to paint it white!
  10. El Nino
    El Nino Member
    210
    Michigan
    Looks good!
  11. bino
    bino JDM ZVW30
    1,348
    705
    SoCal 91739
    lights are looking good...
  12. El Nino
    El Nino Member
    210
    Michigan
    They would look SICK painted white.
  13. ucsmfu
    1,498
    420
    canada
    i'm not sure about the white, haha, the chrome kinda matches my headlights and it doesn't that bad in the white ><
  14. El Nino
    El Nino Member
    210
    Michigan
    good point..it does look good on white. What kind of glare are you getting at night with the full 100% DRL light? I think the chrome may increase it? If it's not bad then I say move on to the next mod!
  15. ucsmfu
    1,498
    420
    canada
    Not much glare at night expect the fact that it lights up the entire ground :) better visibility.
    I'm gonna work on getting yellow fog light projector lens installed on these DRL LED's, they are coming from an Lexus IS series, I will let you know how that turns out, but so far, the cut off line is pretty straight :)
  16. jmrmotorhead
    jmrmotorhead Junior Member
    85
    44
    New Hampshire
    EDIT: Removed
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Looking good E
  18. El Nino
    El Nino Member
    210
    Michigan
    why not just get some laminx and put that over the lens?
  19. ucsmfu
    1,498
    420
    canada
    I've tried, it doesn't work, I wasted 2 laminex films, the projector is too round, and will not stick at all ><
  20. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Why not use hyper yellow or 3k bulbs?
